Question about Epson Stylus C86 InkJet Printer
Epson Stylus DX7400 - Ink cartriges
How do I change the cartridges in the printer? I do not have instructions
  • Anonymous May 03, 2009
    i do not know how to change the inks in the epson stylus DX7400 i have tried all different things but its not doing it, please help me
  • 39 Answers
Lift the scanner up to expose the inside of the printer. Thers a button "stop" top left face of printer, press and release and the print cartridge holder will move, press again and it will stop at the colour that needs replacing, press again (total four times) to show if other cartridges are ok. Press again and the cartridge carrier will return to right of the machine. Lift the lid (grey colour) to show the cartridges, remove and replace the ones that have been shown to be empty. Close the lid, it should click. Close the scanner down again. Press "start" to recharge the cartridge. ANy other problems try the epson support site. Good luck.
Posted on Dec 07, 2008
Dead easy if you follow these instructions:
Click on "Start" and select "Control Panel"
From Control Panel, select "Printers & Faxes"
Right Click on "Epson"
Select "Printing Preferences"
Select "Maintenance"
Select "Ink Cartridge Replacement"
The cartridges will now be easy to remove and just follow remaining instructions on screen.
Posted on May 10, 2010
  • ad_ham Jul 02, 2011
    I got as far as Ink Cartrdge Replacement and it was blanked out.
I cant get the carriage to stop at point where I can check cartridges. Frustrated or what
Posted on Apr 02, 2010
If you go to the start menue and click printers and faxes then right click the epson...button then click printer prefrences then click utility and then change ink it will give you instructions good luck x
Posted on Nov 07, 2010
How to replace an ink cartridge on Epson Dx7400.Cyan has run out TO712.I have lost my user manual and I cannot remember which button to press to get the Printer part to the right spot for changing the...
On your printer and then click on the start menu goto Printer and Faxes. After that goto your default printer Epson Stylus and right click the printer then click properties. Dialogue box was appear click on the maintenance and then click replace cartridge their was dialogue box will also appear. Just click the next button and read the instruction when you press the Next button. After that open the cover of your printer when the cartridge are at the center thats the time you can change the cartridge. Then close the cover when your finished to change the cartridge. Then click the next button and so on to finished.
May 28, 2010 | Epson Stylus Multifunction Inkjet Printer/...
How do i change the ink cartridges on my epson stylus dx7400
It is as simple as below.
Open up the hood of your printer.
Switch on the printer.
The cartridge will come in the centre to remove.
Press at the back of the cartridge and slowly remove it.
While installing the new one follow the reverse process.
Thanks
Jimmy
Apr 29, 2010 | Epson Stylus Multifunction Inkjet Printer/...
How to change ink cartridge in epsonnx110
Here is what I found on Epson Web site. Click on link below. IF YOU FIND THIS HELPFUL PLS RATE ME. THANKS AND GOOD LUCK......
http://www.epson.com/cgi-bin/Store/support/supDetail.jsp?BV_UseBVCookie=yes&infoType=Doc&oid=128285&prodoid=63083739&category=Products
If you need to change a cartridge before it or any other cartridges are low or expended, run the Ink Cartridge Replacement utility.
You cannot print or copy when an ink cartridge is expended even if the other cartridges are not expended. Replace any expended cartridges before printing or copying.
Leave your old cartridges in the Epson Stylus NX110 Series until you are ready to replace them to prevent the print head nozzles from drying out.
When an installed ink cartridge is more than six months old, you may need to replace it if your printouts do not look their best, even after cleaning and aligning the print head.
Follow the instructions in these sections to check and replace your ink cartridges:
Replace Cartridges Using a Printer Software Utility
For best printing results, use up a cartridge within six months of opening the package. If you need to replace a cartridge when the ink light is flashing or off (before the cartridge is expended), you can run the Ink Cartridge Replacement utility.
1. Windows: Right-click the printer icon in the bottom right corner of your screen (the taskbar) and select Printer Settings. Click the Maintenance tab.
Macintosh: Open the Applications folder, open EPSON Printer Utility3, select your printer (if necessary), and click OK.
You see one of these screen SEE ATTACHMENT BELOW
2. Click the Ink Cartridge Replacement utility icon and follow the on-screen instructions to replace your ink cartridges as necessary
Jan 01, 2010 | Epson Stylus NX115 All-In-One InkJet...
How do I change the ink cartridge on a Epson DX7400
Directions are on the Inside the cover and in the manual, you can also find them at the Epson website.
Dec 29, 2009 | Epson Stylus Multifunction Inkjet Printer/...
Replacement ink cartridge ruined my printer.
Get a CISS for your printer. It will save you TONS of MONEY, never change a cartridge again and it will pay for itself in a month.
http://www.inkproducts.com/ink-store/
Jun 21, 2009 | Epson Stylus C86 InkJet Printer
EPSON DX7400 ALL IN ONE PRINTER INK CHANGE
ok just done it - i always have to look it up too!
find the default printer from your control panel
click right click and pick properties
then hit printing preferences
then click tab marked maintenance
and follow the ink cartridge replacement instruction
printer leads you through no probs - hope this helps
Mar 25, 2009 | Epson Stylus Multifunction Inkjet Printer/...
Epson dx7400 printing green
one of your people advised me that it was most likley a bad cartridge i changed it and it worked ,thanks
Feb 04, 2009 | Epson Stylus Multifunction Inkjet Printer/...
Changing inks
Visit this page and download the manual for your printer: www.techfuels.com/printer/11727-epson-stylus-dx7400-all-one-inkjet-colour-printer.html - 53k -
Jan 23, 2009 | HP Compaq Business Desktop dx7400 - Core 2...
Epson Stylus C86 InkJet Printer Logo
5,767 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
