Question about VeriFone Omni 3700
Restraunt credit card machine
Credit card machine is full and will not batch
  • 10 Answers
Contact your processing company
phone# is on your statement
Posted on Mar 17, 2010
My Credit Card Terminal was batching out and it ran out of print paper, so I had to change it right then. It cancelled my batch, so did my batch process? Do I need to re-enter the credit cards from th
you would have to call your processing company and ask them to check if they sales completed the settlement. you can also run a report on your terminal by pressing the purple key marked reports, if the sales are still in the terminal they will show on this report if they settled it will not have information.
Oct 07, 2014 | VeriFone VX 510 Credit Card Terminal
What does must settle TSYS MEAN WONT TAKE CARD
This means that the batch file needs to be settled before more transactions can be made. Do a batch download and this should solve your problem. If you need more help call. Frank (775)338-6634
Sep 19, 2014 | VeriFone VX510
Batch error RB-000-E0001H18000
call your credit card processor, they have to call TSYS to get them to clear it on their end as well.
Sep 03, 2014 | Hypercom T7Plus Credit Card Machine
How to fix settle error RB-000-E0001H18000 on a hypercom t7plus
that error RB: means repeat batch / the batch was already sent and needs to be cleared out of the machine. TSYS also needs to clear it on there end too.
Why batch error RB-000-E0001H18000
That error RB: means repeat batch / the batch was already sent and needs to be cleared out of the machine. TSYS also needs to clear it on there end ...
Credit card machine
'Retry Batch Trans' indicates the terminal settlement was unsuccessful. Hypercom terminals require settlement errors be corrected before allowing processing of new transactions.
Attempt the batch and take the necessary action based on the response of the batch attempt.
May 29, 2013 | Computers & Internet
My credit card machines show ivn batch sew...dont know what it mean
There was a miscommunication between your terminal and your processor. You need to call them to verify batch totals and possibly update some info inside the terminal.
Feb 14, 2011 | VeriFone Omni 3200 Printer
Proccessed incorrect amount on credit card
If you catch the error right after you run it, do a void rather than a credit. A credit could takes weeks to show up for a customer and they won't be happy with you.
Mar 29, 2010 | VeriFone OMNI 3200 (P092-101-10) Printer
How can i use credit card mashine
Following are the steps to use credit card machine
step1:Input the credit card numbers.If you have the credit card in hand, swipe it through the card reader. Most readers have a small icon or picture on them that shows which way the magnetic strip on the back of the card should be facing. If not, try running it
through the reader with the strip facing the machine first, since that is the most common direction. If you have a phone order, or do not have the credit card in hand, select the button marked "sale." On many machines this is also the "1" key, but it varies depending on the brand of the machine. Then follow the on-screen prompts to enter the card number and expiration date. Always double-check the numbers before pushing enter
step 2:
Input the sale information.Typically, the machine will first ask for the sales amount in dollars and cents. Input the amount using the number keypad. Double-check the amount to make sure it appears correctly on the screen and if it does, then push enter. If you accidentally input the wrong amount, look for the "clear" or "delete" key and start over. In some cases, the machine will prompt you for additional information after you've entered the sale amount. Follow the prompts to enter information, such as the customer's zip code or an order number.
step 3:
Wait for the sale to process. Depending on the machine's connection the sale may process within seconds or it may take a few minutes. If the machine seems to become "stuck" while processing a sale, do not re-enter the sale, but instead call the processing company's phone number for further instructions. In many cases this number will appear on a sticker on the machine.
step 4:
Process the receipt.If the customer is present, have them sign the credit card receipt. Give them the copy and retain the original for your records. If the customer is not present, write "phone-in" or another appropriate phrase on the signature line of the receipt. Keep one receipt for your records and include the other in the shipment of the goods to the customer.
step 5:
Close the batch.Double-check with your processing company, but most require you to run a "batch report" or close a batch of credit card receipts each day. This is the process that tells the company to finalize the credit card charges and deposit the balance to your account. Many machines will have a key that is marked "batch." You can press this key and then follow the prompts to close the batch at the end of the day. If the machine does not have a "batch" key, consult the user's manual for instructions or call your credit card processing company for instructions.
Thank you
Mar 14, 2010 | IBM Domino.Merchant Server Pack Upgrade...
Nurit 2085
This is most likely cause by a crupt transaction or a transaction that is not aloud stuck inside the terminal. Once you batch out contact your processing comapnyask them if they see you current batch you jut settled. If so they will need to clear the the terminal and up the batch number. Just make sure all of your sale are settled with your processign comapny before you go ahead and clear the terminal.
May 14, 2008 | VeriFone (M19755014US1) Magnetic Card...
Retail Supplies Logo
116 people viewed this question
Top VeriFone Retail Supplies Experts
danielle yancer
danielle yancer
Da Doc
Are you a VeriFone Retail Supply Expert? Answer questions, earn points and help others
