Question about Dishwashers
Error code A04
Could you tell me if this is related to the heating element and if so would changing it resolve this problem? also is it easy to locate and replace?
  • kingkenny01 Jun 08, 2009
    hi i'm sorry it's taken this long to reply but i've been handwashing the pots and i'm now fed up!! my problem is still there as i have tried to remove the front from my dishwasher to no avail but i did get in from the back and replaced what ariston call the heating element about 5-7inches long, looks like a pipe with wires on, anyway that hasn't worked and i now have a spare heater do you have anymore suggestions that i could try?
  • 623 Answers
A04 = Unable to sense/reach temperature in 70mins. - machine drains until Level Switch resets + 1 minute First, open the door and look into the tub and locate the heating element (if it is covered, remove the lower dish rack and cover). The heating element has two terminals which extend through the bottom of the tub, note the general location where they go through.
To access the heating element's wiring, remove the front panel located beneath the door. The panel is usually held in place with two screws either above or below the panel. It may be necessary to first open the door to the dishwasher to reach the screws over the panel, then close the door to remove the panel.
Look into the lower access area and locate where the terminals come through the tub. Each terminal has a wire connected to it. Label the wires and the terminals so that they can be properly reconnected. Pull the wire off of each terminal; they are connected with a slip on connector. Firmly pull the connector, do not pull on the wire. You may need to use a pair of needle-nose pliers. Inspect the connector and terminal for corrosion. If either is corroded they should be cleaned or replaced
Each terminal is secured with a lock nut, use a crescent wrench or pliers to loosen the nut. Remove the two lock nuts. From inside the tub, lift the element out. Position the new element over the holes and set it in place. Replace the lock nuts and reattach the wires. Replace the access panel, the element cover, if any, and restore the electricity.
Posted on Aug 31, 2008
I have a hoover silver pulse inverter e03 came up on the display then changed to e16, what do I need to do?
Hoover dyn8144 and related machines
Error code 03 followed sometimes by Error code 16
Check the usual drain pump and resistance of heating element
On my machine I've discovered that on the motor if the brushes are not bedded onto the commutator it will cause the above codes to display and stop the machine.
The problem is not related to the drain pump or heating element so the codes displayed are not correct. If the brushes are not bedded to the commutator the motor cannot get to spin speed but will happily wash away. Watch the machine during a quick wash to ensure it does actually spin
Jul 10, 2015 | Hoover Washing Machines
Cod. error a04 on the display
Appliances fault A04 has different meanings depending on the type of appliance. Please see below for further detauls:
Also see our video section for help.
Error: A04,
Machine: Dishwasher,
Type: EV02 Module,
Fault: The selected temperature was not reached within a given time.Check thermistor and heater
Error: A04,
Type: Standard Module + FDW70 + FDW75,
Fault: Heating fault.Check thermistor and associated wiring
Hope helps.
May 02, 2011 | Dishwashers
Will not heat
Most likely the heating element. They are pretty cheap and almost as easy to change as an ovens element. Most times they are cracked and easy to tell if broke, otherwise could be a computer issue.
Heating element break easily with all the contracting and expanding they do. So most of the time it's the element.
Sep 12, 2010 | Kenmore 98702 Stacked Washer/Dryer
What is systems error A04
System Error A04 indicates Timed out awaiting response from printer. To resolve problem, follow the instructions on this link: If problem continues, I strongly suggest you contact Lexmark technical support to further investigate the problem. Thanks.
Aug 18, 2010 | Lexmark X83 All-In-One InkJet Printer
F 03 showing on machine
Yes F-03 indicates a faulty thermistor (it's inside the heating element at the back). Before calling an engineer, just open the bottom rear panel and check that the connector has not come loose (OR IN MY CASE FALLEN OFF COMPLETELY). This can happen if there is a spin cycle that runs out of balance big time. (two thin wires on a square unit about 5mm in size fitted to the middle of the heating element).
Jul 06, 2010 | Hotpoint Ultima WF860 Front Load Washer
Heating elements will not heat and getting an error code E1 F-5
Hello,the lock latch is located directly in the center upper portion of the door. It is a hook shaped latch that lock by turning downward. This lock gets stuck in this position which causes the e1 f5 error code. Locate the latch through the vent holes in the upper front of the oven door. Insert flat headed screw driver into vent hole and gently push latch up to a horizontal position & simply open door. Once unlocked, push cancel on the control panel.This will clear the error code and resolve the issue.
May 30, 2010 | Whirlpool Ovens
Hello I am getting error code E3 on my Baumatic dishwahser- how may I resolve this? Thank you
its "malfunction of temp sensor or heating element"so it is either the heating element or temp faulty test and replace the faulty part
Nov 09, 2009 | Baumatic 23 in. BDW13 Built-in Dishwasher
Help with correcting fault code f-5
F-05 error means:-- Water Temperature Sensor Error
If during the water heating step in wash cycle, the water temperature sensor (NTC) value is out of range, or the heating element circuit has failed, the "F/05" error code will be displayed.
Check the Water Temperature Sensor, Heating Element and Element Relay globul1a.gif Check connections to the Sensor, Heating Element and Relay
May 07, 2009 | Washing Machines
Heater not working in cycle. No Error Code present
The LG 5811 dishwasher would display the error "tE" if the thermistor has failed. Not seeing an error could mean that the controller card (PCB) has failed. Hard to tell if the heating element has failed or wiring has shorted.
To look a little further, you can see (but not remove) the heating element by removing the filter in the sump area beneath the bottom rack. Disconnect dishwasher from power first and inspect for obvious failure of element.
Gaining access to the heating element is very complicated on the LG units. You have to drop the entire sump unit after turning the dishwasher over on its top.
Recommend a service call.
Feb 10, 2009 | LG 24 in. LDS 5811 Built-in Dishwasher
DE73 A04 Error code
you may have a bad heating element..or temperature sensor the water temperture is not getting hot enough to let the dishwasher run. you my reset it and try running the water in the sink until it reaches hot ... then try stating the dishwasher...let me know if this helps
Aug 28, 2007 | Indesit 24 in. DE73 Evolution...
Dishwashers Logo
136 people viewed this question
Top Dishwashers Experts
