Question about Sony Ericsson Cell Phones
Model Z310i having difficulty charging. Does not start charging even after 35 minute period sometimes if switched on and off several times charging commences however is a bit of a hit or miss. Sometimes left for 2 hours only 5% charged.Phone has done this for last 6 months and is now outside warranty which ende May this year.
    Brigadier General:
  • 7,752 Answers
Try a new battery or take the phone to a mobile service center to have it reflash nd also you can try topsony.com
Posted on Aug 31, 2008
Refrigerator will not restart for a very long period of time after power cut.
there may be a faulty capacitor for the compressor motor
I would suggest a technician check it out as it should come back working within minutes of a power cut
there will be a short delay until the pressures even out as compressors have difficulty starting under pressure but you delay is extreme and needs checking out.
Apr 27, 2015 | LG Refrigerators
Camera does not start even with new batteries
Your camera will work with AA batteries.
Always be sure the batteries are charged.
Insert the batteries correct plus to plus and minus to minus. Only one battery the wrong way around and the camera won't work. Check contacts of the batteries and in the battery compartment of your camera. Dirty or oxidised contacts can be cleaned with a dry cloth. Never use sharp tools to clean contacts or anything in or on your camera.
Always charge the batteries before using it for the first time, or if you have not used it for a long period. 3 months is a very long period.
Also check if the battery door is closed correct. Most cameras do have a switch connected to the battery door. If the switch does not work correct, it could be you can't switch on your camera.
Do not use alkaline batteries unless it is absolutely necessary. In some cases, alkaline batteries may have a shorter service life than NiMH. Alkaline battery performance is limited, especially at low temperatures. The use of NiMH batteries is recommended.
Never use manganese (Zinc-Carbon) batteries in your camera. They can't deliver enough power and can start leaking, causing damage to your camera.
Feb 13, 2014 | Konica Minolta DiMAGE Z5 Digital Camera
My lift-master garage opener works just fine from wall button, but will only open but not close from any remotes (from car or original remotes) If I open it with remote and immediately close with wall...
We have the same model and similar difficulties. We were told it's a bad antena. Not sure if there is anything we can do about this. Sometimes it works with the remotes, sometimes not. Always works with the wall switch, because that's wired.
Nov 12, 2010 | liftmaster Chamberlain Garage Door Opener...
My name is samuel adjei boadi from ghana. the fault of my phone is that the z310i happens to be a new phone.whenever i charge the phone with a charger, the phone stops charging or switches off.when you...
there was a connector problems with your sim card and the battery connectors please try to stretch it to up and try again.........if you dint get what i said call me on my mobile +91 9704788855
Dec 05, 2009 | Sony Ericsson Z310i Cellular Phone
Acer aspire 3050 new battey will not charge
Sometimes batteries need a full 24 hr initial charge before they will work. You would be advised not to use the M/C during this period. Also it will take several charges before the battery reaches it's optimal performance.
This could be the problem so it's worth a try.
Aug 21, 2009 | Acer Computers & Internet
Acer Aspire 5580 poor battery
Its time for a new battery. After a period of time of using a battery, the amount of charge it can hold depletes. Even if you always have it plugged in. Usually, batteries only last 18-24 months which is sad, seeing how much they cost. I'm a computer tech and see this problem everyday first hand. The best thing you can do is buy a battery from eBay and save yourself a bunch of money. Local retail stores charge up to 3 times as much for a battery. Good luck and I hope this helps..... :>)
May 31, 2008 | Acer Aspire 5500 5570-2609 Laptop
Getting gprs settings to connect to O2
Go back to the sony site, pick another region like the U.K for example choose your phone and resend the settings. Do it again and it should work. Just pick diiferent regions
Jan 23, 2008 | Sony Ericsson Z310i Cellular Phone
Cell Phones Logo
43 people viewed this question
Top Sony Ericsson Cell Phones Experts
Computer Repairing
Computer Repairing
Sandeep Shenoy
Are you a Sony Ericsson Cell Phone Expert? Answer questions, earn points and help others
