Question about Lexmark P4350 All-In-One InkJet Printer
Re my Lexmark cartridge problem.
The printer is a Lexmark P4350
  • 435 Answers
I have posted a solution. Please check the other thread.
Regards
Posted on Aug 31, 2008
I have Lexmark p4350 I can not copy, and show error 2200
According to the Lexmark site the 2200 error is a jam, possibly the scanner. Try unpluging the power at the printer, remove the paper, and see if there is any paper stuck in the unit. Another possibility is the cartridges are messed up. If you don't find paper stuck, remove the cartridges, and reinstall the color one. If the error goes away, the black cartridge is possibly bad. Another problem you can't fix, which is the scanner glass cracked. In that instance or if the cartridge swap doesn't work, contact Lexmark to fix the unit.
Sep 18, 2014 | Lexmark P4350 All-In-One InkJet Printer
The front window on my lexmark P4350 allways says the cartridges are empty even when they are full please help
Are you still able to produce printouts? Try to re-seat the cartridges in the printer.
Please note that a refilled cartridge will not be able to report its ink level.
Oct 12, 2011 | Lexmark P4350 All-In-One InkJet Printer
My ink was showing low so i just bought lexmark combi ink from tesco L111 number 34 and 35 and yet printer is still showing ink as empty why is this printer is p4350 model
use the menu on the printer and select the printer options-> ink cartridge-> new ink cartridge and the ink meter should be reset.
Remember that the printer does not actually read the amount of ink in the cartridge it makes predictions about the ink levels based on the number of pages printed on the cartridge.
Jun 30, 2011 | Lexmark P4350 All-In-One InkJet Printer
I need to download the setup disc for my Lesmark P4350 granddaughter misplaced it put new refills in and it wont recognize have been using it only as a copier printer not hooked tyo computor
You can download and install the Lexmark P4350 driver by visiting the Lexmark website at http://bit.ly/bETkq1. Select your operating system, download and then execute the file. However, if your main problem is the printer not recognizing your cartridges, make sure you are using the correct cartridges for your model (Mono: 32, 34 and Color: 33, 35). You could try to re-seat your cartridges by removing it from your printer. Unplug and replug your printer into the power source to reset it. When the printer turns on, reinsert the cartridges properly. Hope this helps.
Apr 14, 2011 | Lexmark P4350 All-In-One InkJet Printer
Need black ink cartiage what is the number for black ink
Black ink for Lexmark P4350 are:
- #32 standard yield cartridge - #34 high yield cartridge
Thanks.
Feb 17, 2011 | Lexmark P4350 All-In-One InkJet Printer
We have a lexmark p4350. we cant get it to print
The error indicates an error in communication either between cartridges or the cartridges and the printer. Here's an article in the Lexmark website on 1203 Error Message on the Lexmark P4350 / P4330 Photo All-In-One. Just click on this link: http://bit.ly/9sK9hE. This should guide you on what to do.
Jul 05, 2010 | Lexmark P4350 All-In-One InkJet Printer
Shows 1203 error on lexmark P4350
Error 1203 is an issue that occurs either when a cartridge is bad or the printer cartridge Slot is bad...
1 - try cleaning the copper contacts of the both carts and cart slot in the printer and try again..
or
2 - when error shows up, shut the printers power off; wait one minute and turn it back on press copy.
Nov 01, 2009 | Lexmark P4350 All-In-One InkJet Printer
Cartridge error
i have a lexmark p4350 and just recently got a eror message 1102, says consult user guide, cannot find that error message in the guide, what is it, thanks
Sep 10, 2008 | Lexmark P4350 All-In-One InkJet Printer
Lexmark P4350 AIO incorrectly identifies cartridges, will not allow printing
Some times refilled cartridges works fine,and in Lexmark cartridges
they do not support refilled onces ,Try a new compatible cartridge it should print ..
Feb 12, 2008 | Lexmark P4350 All-In-One InkJet Printer
Lexmark P4350
I am also experincing this problem after refills. Older Lexmarks you had the control to tell machine it is a new cartridge.Had cartridges refilled in stores deticated to doing nothing else but refilling new ink.Still will not read full??Have no idea as to what to do.
Mar 30, 2007 | Lexmark P4350 All-In-One InkJet Printer
Lexmark P4350 All-In-One InkJet Printer Logo
22 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
