Back to:
Tags:
Lexmark X7170 All-In-One InkJet Printer
Thick marks on photo paper
posted by javidalgo on Aug 31, 2008
When I print pictures using photo paper, they come out with a longitudinal mark (like if one of the rollers were pressing the paper too much). The mark is always in the same side (center-right). I opened the rear door and I think it is coincidental with a sort of retractable device that presses the paper as it comes through. Apparently it doesn´t seem to apply pressure when the door is open, but it looks exactly in the position where the mark shows in every printout.
For normal paper it is not that obvious (nor important) as in a photo.
I have the same problem Post a new problem
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Solution #1
posted on Aug 31, 2008
Not Rated (0)
Carrieone
Rank:Apprentice Apprentice
Rating: 70%, 1 votes
You don't say whether the mark is a dent/dinge in the paper or whether it is a dirty or inky mark. If it is one of the rollers pressing and making a dinge in the paper you need to check for flat spots on the rollers. Do check all the rollers as the problem may be caused by another roller not gripping properly or the feed rolls being twisted therefore the one where the dinge occurs is over compensating. You can get rid of small flat spots or shiny bits on the roller by GENTLY roughening the roller feed wheels with a fine emery board. This will also clean off any dirty marks on the roller. You can clean dirty marks off the rollers with a non-lint cloth/specialist wipe. (I use baby wipes). Make sure you get rid of all the dust, as this will cause more marks. Clean the platten glass, again with a glass wipe or windowlene to get rid of any marks there. It is also worth taking out the catridges and wiping the ink surfaces. I use kitchen roll and the a baby wipe. Do test the baby wipe first to make sure that it does not damage the printer. If it is possible without taking the printer to pieces wipe the cartridge feed bars. I use a oil based specialist wipe fro this. Another thing that could cause the symptom that you describe is a piece of debris/stuck paper in the feed path. So check that the path is completely clear. You would be amazed at the impact of even a tiny scrap of paper stuck can have.
If you printer has a clean cartridge utility, do that for both cartidges and run the alignment routine before using the printer again. Print a test page to check that you have got rid of all the marks.
Good Luck Please send me feedback so that I know that this fixed the problem.
Carrie
Was this solution helpful? Show your Appreciation by rating it:
Thank You!
Was the solution helpful?
Show your appreciation by commenting on Thick marks on photo paper:
I don't want to Accept this solution
Can you Help with these Printers problems?
Our home phone and fax are on the same line. Is there a...
I put a brand new Lexmark 34 cartridge on 23rd October...
will not print envelope at all
(When printing of making copies only) Prints are too dark...
I used to pull my faxes off my voicemail with my computer...
Loading problems.
Repair Service
Prescreened Contractors
Get Matched to Prescreened Computer Professionals
Category
Zip code
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
