I have bought an acer t180 with windows vista from a mate and would like to reset it back to factory settings as it is really slow and has alot of programs that will not uninstall properly, but i can not find and option to reset it in the control panel, i do not have a windows vista disk
    President:
  • 2,961 Answers
Acer do not supply backup discs, when the unit is purchased your mate would have been pompted to do a backup disc using the supplied software, which then leaves a file on another partition to be used in conjunction with the backup cd,s.
lll you can do is uninstal all unwanted programmes and clean up the system using Ccleaner which is free to download and cleans all temp files and old registry entries.
You may also have trojan or virus, so run your antivirus programme to scan the system.
Posted on Aug 31, 2008
I have an Vista running Acer Aspire t180 desktop that i bought in 2008. i would like to restore it to its factory settings but i have misplaced the restore disks and Alt-F10 does not work. My eRecovery was...
Your options are either go to Acer for a replacement Vista recovery DVD or
Install a borrowed Vista DVD, must be same Vista Basic, Home Premium,
then use your registered CD key, normally located on the side or rear of your tower.
It will also tell which Vista type you have. You then must go to the Acer support site
and install then drivers for the componenets in you computer.
You will not have any other software installed that may have come with your
original setup from Acer. This option requires more work on your part, but
no cost to you. Acer will charge for a Recovery DVD, plus S&H.
Aug 24, 2011 | Acer Aspire T180 PC Desktop
Need to reset my acer computer to factory settings.
Hi! Try system restore first and check if that will remove the virus but if not then you can reset the machine to factory defaults by pressing ALT+F10 during start up or when the acer logo appears on your screen.Follow the prompts and you should be able to reset the computer to factory image.Make sure you back up important files because it will wipe the system clean.hope this helps...
May 29, 2010 | Acer Aspire™ T180 PC Desktop
I tried to upgrade my acer t180 to windows 7 from vista basic, no i"m having dmi problems... seems like it's stuck... help please
Hello kelajo34,
There might be a Desktop Management Interface (DMI) compatibility problem with Windows 7 and the Acer T180 Vista Basic DMI. The Acer support Windows 7 eligible systems link shows all the Acer computers that are fully compatible with windows 7. (Acer T180 is NOT in this list !):
http://www.acer.com/windows7upgrade/eligible.html
Also, It might be a good idea to run the Windows 7 Upgrade Advisor before upgrading from vista basic to Windows 7 on the Acer T180. The Windows 7 Upgrade Advisor download link is at: http://www.microsoft.com/downloads/details.aspx?FamilyID=1b544e90-7659-4bd9-9e51-2497c146af15&displaylang=en
If this solution is helpful please click a thumbs-up rating below.
Have a great day,
martyshaw152
Jan 30, 2010 | Acer Aspire™ T180 PC Desktop
WILL not resetting to factory settings
You will need to burn a Recovery CD / DVD set from the icon located on the desktop/ In your Acer Home Start utility (The window loading at startup) or from the Start Menu.
Using this disk you will be able to do a System Restore back to original factory setup.
Apr 14, 2009 | Acer Aspire T180 PC Desktop
Acer t180 boots to erecovery
Borrow any Vista install DVD and boot from it
Follow it through until you are asked if you want to install Vista or Repair your Computer
Select repair and let it do its thing - it may work
Failing that its a full reinstall by the sounds of it
If it does not offer you the initial boot option then look on the boot screen for the boot options key - probably F11 or F12 - and press that during initial boot to obtain the boot options screen
Dec 19, 2008 | Acer Aspire™ T180 PC Desktop
How do i fix my acer windows vista computer
I wiped out my Acer Aspire T180 , bought the system and recovery disc from Acer but after loading them it starts to load windows vista little bar goes across with the green in it then the vista backround then a box will pop up saying , there was an unexplained error and windows restarted unexpectedly so you need to restart windows now but then get the same box all over again. HELP !!!!!!!!!!!!
Oct 18, 2008 | Acer Aspire™ T180 PC Desktop
Missing Vista home basic product number
Acer gives you the option to create your own cd's. Click the start button & go to all programs. Look through the programs installed. Someting like DVD pro. or nero. There is a program in there so you can creat your own set of restore cd's. The reason your PC is so slow is because Acer loaded the system up with a ton a junk you'll never use. (Can always return it). I would befor the warranty runs out.........
Good Luck!
Mike
Mar 29, 2008 | Acer Aspire™ T180 PC Desktop
How do you reset Acer Aspire T180-GB7Z PC
Perform a system recovery:
Does not come with recovery cd's - there is a program that allows you to burn the disks or
recover.
3 ways:
1. If in Windows - Start - Programs - Acer empowering technology - Acer E-recovery management -
click on Restore at bottom then "Restore to factory default settings"
2. Or click on Burn disks instead of restore
3. if unable to ge into Windows then Alt/F10 during boot right after Acer splash screen on startup
End User Technical Support and Service (USA only)
For end user technical support, spare parts and service: 1.800.816.2237
Dec 30, 2007 | Acer Aspire™ T180 PC Desktop
Restoring acer aspire to its factory settings
From Acer customer support:
1 Ensure all Data is backed up, all data will be deleted.
2 Restart machine
3 When your unit switches back on hold down alt & tap f10 repeatedly...(on Acer icon)
4 Please wait a moment until prompted, -How would you like to restore?-
5 Please select –Restore system to factory default-
6 Enter your defined password or enter six zeros ‘000000’
7 Click ok
8 Please wait until process completed, this will take 45min – 1hour
Oct 03, 2007 | Acer Aspire 5100 Notebook
What do you mean, "Reset"? Do you mean like restart it or like reinstall windows with factory defaults?
Aug 18, 2007 | Acer Aspire 3680 Laptop
Computers & Internet Logo
44 people viewed this question
David Payne
David Payne
