Question about Sony Vaio P VGN-P530H Netbook
Once open no display on screen but it is power on already there a light on power button and the fan is running but nothing comes up on screen.it was only 4 mos and it was bought in CUBA.please help me fix this problem.one time when it was on the screen appears different color and it was shaking and it was always hang.
2 Suggested Answers
spike888ph
  • 77 Answers
SOURCE: occasional colored vertical lines on the screen at startup
base on our experience.... you are looking at a possible screen problem. Is it serious? yes as the screen replacement costs almost half of the total cost of the laptop.
but no harm trying this
1. remove the screws from the LCD bezel, remove the screen
2. detach the cable and reinsert them all both the inverter and the flex cable.
inverter is the circuit usually located at the bottom of the screen and the flex cable is the ribbon that runs from the laptop to the back of the lcd.
reseat them and see if your display improves
Posted on Apr 09, 2008
Black screen no fan sound but apparently getting power
for solve any type of error and issues dial toll free number +1(800)726-0294
and for more visit - 1 800 726 0294 Apple Support Number Mac Technical Support Help
Sep 10, 2017 | Apple PowerBook G4 Mac Notebook
Computer won't do anything, keyboard does not light up, screen is blank
So there is not so much as a BIOS message on screen? Any beeps?
If there is no life at all, you have a CPU/motherboard failure. This may be direct or indirect (e.g. no power to MoBo). Check your connections.
Otherwise, your boot device may not be operating. This is usually a dead or disconnected HDD. Check that it is plugged in. Does it get warm? Can you feel any vibrations from it? It should spin even if your cpu is dead but MoBo is alive.
Oct 26, 2012 | HP Compaq Presario SR2038X PC Desktop
Compaq Presario C300 beeps 4 times
Sounds like a GPU issue. That will require professional help of a specialist nature. The GPU has probably been run too hot and unsoldered itself.
Apr 15, 2012 | HP 435768-001 - Compaq Presario C300...
My sony vaio vgn fs790 would'nt start up all it does is light up all of the three lights located near the power button and the lights near the battery indicator too, and they stay on. then it...
It sounds like you may be having a video related issue. These issues may indicate that you have a problem with either your video card or your lcd screen. To isolate the issue, you have to connect an external monitor to the VGA port of the portable system. There should be an S2 button on your laptop which should allow you to switch videos. Press that and if the video appears on the monitor, then it is an issue with the LCD screen. If nothing happens, you have a video card failure. These are due for replacement already.
Jul 02, 2011 | Sony VAIO VGN-FS790 Notebook
Wifes Acer laptop screen went black, power light is on, fan is running, but nothing comes up on the screen.... We're stumped...
If you reboot it and everything seems normal except there is no display, get a flashlight and examine the screen for a display with no backlight. Maybe it is just the back light power supply that has failed?
Hope that helps.
Jan 15, 2011 | Acer Computers & Internet
Dell Dimension E510 Wont Boot up. PSU is working 100% CPU is working 100% Ram is working 100% Disconnected all other hardware. No Power On Light. Light on Motherboard is green. Once you plug in the PSU...
Hi
With that scenario i would recommend you check the front panel assembly where the power button is located and also have you tried to reset the CMOS from the motherboard.
Dec 29, 2010 | Dell Dimension E510 PC Desktop
I have a Toshiba A350D-S6848 laptop...when i hit the power button all the lights come on fan running, dvd drive running, hdd running, nothing on monitor
Try attaching an external monitor to the laptop & see if you could get any display on it. If this is successful, then you might have either a faulty LCD cable or screen inverter board.
The LCD cable transfers data signal from the motherboard & video card to the LCD screen. It also supplies high voltage DC power to the screen inverter board. The screen inverter board works as a power supply for the backlight lamp mounted inside the LCD screen. It converts low voltage DC power to high voltage AC power needed for the backlight lamp.
Sep 15, 2010 | Toshiba Satellite A305D-S6835 Notebook
When I hit power button on computer, power light doesn't come on...and the fan kicks on, but nothing else happens. nothing shows up on monitor except the test screen with 3 colors...the computer doesn't...
THis sounds like a power supply issue.. I had a similar issue with mine. my fan would kick on for about 2 seconds then shut off.
Hope that helps
Ciza
Oct 29, 2008 | Gateway (4000274) Motherboard
Ps3 light on but freezes
Hey ok wait a sec so nothing is displayed on the screen?
Does it power off or down?
Ok it sounds like a simple setting error..
Turn system off then on and let the red light show up.
Then push the power button down for 5 sec and/or wait until it beeps.. it will reset itself and turn back on.. still nothing? do it up to 10 times and let me know if this is not the issue thanks!!
Jun 27, 2008 | Sony Playstation 3 (PS3) Console
Sony Vaio P VGN-P530H Netbook Logo
89 people viewed this question
Top Sony Computers & Internet Experts
Alun Cox
Computer Links
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
