Question about Bosch Classixx WVF 2402 Front Load Washer/Dryer
Enquiry Hi, can you please send me a catalogue for using ARISTONE washing machine model AF552t/1 as I don't know the functions of each programme &how to do(fix) it
  • abdelmotaal Aug 31, 2008
    I' ve found my favourite helping site which is really trustful
Dear Abdelmotaal, Please give me the Brouchure of Washing Machine (Ariston AF552T) Function also.
Thanks
m_hashir@hotmail.com
Posted on Oct 13, 2010
Zanussi dishwasher ZDF601M 1 in 3 red light comes on and programme doesn't work through
26269906-aipk5px1bmfkdpsmrgevaqwn-3-0.jpg "3 in 1" function
This appliance is equipped with the "3 in 1" function, that
allows the use of the "3 in 1" combi detergent tablets.
This function can be selected with all washing programmes.
With the selection of this function the inflow of rinse aid and
salt from each respective supply container is automatically
deactivated and also the indicator lights for salt and rinse aid
are deactivated.
Select the "3 in 1" function before the set of a washing
programme.
Once this option is selected (indicator light illuminated) it will
remain active also for the following washing programmes.
With the use of the "3 in 1" function, the cycle durations may
change. In this case, in the digital display, the indication of the
running time of the programme is automatically updated.
NOTE: Once the programme is running, the "3 in 1" function
can NO longer be changed. If you want to exclude the "3 in 1"
function you have to cancel the programme setting (see
chapter "Starting a washing programme" - "Cancel a washing
programme in progress") and then deactivate the "3 in 1"
function.
In this case you have to set a washing programme (and
options) again.
Activation/deactivation of the "3 in 1" function
(The dishwasher must be switched off)
1. Press the On/Off button. The On/Off indicator light
illuminates (setting mode).If a programme button indicator light is on, this means that a washing programme is set. The programme must be cancelled: press simultaneously function buttons 2 and 3
for about 2 seconds. All the indicator lights will turn off (except for the On/Off indicator light and eventually salt and rinse aid indicator lights) indicating that the set programme has been cancelled and the machine is now in setting mode.
2. Press simultaneously function buttons 2 and 3, until the
indicator lights of function buttons 1, 2, 3 and 4 start
flashing.
3. Press function button 4, the indicator lights of function
buttons 1, 2 and 3 turn off while the indicator light of function
button 4 goes on flashing.
4. Press function button 4 again, the "3 in 1" indicator light
illuminates, indicating that the "3 in 1" function is active.
To deactivate the function press function button 4 again, the
indicator light turns off.
5. To memorise the operation, switch off the dishwasher by
pressing the On/Off button or wait about 60 seconds after
which the dishwasher will automatically return to setting
mode.
Dado
Aug 29, 2016 | Zanussi Dishwashers
How to get Brother sewing machine apart to replace spool spindle.
To be honest the best thingon such instructions is the manual which is provided along with the machines,but many people don't have it , probably because they have lost the manual orthey have got the machine as a used one and forgot to take the manual alongwith it.
Please follow the belowinstructions :-
Close to the end of theHandwheel , there is usually a spindle, at the back of the machine.
This is where you need to restthe spool on and you would notice it sitting perfectly.
In case the length of the spindleis less , then pull it up gently with your fingers.
Also there are machines these dayswhich have easy to replace facilities , so the spindles just slide intothe machine for safety norms when you put the machine away.
Therefore , all you need to do it pullit up and it would be fine.
An example of a manual forbrother's sewing machine can be found in the below link which would give you anidea of how exactly it's done.
http://bit.ly/j2BdsP
Hope this helps ..:)
Jun 11, 2011 | Vacuums
Machine does not stop filling with water and over flowed nor did it start washing
It sounds like the water level sensor switch is not functioning, until it does operate, then the washer will not ncommence it's programme.
I cannot help you further without knowing the make and model of washer, can you please confirm this ?
Thyankyou.
Mar 25, 2011 | Whirlpool Washing Machines
Please send me the user guide for Gorenje WA 61101, via email. Especially the programmes and the use of all buttons. Urgent!
Hi and thanks for choosing FixYa, I am Kelly
I understand why you came to use in search of your manual. It was quite a task locating a manual for you and the WA61101 does not come up anywhere. I did find a manual I think you can use. This is NOT the exact manual but the WA6xxxx series appear to all use the same instructions. This manual is under the WA60125 model. Let me know if this does NOT work for you or if it does work for you. If it does not work for you I will search again. This search took about 1 hour.
Thanks for choosing FixYa,
Kelly
Feb 15, 2011 | Washing Machines
Loola wheels were can i purchase them from,i have been told that dorel sells them,but when i go on the website it wont let me download the catalogue.
As you would not be able to purchase these wheels through the catalogue (spare parts are not in the catalogue) I would suggest that you contact the email address below or telephone number. Please note that this is from the Maxi Cosi website as the Loola is now branded such and is based on a UK enquiry.
Customercare@uk-dorel.com
01842767965
I hope this helps.
Sep 18, 2009 | Baby Gear
Asking aquestion
Please explain in some detail.. the wiring that was done and the power system in your house ( meaning ..what type of receptacle do you have and and what voltage is the washer set up for 220VAC etc?) I may be able to assist if I have more information... Also.. what actually burned that caused the fire? ( the cord, something inside the washer... please elaborate on that)
Aug 28, 2008 | Ariston Technologies Ariston AWD12 Front...
Simpson 175 HD washing machine Programme keeps stopping Is it the timer or some other problem
image_bubblequestion_04.gif Can you please identify the problem with my washing machine?It appears all the functions of my simpson 175 washing machine work normally except the agitator only moves briefly and harshly for between 1 and 2 seconds.
Simpson 175 HD (Dual Action Agitator) Washing Machine.
1517 5M40 A 28 June 1990
Jul 12, 2008 | Washing Machines
Washing machine was running and stop inbetween rinse cycle and water pump got spoiled ihave already replaced with new pump but it is stuck on continuing programme and do not function at all. it only...
There's no way to properly help anyone with "Generic problem for all Washing Machines" as a topic heading. When posting problems please be more specific. Provide a clearly worded problem including the complete model number
Feb 07, 2008 | Washing Machines
My washing doesn't smell clean? Help
the drain water pump its not working properly , needs to be cleaned the drain hose needs to be check for posible bent or clogged , ,please be sure that the drain hose ,and drain pipe are installed ,no more than 12 inches above .of the machine, and avoid long hoses. let me know thanks
Jun 20, 2007 | Whirlpool AWM5145/2 Front Load Washer
Bosch Classixx WVF 2402 Front Load Washer/Dryer Logo
102 people viewed this question
Top Bosch Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
