Question about VAX Appliances Vax X5 Bagless Upright Cyclonic Vacuum
How to change carbon brushes in Vax 2000
Since new carbon brushes can be bought for a Vax 2000 (e.g., here) then I guess they can be replaced. Can you give me any tips on how this is done. I've opened up the motor unit and can see the carbon brush units. They seem to be retained by a brass housing. Do I just bend parts of the brass housing until the brush can be withdrawn, or is there some clever way to release the brush and/or housing?  Simon
  • doncheyne Feb 07, 2009
    I have the same problem, after bending back the tabs the brush still cannot be withdrawn.
    Is it possible to remove the brush holder complete?
  • manojcc
    manojcc Feb 28, 2014
    thanks for your help in changing Carbon Brush
Bend back the three tabs and cut off the contact wire as close to the top tab as possible. You can then pull the brush (or what is left of it) out. The new brushes have a brass plate the same size as the brush opening. The connection wire that you cut away on the original brush is attached to this plate so you don't have to solder the connection. Push the new brush into the holder (you might have to file the carbon slightly to get it in). Then you have to compress the spring so that it all fits into the brush holder (this is difficult) once this is in keep the sping compressed with a small screw driver or other small tool, and bend the three tabs back over the brass plate to hold it in place. This is tricky but can be done.
Posted on Mar 31, 2009
Vax 2300
If the roller brush cannot be rotated easily by hand, it is likely that debris is jammed inside the end caps.Make note of the direction arrows on the end caps as you remove the roller brush. You will need to know this for reinstallation. The end caps are fastened with stop nuts. Removal of one will allow the inner shaft to be extracted for examination and cleaning. An old toothbrush is a good cleaning tool. Reinstall the inner shaft and stop nut. Check for free rotation of the brush roller. Place a new belt over the brush roller and reinstall the brush roller, being careful to observe the position of the arrows on the end caps. Inspect the motor shaft and remove any old belt residue before installing the new belt on the shaft.
Jun 30, 2013 | Vacuums
New carbon brushes making popping noise
the brushes aren't making a good contact or are loose in the mount
Aug 25, 2012 | VAX Appliances 2000 Canister Vacuum
My vax rapide xl ultimate v-027y brushes not working..new belt fitted and same problem
hello i have a vax rarid xl carpet cleaner when you switch power on just makes a buzzing noise can you help thanks
Jul 15, 2012 | VAX Appliances Vacuums
Hi i have a vax swift complete 1800 watt,it is not picking up and the brushes are not moving they are also tough to move by hand what could this be
Possibly brush needs to be removed , cleaned , brush bearings lubricated, and new belt or oring belt needs to be fitted.
Dont do it yourself unless mechanically minded.
Ring up vacuum cleaner place.
Sep 12, 2010 | VAX Appliances Vax X5 Bagless Upright...
"CHANGING CARBON BRUSHES ON A DYSON VAC"
Solent Tools have a full range of Dyson brushes available. Tel 023 8057 8057. www.solenttools.co.uk
May 25, 2009 | Dyson DC07 Animal Bagless Upright Cyclonic...
Vax 2000 trips electrics
Try the reset drive belt brush button - you'll find it underneath the main power switch on the handle. Also check the brush isn't clogged, by the sole plate by tipping it over and undoing the screws on the bottom place where the beater bar is.
Apr 11, 2009 | VAX Appliances Vax X5 Bagless Upright...
HOw to change the Belt on a Vax VX1 Model
There is a brush reset button on the handle. Check to see if this has been pushed in. Also check to see that the brush slider has also been switched on. Usually belts are protected on this model but you should be able to remove the bottom sole plate where the base of the vacuum is (and beater bar). If the belt cover can't be removed then it has to be repaired professionally.
Mar 24, 2009 | VAX Appliances Vax X3 Bagless Upright...
Vax 2400 performance pet overheating
Unfortunately there is no permanent solution.It is a terrible vacuum cleaner and im getting rid of mine today. I have been maintaining it for 6 months cleaning filters , swapping filters, swapping carbon brushes all to no avail.Dump it. it would'nt **** the air out of a balloon.
Jan 29, 2009 | Bissell 9500 ProHeat 2X CleanShot Upright...
Reverse operation
You probably have a clog in either the dirt inlet down by the brush roll, or the hose itself is clogged.
Feb 18, 2008 | VAX Appliances Vax X5 Bagless Upright...
VAX Appliances Vax X5 Bagless Upright Cyclonic Vacuum Logo
1,238 people viewed this question
Top VAX Appliances Vacuums Experts
seanwalters1
Level 1 Expert
Tom Chichester
Are you a VAX Appliances Vacuum Expert? Answer questions, earn points and help others
