Question about DeLonghi EAM3500 Espresso Machine/Coffee Maker
Coffee Grinder on the EAM3500
Coffee grinder is not grinding coffee. Sounds like gears are slipping and not meshing together. Makes very loud noise and then says "fill beans container."
  • 3 more comments
  • runeel Dec 28, 2008
    Did you solved the problem?
  • Anonymous Mar 22, 2014
    Used grinds are loose after brewing. Machine no longer makes pressed used pucks. Instead of filling the receptacle, the grinds go all over the inside of the machine.
  • Anonymous Mar 24, 2014
    delonghi magnifica starts to grind then makes a clicking sound and dosent grind sounds like gears slipping?
    delonghi grinder grinder not working sounds like the gears are slipping ?
  • Anonymous Mar 25, 2014
    Loud Grinding sound after brewing
We just went through the same situation. We opened the top the Magnifica to get to the grinder and removed the four screws to seperate the grinding pieces. Inside we discovered two black fosilized beans/stones! We removed those, cleaned out all the bean dust and it is working like new! Took about an hour.
Posted on Dec 28, 2008
I have a Breville BES860XL and the grinder is not working. If i overide the interlock, It will spin, but does not have enough power to grind beans
It seems there's a fault in the grinder gearing in this particular model.There's no solution but to take it to Breville repair...
I have the same problem and so does a friend of mine. The grinder will spin without beans in the hopper but as soon as beans are introduced the grinder makes a loud noise. Like the gears are slipping and there's not enough power to grind.
Jun 10, 2011 | Breville BES860XL
The machine makes a very loud noise when grinding the coffee beans. * Magnifica Espresson Machine *
Even a properly operating super automatic DeLonghi espresso machine makes enough coffee grinder noise to scare your pets and wake you next door neighbors. It's LOUD, no doubt about it. Only if your grinder makes more noise than that do you have a problem.
Jun 23, 2010 | DeLonghi Esclusivo Magnifica ESAM3300...
Rock stuck in grinder. just spinning noise when it
It is not a healty sound,seems either the gear cogs slipped or the plastic base that holds the lower blade of the grinder is broken.
Jan 02, 2010 | Saeco Talea Giro Espresso Maker -...
Machine has major problem with grinding beans.
Try removing all beans from bean holder - then use a vacumn machine to remove the bits down amongst the grinder "teeth'. You may have had a small stone in your coffee and if so it may have jammed the grinder.
Once it looks clean, try making a cup of coffee without the beans in the hopper - you should be able to see and hear the grinder revolving and also hear the brew unit moving between the grinder outlet and the water inlet. If it all seems ok now, then add a small amount of beans back into the beans hopper and try making a coffee. If it still will not work, get it serviced. There's not much the average person can do inside these units other than to do more serious damage or kill themselves with an electric shock.
Nov 05, 2009 | Saeco Magic De Luxe Espresso Machine
My Bunn Grinder sounds like it is jammed. I have power but no mov
First turn grinder to coarse setting and try grinding some white rice through it, that will clean out the coffee oils, if that does not work then the you will have to open the grinder and clean out the burr chamber and the spout for the grounds.
Apr 21, 2009 | Bunn Coffee Grinder
I just got a used Rocky grinder. It works great but I read about
the grinding itself makes noise. if you have noise in empty spinning than you should consider changing bearings( 2 of them) in the motor.
during opening grinder pay attention to lower holder of burr which spins together with axis, try to be gentle with that part.
Jan 31, 2009 | Rancilio Rocky Espresso Coffee Grinder -...
Coffee machine will not grind the coffee beans?
Since your grinder makes noise and the problem occured suddenly, I would rule out a grinder problem. I am guessing that your grinder runs 10-20 seconds before it stops. If that is the case you need to look for a obstruction in the grinder or a failed microswitch on the doser. Either of these could cause the problem.
Dec 13, 2008 | Saeco Vienna SuperAutomatica Coffee...
Grinder is slipping.
  1. take out bean container
  2. disassemble 3 philips screws and take plastic out
  3. rotate the knob to try to get out the upper holder of burr. if it does not rotate than disasemble the knob and the gears(plastic big one is attached to upper holder of grinder, the other is together with knob.
  4. tru to rotate it manualy, with help of extra srews puted in gear holder holes.
  5. when you get it out, carefuly clean it, look for metal parts and stones(wich sometime comes with coffee)
  1. turn on the grinder and attach gently one marker to lower burr during spining. after you stop grinder, look if it is perfect circle marked in burr. if it is not than marked side is higher. you should consider getting it ok by putting adhesive paper under lower burr and check it again.
good luck and carefuly.
Aug 02, 2008 | Gaggia MDF Coffee Grinder
Coffee will no longer grind.
Aug 21, 2007 | Cuisinart DGB-600 Coffee Maker
DeLonghi EAM3500 Espresso Machine/Coffee Maker Logo
1,819 people viewed this question
Top DeLonghi Coffee Makers & Espresso Machines Experts
Shehu Pro
Shehu Pro
Michael Vincent Cruz
Are you a DeLonghi Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
