Question about Cell Phones
Phone dead I installed RSD Lite V4.0 to flash my Motorola Raze2 V9 phone to its original setting sand remove network software. I did all steps according to instructions. Now my phone is completely dead. I cannot get it to work. It is stuck in Bootloader. Please help as I have only had this phone for a couple of weeks.
  • kkolowitz Nov 27, 2008
    hey ma too!!!! my phone was working fint at first but then it just froze. i took the battery out and put it back in then tried to turn my phone back on but now its stuck loading!!!! HELP!!!!
  • 4 Answers
Pressing 'power' and # and * at the same time will start the phone in this boot mode. It is used for preparing a phone for new software to be uploaded. If your phone is doing this the software is probably corrupted and you will not be able to recover. You may be able to have it flashed with new software at the store.
Posted on Dec 31, 2008
SOURCE:
I installed a program called RAD Lite V4.1 to flash my Motorola Razr2 V9 phone to its original settings. I ran the program without incident and it stated that it was ok. Thge problem is that my phone is...
plz charge your phone for some time and try to boot. if the problem persits then you contact your vendor they will help you as your phone is under warranty
Aug 31, 2008 | Cell Phones
Tip
Flashing motorola phones without a battrey
if you have a dead battery and you want to flash your Motorola phone and you cant do that cause your battery is dead . well i have a solution for you guys . all you need is all usb cable and Motorola rsd lite 3.7 or better now. OK no battery needed remove the battery , on the device hold down the # * buttons than plug in the usb while holding the # * and that should put the device on flash mode that hit start and let the phone flash itself and after its done passed flashing go ahead and insert your battery on the phone and let it charge by it self , easy trick and a tip for the flashing software guys ........good luck from ...rymi1982
on Jun 17, 2010 | Cell Phones
My mobile display was problem. i want to touch my menu icons its not working. how to solve this problem?
You need to update your handset firmware-rokr-e6. to update your handset..
  • First you need to install your motorola phone tools ....
  • Go to the option live update.......
  • Download the software named [Motorola_Software_Update]
  • Backup your contacts and open your SIM&SDcard....
  • Then Using Motorola_Software_Update go through the stapes..
If thats not working
You have to Flash your firmware-rokr-e6.........
  1. Install the Motorola_Software_Update.....
  2. Download the software named RSD Lite........
  3. Download any firmware-rokr-e6 as you like.........
  4. Backup your contacts and open your SIM & SDcard....
  5. Turn off your Motorola ROKR E6 Smartphone when its battery will be fully charged
  6. Tap and hold Your Power +Camera key for 3-6 seconds when it is connected to your pc.
  7. At last brows the firmware-rokr-e6 and press the button start on RSD Lite.......
  8. Do not dis connect your phone from your pc...
If the RSD Lite can not show Device the flashing can not be finish....
You have to wait for finish the Flash method
Dec 01, 2010 | Motorola Mobility ROKR E6 Smartphone
How to get flash mode off a phone
How to fix Motorola Flash Mode Of Death To do this you must have a fully charged batery, i know when your phone is stuck in flash mode you cant charge your battery so your gonna have to buy a new one or try to charge the battery i another phone.
First download Motorola RSD Lite 3.2 from here http://www.cpfxwireless.com/downloads
Then download the Monster flash file from here http://www.cpfxwireless.com/downloads (Same place i no)
Then extract your monster flash file, save it to somewhere on your computer.Plug in your phone when on motorola flash mode .Open RSD lite , find your monster flash file wherever you saved it then click on start. You can always use the Motorola Software update , but i already had the latest software on my phone so there was nothing to update
Jun 29, 2010 | Motorola Mobility MOTOKRZR K1 Cellular...
Sir, i m using moto rokr e8. i wanna know how to install aircel gprs? The prob. is whenever i tried to install gprs settings it failed and the message ''profile update failed''. Plz tell me the procedure...
Well the problem seems due to some firmware issue, might be the firmware is corrupt. first of all you can try to reset your phone to the factory default settings....... If further you have the same problem then you can try updating the firmware on your phone, follow the below steps to know how to update firmware -
1- You 1st have to have the motorola phone drivers installed on your computer. Get them here: http://data.mofan.mobi/index.php?dir..._32_v3.5.0.rar
2- Then plug in your phone with a cable and let the computer recognize your phone.
3- Unplug and go main menu-connections - usb settings-change this to modem (I keep mine set like this)
4- Download and Install rsd lite- I use version 3.9. Get it here: http://data.mofan.mobi/index.php?dir...D_LITE_3_9.rar
5- Now plug your phone back into your computer. Wait about 30 seconds so the computer recognizes your phone again.
6-Now start rsd lite. It will eventually recognize your phone. Wait 30 seconds. It will show up in the bottom window.
7- Now find where you downloaded the flash you wish to install.
Click the ... next to filename window to search your computer.
8-After you highlght the flash (the file ends in .sbt)
Click Start.
9- Now wait. It may take 5 to 10 minutes. make sure the result says PASS before you disconnect your phone.
10 - Close rsd, reboot your phone and you will be all set. Your phone is now using the new flash.
Good Luck!!
Mar 21, 2010 | Motorola Mobility ROKR E8 Cellular Phone
No. i need to unlock my motorola razor v3 for
My friend gave me a razor to unlock last night that he just bought from a long time user on Cingular network. Since I unlocked without trouble I thought I would help someone out. Basically you need to flash one software into your phone, then you need to run another program and unlock it. Here is how I did it. Download and install EMULE, a free program. Run EMULE and select edonkey network only and forget KAD network during setup. Don't upload with emule in chunks as I believe it takes more processing power from the PC. Now run EMULE and click Connect. After it connects search for a program called P2K.EASY.TOOL. It will be around 6.2MB file. Extract all the files and look for a file called P2K_Easy_Tool_v39 and extract this also. Next, you need to get the program called RSD Lite 3.0. Again get this file by searching emule for this and downloading. Then install the program by double clicking on .msi or right click and click install. Now get the program Motorola_Unlocker_2005.zip. This can be found quicker at themotoguide.com/unlocking.php. This file may not be necessary or this step! CHARGE the phone to full charge. I forgot two more file are needed! You'll need to USB drivers for the phone. The ones I used were v3_drivers.exe (search yahoo) and always click continue anyways. Finally, you will need bl_826-828_to_07d0_ for_V3_by_Archy.V2.shx (no space between 07d0_for_) and this file can be gotten at themotoguide.com/unlocking.php. If you attempt to communicate with the phone it may want to install drivers and you may have to do the operation again. When installing drivers, just specify the folder where you extracted USB drivers. Now lets get started. Plug the phone into USB cable and turn on. Run the program called RSD Lite 3.0 and then it should say connected and show your phones IMEI #. If not, you could restart phone, but press # and * with one hand then start up. Now it should say in RSD LIte 3.0 something different. You can leave it like that or restart phone and then you should definitely see IMEI #. Now click on FILE in RSD Lite 3.0 and search for the file bl_826-828_to_07d0_for_V3_by_Archy.V2.sh… and click OK. Now lets downgrade the bootloader, click START. Wait tell it is done and finished at 100%. Don't even mess with the computer during this time or any cables. Turn phone off and hold down * and # on phone again and turn phone on into Flash mode again. It should say 07d0 now or be a blank screen, which is fine. Now run the program Motorola_Unlocker_2005, click send to phone. It will do something and your phone will reboot. If it is unlocked then you are done. If it didn't work as mine didn't with this step then turn phone off for third time. Again boot up in flash mode by holding down both * and # and turn on with other hand. It will be in flash mode with black screen. Now run the program called P2K_Easy_Tool_v39.exe and there is one other file in this folder called winscard.dll. Click on LOCKS and then select your phone model. Now select Unlock SP. Click on DO SELECTED JOBS. It should show the status above and will do some work, then reboot phone do some more work and power off, I remember. That is it turn it on and you are done. Lets sum this up on what is needed. EMULE, P2K.EASY.TOOL, RSD Lite 3.0, Motorola_Unlocker_2005.zip, bl_826-828_to_07d0_ for_V3_by_Archy.V2.shx. You could probably skip the Motorola_Unlocker_2005.zip step. If for some reason you destroy your phone! You have a 80% chance of recovering it by going to www.themotoguide.com/downloadfirmware.ph… and getting one of these three files, extracting it. Then flash it into your phone with RSD LITE 3.0. Do not do any of these steps if it is illegal in your country or you don't deserve to use your phone yet or buy talk time from a network!!
http://www.themotoguide.com/unlocking.ph…
Hoped it Help.....
Aug 01, 2009 | Motorola Mobility RAZR V3i Cellular Phone
I forgot my unlock code for my moto razr V3
your firmware is corrupt, the only way to revive your phone is re flashing it.Its hard to do, and by doing it wrong may damage your phone. To safely retrieve your phone is let the experts do it or go to a near cell repair shop and let them help you out,
if you want to do it your self, try this
first you need is a RSD lite program or flash and back-up to flash or reformat your Motorola,
to enter the bootloader
hold * then the # then power button, your phone will boot to bootloader, and you will see there the flash program of your phone,
start the program rsd lite or flash and backup
then connect it to your computer VIA usb, automatically the program will detect your phone,
i prefer that you first buck up your firmware by using F&B (Flash and backup) then use RSD lite to flash your Motorola,
RSD lite its much easier to use than F&B, but for safety backup first your firmware,
gudluck
Jan 16, 2009 | Motorola Mobility RAZR V3
Motorola l6i
gudluck
Aug 28, 2008 | Motorola Mobility L6 Cellular Phone
Motorola RAZR V3i Cellular Phone
hopefully when you where doing this you made a back up of your original firmware so you can just reload it using the RSD Lite
May 16, 2008 | Motorola Mobility RAZR V3i Cellular Phone
Cell Phones Logo
1,052 people viewed this question
Top Cell Phones Experts
Marvin
Marvin
Are you a Cell Phone Expert? Answer questions, earn points and help others
