Question about Zanussi Washing Machines
My zanussi fji1204 washer has stopped draining and is making an awful grinding noise. i figure the drain pump has gone and wanted to know how easy it is to fit a replacement and to understnad if i need the assembly or the bare bones pump.. i can find either a full zanussi assy. or an askol pump body only for this machine. many thanks. dvid
    President:
  • 1,462 Answers
Easier to replace the bare bones pump - held by 3 screws around the edge. fiddly job so be patient
Posted on Aug 31, 2008
Got an OE error, now it will not finish rinse and spin, sounds like it is grinding in the spin cycle and the timer is stopped at 27 minutes remaining. What is wrong?
The problem is in the drain system as what error code OE stands for.The grinding noise is coming from the drain pump. Loose change, hair pins and the likes can get into the pump filter and sometimes into the pump impeller causing a grinding noise during the spin cycle because the pump works while the machine is spinning. The pump impeller may also be broken causing the grinding noise.
Disconnect power then open the filter door on the bottom left of the cabinet.
Remove the drain plug and drain the water out completely into a shallow basin or the likes. Once drained, lay a piece of towel under the filter then turn the filter knob counterclockwise and remove it. Clean the filter and reach in the pump impeller to check it if blocked or broken. If cleaning the filter does not solve the problem, you need to access the drain pump assembly and check the pump particularly the impeller thoroughly. Click on the link below for the detailed procedure in accessing the drain pump assembly.
LG Front-Load Washer Drain Pump Access
Dec 30, 2010 | LG WM2277H Front Load Washer
My Whirlpool washing machine AWM6100 is weird. it washes no problems but when it comes time to drain there is an awful noise any idea? it does drain and spin its just the noise
you may have something stuck in the drain pump that is rubbing or grinding on the impellar wheel
check for any obstruction in the drain pump and the hoses that led in and out of the drain pump.if you do not find anything then you may need to replace the drain pump. as long as this noise only happens in the drain cycle.
Feb 09, 2010 | Whirlpool AWM6100 Front Load Washer
I heard a noise that sounded like it was grinding marbles and now it will not work and there is water in the washer.
Peggy,
“”I heard a noise that sounded like it was grinding marbles and now it will not work and there is water in the washer.””
With the washer not working do you have an error code to the LED display? Can expand on the washer not working?
Do you here the grinding noise in wash/agitate cycle when the tumblers are turning?
If so you need to remove the tumblers and see if there are any coins under the tumblers. See page 37 of the Service Manual.
The SM doesn’t call out the torx driver size required for tumbler removal it’s a #20 torx driver.
You can enter into Service Mode and empty the wash water with this process.
To pump out the excess tub water;
I would go to page 16 of the SM lower right hand part of page, Board Output Test and turn on the drain pump in service mode to pump out the tub.
Enter Service Mode by simultaneously pressing and holding the Enviro Plus and Spin Only keys for three seconds or the display reads “00”
Pressing the Delicates key will lock the lid. Now press the Presoak key the drain pump will turn on. Stop with off button or hit the Presoak key.
Rich
Jan 31, 2010 | Maytag Neptune FAV6800AW Top Load Washer
Washer won't drain. Makes grinding noise
check your water pump. there maybe something in it. If there is you may have to replace the pump
Nov 06, 2009 | Whirlpool Estate TAWS750PQ 27-Inch Washer
Admiral aav-1 makes loud grinding will not spin or drain
Hi, the drain pump impeller is damaged. you will need to replace the entire pump(drain) in this case.
You will hear this noise when the impeller become separated from the actual drive stud or, shaft.
Jul 13, 2009 | Maytag Atlantis MAV8551 Top Load Washer
After a grinding noise washer stoped..as if no power..does it have a reset button,,,won't drain
many of the Maytags have had a problem with the pump bearing. This is what it sounds like. Tilt the washer back. Look underneath and take the belt off. The pulley on the pump is metal. try turning with your hand both ways. If it grinds that is problem. Let me know if need more info.
May 23, 2009 | Maytag Washing Machines
Noise while machine is draining
Have you checked the pump filter- behind access door at front? If clear then bearings going out on pump; it would need to be replaced. Please contact me if you need further help or leave feedback if appropriate as that is how I get paid. Thanks for letting me help you!
Nov 30, 2008 | Whirlpool LHW0050PQ Front Load Washer
Whirlpool Duet Washer Making Loud Grinding Noise
not nesseccarrily your pump, possible you have a rear bearing going bad, which will sound as if a helicopter is coming through your laundry room. ( noisy pump can be the issue , honestly a better and cheapre problem to have) in order to determine if its apump problem you can remove the lower access panel and unplug the pump then start the spinn cycle, if it still loud the pumpms not hte issue.
Nov 20, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Frigidaire front washer has power but won't fill up, drain or go through correct cycles
You'll very likely have something caught in your drain pump. First set the washer to drain and spin. If you hear a hum or grinding noise and the water in the tub isn't draining or it's draining slowly you have something in the pump. If you take the rear panel off you'll reveal the drain pump at the right front corner or maybe middle on this model. if you empty all the water from your machine you can take off the spring clamp (this can be tricky) attaching the thick rubber hose from your tub to your drain pump. (you may want to have some old towels ready) With this off you can feel around for what's blocking the drain pump's impeller. You may want to take the screws out that secure the drain pump to the base and the other spring clamp that attaches the drain hose to the drain pump. Good luck!
Oct 15, 2008 | Frigidaire ATF6000ES Front Load Washer
Drain pump removal on Zanussi FJR1254 Washing Machine
not easy.suggest you disconnect pump and power up independently as an easy way to check if it runs
easiest way to remove pump - and its awkward - is to undo the 3 screws holding the pump to its housing
Jun 29, 2008 | Zanussi F1245W Front Load Washer
Washing Machines Logo
Top Zanussi Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Zanussi Washing Machine Expert? Answer questions, earn points and help others
