Question about Compaq iPAQ H3955 Pocket PC
IPAQ 3955 Won't Sync?
Here I go again. I still have not got this thing to sync. It synced as much as two weeks ago and won't any more. I have a IPAQ 3955 and when I go to Sync it gives me an error 604. It says it cannot start communication with the desktop computer due to critical error (Error 604). I looked under the help menu and nothing shows up for Error 604. If anybody knows what to go please reply. I have tried it several times. Thanks
    Master:
  • 425 Answers
I have an iPAQ 3955 and recieve the same critical error 604. I have upgraded to Active Sync 3.7 and still have the same problem. Have tried two different laptops (work/home) and different USB cables. Restarted (hard) the PDA seveal times and still can not connect. Any ideas what to try next? If I can't sync to Outlook the PDA is useless! Reply With Quote
Posted on Sep 12, 2005
    Master:
  • 425 Answers
Try uninstalling, rebooting and reinstalling ActiveSync on the host. If you haven't yet upgraded to 3.6, maybe upgrading will clear up the problem.
Axim x51v won't sync
Guys it's probably down other sync software on your system like phone sync, I had the same problem yesterday, sometime ago I had installed software for my HTC phone, check in add/remove programs & uninstall anything that sync with your computer, then reinstall activesync.
welshcob
Jan 03, 2013 | Dell Axim X51 Pocket PC
Ipaq h2210 won't sync with desktop
Usually the simplest solution with Microsoft software such as active-sync is to uninstall it and install it again from scratch. When you reinstall it will ask you what programs you want to sync with, your old PIM software has been lowered in priority in favour of Outlook because MS think everyone should want to use it, so it's often easier to start using Outlook as your main PIM.
Aug 13, 2007 | HP iPAQ H2210 Pocket PC
Ipaq 4700 active sync problems
i can try to help you , first are you using xp or vista ? and which version of active sync ? i found that after upgrading to active sync v4.5 my ipaq 4700 refused to sync , i have xp home , so by trial and error i learned several things , i tryed my usb cable in every usb slot i had , only to find some usb ports are more friendly to certain devices , for a lack of better terms , i deleted all partnerships in active sync , found that i needed to make sure active sync is not running on ipaq , go to settings / memory / running programs on the ipaq , stop all running programs , turn the ipaq off , then on the pc made sure firewall not locked , plug usb cable into pc , i leave mine in a port permanently , plug into the ipaq , it automatically turns the ipaq on , then i see 2 icons in pc system subtray start blinking , at that point i know sync is going to work , then active sync icon starts turning , lit up in green , and asks do you want to create a partnership , yes , follow prompts , and thats what has been working for me , now if i was to put the usb cable into a different port , no doubt it would give me grief , and the same thing with my phone and active sync , make sure active sync is not running on the device , sometimes i have to reset the unit , ipaq or phone , make sure unit is turned off them make the connection , give it a try .
Jan 02, 2009 | Computers & Internet
Ipaq 4100 problem syncronizing with outlook on new laptop
you are now using outlook 2003 , probably cache , this means all the email is on your laptop. when you sync it will sync all the email (thousands). initialise your ppc (back to factory default). set up the sync via usb cable. then sync via bluetooth . then you are fully sync. now setup an auto backup of your email data (daily). if after some time , you have sync problem again , initialise the ppc, restore from backup and you are back to sync (last full backup). try this , you will never need to do it all again.
Regards
David Ng
Sep 23, 2008 | HP iPAQ H4150 Pocket PC
HP IPAQ 2495
Try and reinstall the sync software in your PC. Check your cable if it is properly hooked.
Feb 12, 2008 | HP iPAQ hx2495
PC/PDA "connected" yet PC won't read PDA
Did you tried installing the ActivSync again, for Windows XP the version is 4.5, for Windows Vista is 6.0, Try installing the AS
Feb 02, 2008 | HP iPAQ H3955 Pocket PC
Outlook
Check the setting on the ipaq, go to ActiveSync and tools, options, server and make sure calendar, contacts and inbox are not selected here. Then, put the pda in its cradle and let it do a sync, it should change the settings on the desktop and the (sync status on device) should disappear. I had a similar problem and after de-selecting these, everything worked fine.
Aug 21, 2007 | HP iPAQ RX3715 Pocket PC
Calendar and outlook sync
Is ActiveSync set to sync only items from the last 2 weeks?
May 22, 2007 | HP iPAQ H2210 Pocket PC
Error message
This original question is so old it probably won?t help the original poster but instead is meant for anyone who runs across this in the future with a similar problem. If you haven?t already done so backup your data, remove any extra cards or plug-ins and do a cold-boot. If that doesn?t work the next step is to remove Active Sync and install the latest version from Microsoft. If that doesn?t help then the next thing I would try is syncing to another PC and then another cradle if possible. If the problem persists the only thing left to try would be reflasing the ROM.
Sep 11, 2005 | HP iPAQ H5555 Pocket PC
ActiveSync
try soft reset on your Ipaq and a restart of your PC.
Sep 11, 2005 | HP iPAQ HX4700 Pocket PC
Compaq iPAQ H3955 Pocket PC Logo
161 people viewed this question
Top Compaq Computers & Internet Experts
pankaj rautela
pankaj rautela
Alun Cox
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
