Question about HP Office Equipment & Supplies
I've installed my 6200 series printer and printed a test page but when i click on the icon on the computer it says "no HP device detected".
  • 40 Answers
I cannot print a document from my Asus eee pc 900 series using HP Laserjet 4L - it prints test page only. I also have Canon BJC-100 and it won't even print a test page from that.
Hi Sir/mam '' i hope i can help you with my idea ' as you said your HP prints the print test but not working to print any document '', so here we start on start menu then click my computer , as it opens you can be able to see your HP device icon , click HP then click print settings , set it to print using HP as default printer , because another instance it is set to print to image or print to file or print to email. . thank you
Jul 16, 2011 | Computers & Internet
NEW HP Photosmart C6280 All-in-One on Vista - Error Printing
Whats the error message and can you try the printer directly connected into your computer?
Also check what your computer says in the printer status -> start -> printers and faxes -> your printer.
Jul 05, 2008 | HP Photosmart C6280 Printer
My HP CP2025 printer will not print color text and color shading in Word. It prints color photos, pdfs, and paintbrush files, but will not print color in Word or Word Perfect.
I had this problem on Windows 7 64x.
The solution that finally worked for me:
1. Go to your Devices & Printers window. (from the Start menu)
2. Right-click on your HP CP2025 printer and select Printer Properties.
3. Select the Device Settings tab.
4. Scroll to the bottom where you see Device Type. It probably says "Auto Detect."
5. Click on the words "Auto Detect" to activate a drop-down menu. Select "Color". Click the Apply button.
To test if this fixes your color printing, go to the General tab and click the Print Test Page button at the bottom. The page should print the Windows logo in color at the top of the page (the rest of the page is b&w).
Note: I did not install any additional drivers from HP for this printer. Windows automatically detected it and installed HP's Universal Print Driver PCL 6.
Kudos to Ken from the HP forums for this knowledge: http://h30499.www3.hp.com/t5/Printers-LaserJet/CP2025-Won-t-Print-in-Color/td-p/1151762
Feb 10, 2011 | Office Equipment & Supplies
My fax machine stays on and I can't print somethings. Everytime I try to print something the "FAX" machine window opens up....instead of the "PRINT" window. I clicked on the little arrow by the printer...
Try this.. Go to start, devices and printers and you will have a few things listed in there that are related to your printer. Most likely it will say document writer, fax and your hp printer. Make sure that the check mark is on your printer, not your fax. This indicates what your default printer is. To change this, right click on your hp printer and select set as default printer. Once this is set try printing again. Let me know if this works, if not we will try step 2. Hope this helps!
Oct 23, 2010 | HP Office Equipment & Supplies
HP 4180 SERIES STOP PRINTING
Is it set to "default printer?" Right-click the printer icon and set it to default. Also, right click the printer icon and go to properties, then click "print test page" to test your printer.
Apr 14, 2009 | Computers & Internet
My printer is not working, I thinkis the connection between the printer and the computer as I did a print test page and it worked. when I print from the computer it does not print. Hope you can help
1)right click the my computer icon
2)click properties and then click hardware n go to device manager.
3)uninstall all usb ports and then scan for hardware changes
4)ur pc will detect your printer and ask for printer drivers
5)re load drivers and your pc will communicate with your printer
6)for reloding install the cd follow the instructions on the screen and click next
7)restart when the printer is loded.connect the wires and cords properly.
Nov 29, 2008 | HP Office Equipment & Supplies
HP 3330 Printing Problem
Aug 29, 2008 | HP LaserJet 3330 All-In-One Printer
How do i install hp laser jet 1018 printer
hi johnboy
you can download the driver from here hp 1018
select your windows to download .
riz.
Jun 09, 2008 | HP LaserJet 1018 Printer
My HP Photosmart 8450 no longer prints lines, boxes, etc., since I upgraded to VISTA and MS Office/Word 2008. HP says to buy a VISTA-compatible printer...they do not have an updated driver. Any solutions?
You can use the drivers supplied by Windows Vista
Verify that the printer is turned on.
Connect the Universal Serial Bus (USB) cable to the printer and to the computer.
After plugging in the device, select Don’t show this message again for this device.
Click Continue on User Access Control (UAC) Window.
Go to the Start ( ) icon, click Control Panel , click Hardware and Sounds , and then click Printers .
Click Add a printer .
Click Add a local printer .
Select the Use an existing port check box.
In the Use an existing port drop-down list, select USB001 and then click Next .
Under Manufacturer on the Install the printer driver dialog box, select HP .
Under Printers , select HP Photosmart 8400 series and then click Next .
In the Printer name text box, type the printer name and then click Next . The printer driver starts to install.
When the message You're successful and HP Photosmart 8400 series appears, you can print a test page to ensure that the printer is working correctly and then click Finish .
Apr 03, 2008 | Office Equipment & Supplies
Printer Error Code 20 HP Deskjet
Dear rowanleigh,
What u have to do is just unistall the printer Driver restart the system then Reinstall the printer driver. and also do one thing delet all the temp files, temporary internet files & run the Disk cleanup tool.
Regards,
Bittu_8
Feb 13, 2008 | HP DeskJet 3930 InkJet Printer
18 people viewed this question
Ben Johnson
