Question about Creative Labs PC-Cam 600 Digital Camera
Pc cam 600 installation in windows XP
How can I install my pc cam 600 in my new PC that runs with XP Operation system ??? I can't install the old cd because its not compatible, so what should I do to use my cam again?
    Champion:
  • 217 Answers
Download upgrade driver from the internet, it's free!!! [;0)
Posted on Sep 10, 2007
SOURCE:
I have a Dell XPS 600 Desktop. I have a new HDD SATA. I installed the new HDD and I try install Windows XP by pressing F12 to boot from disk. It take me to a screen where it says, Press enter to install...
Don't press F12, that tells the Dell to restore Windows from a hidden partition located on the original hard drive. Since you are using a new drive, you need to boot from the Windows XP CD and follow the instruction to load the operating system.
Oct 30, 2010 | Dell XPS 600 PC Desktop
I have a 845GV Chpest zebronic mother board in my CPU. & i just want to format my PC window service pack 2 is not supporting. so please let me know which window i should use to format my PC
You can format the Computer but i feel like your computer is not too old to not to accept the service pack 2 ..
Check the system configuration and format the system
Disk formatting is the initial part of the process for preparing a hard disk or other storage medium for its first use. The disk formatting includes setting up an empty file system.
So you can format using the Windows OS CD --
Format the Drives and delete the partition
Check the Video -- May help you
A VIDEO HELP YOU HOW XP INSTALLS
If you want to format the pc and install the new window then
1) First take the Backup of your files
2) You need to have the Operating System Disc
Windows XP Professional System Requirements
PC with 300 megahertz or higher processor clock speed recommended
128 megabytes (MB) of RAM
1.5 gigabytes (GB) of available hard disk space*
Super VGA (800 x 600) or higher-resolution video adapter and monitor
CD-ROM or DVD drive
Keyboard and Microsoft Mouse or compatible pointing device
Jan 03, 2010 | Computers & Internet
Gigaware webcam is not installing on my xp system
uninstall the camera program
then unplug cam from pc and reinstall with cd and don't plug cam in until asked
if does'nt instruct to plug cam then after software install restart plug in cam on restar
Jan 16, 2009 | Computers & Internet
Got a new hdd 250gb sata the pc can't find it
I have the exact same system you have and have the same problem. Dell quit supporting that system as far as updates to drivers and BIOS updates before SATA drives became readily available.
The short answer is there is no way to boot to a SATA drive on that system that I have been able to discover. The BIOS does not recognize it as a bootable device.
What you can do is boot to a regular IDE (PATA) drive, install the driver for the SATA drive and Windows will recognize it. Place your Page file on the new drive and all your applications and data on the new drive.
It is not ideal, but I have managed to move the majority of files to the new drive and it runs quite well. You have to be diligent about installing new software to the new drive instead of the IDE drive.
There is a program you can buy for about $15 that will help you move applications that insist on installing to the boot drive called App Mover. I tried the free trial and it works quite well.
If you ever get a better answer, let me know.
Dec 28, 2008 | Dell XPS™ 600 PC Desktop
Dell xps 600 windows booting problem
You would probably do right to reinstall Windows. The bios handed off to Windows long before the splash screen comes up. It is probably a faulty driver or corrupt registry entry. If it was me I would reload Windows
Dec 01, 2008 | Dell XPS™ 600 PC Desktop
Just installed P5G- motherboard, runing windows XP eror code purple wont run, any ideas
Normally Windows XP will not boot if you switch out motherboards, not unless it has the exact same chips as the old one.
If you have your Windows XP install cd, you can try a repair install.
When the installer asks you if you want to do a new install, or run the repair console, hit new install. It will search for your old windows install and ask if you want to repair it.
Doing so will leave your applications and user accounts on your computer, and reinstall only Windows system files. It may ask you to put in your key code.
May 09, 2008 | Computers & Internet
INSTALL PHILIPS WEB CAM SPC 600 NC
First try to plug in your Cam into the system and when it detects and pops 'windows found new hardware and installing software for it' put in the cd into the drive and choose to find/search the drivers location of the Cd.
If it doesn't not sovle your problem then first put in the CD and install any EXE file (most probably the driver installation file) and restart your PC and then after that connect your Camera to the System hopefully this would solve your problem inshallah.
Regards
myaseenl
Apr 24, 2008 | Microsoft Windows Vista Ultimate Edition
I found a pc that has windows 95 installed in it . how can the old windows be replced by new windows
if you want to remove win 95 just remove it ... or else if you want to install new version .. try upgrading ..
Sep 30, 2007 | Microsoft Windows XP Professional With...
Problem installing the driver
Mine did the same thing - just ignore it and click ok - it will work believe me - just do it and it'll work.
Sep 12, 2005 | Creative Labs PC-Cam 550 Digital Camera
Creative Labs PC-Cam 600 Digital Camera Logo
116 people viewed this question
Top Creative Labs Cameras Experts
micky dee
Geoff Hone
ray gallant
ray gallant
Are you a Creative Labs Camera Expert? Answer questions, earn points and help others
