Question about Sherwood RX-4103 Receiver
Heavy static noise
I recently purchased a RX-4105 AM/FM Receiver and the Bose Acoustimass 3 Series IV Speaker System. After I hooked every thing up, I notice that there is a pulsing noise and static. It gets even worse when certain lights in our condo go on. Is there any way to solve this? Thanks, David
  • Sherwood Master
  • 4,872 Answers
Sounds like interference getting in caused by your connecting cables. Suggest upgrading to higher quality ones.
Posted on Feb 20, 2009
Is the subwoofer from the Bose acoustimass 10 series IV Home Entertainment Speaker System a power sub?
The entire speaker system is passive. That is, it requires amplification for each channel.
From the manual: "Compatible with A/V receivers rated from 10 to 200 watts per front channel and 10 to 100 watts per rear channel; rated from 4 to 8 ohms".
Dec 09, 2010 | Bose Acoustimass 10 Series IV Home...
Which model of amplifier will match the Bose AM 10 series4
There's a pretty decent write up for this speaker system on CNet. The "Speaker System" section calls for an amplifier capable of 10 - 150 watts RMS.
Bose maintains a library on their products as well. You can download FAQs, Manuals and Product Information easily. On the accessories tab, Bose lists an Onkyo receiver for $350 that will work very well with this speaker system. Of course, any quality modern stereo receiver or amplifier with power in this range 10 - 150 watts should provide good results, but better amps will be in the 75 watts and greater range.
I hope this helps - good luck
Sep 14, 2010 | Bose Acoustimass 10 Series IV Home...
Just purchased the Yamaha RX-V765 receiver. Have
I too have purchased the same receiver and have the same speakers. Did you get a good solution to this problem and how does it sound?
Jul 26, 2010 | Yamaha Audio Players & Recorders
No bass response
Seems there are 2 underlying problems-
no am/fm? are antennas connected? is there static active on any station tuned to?
in terms of low bass response- double check settings both in the receiver and also on the sub itself if any available.
Jan 14, 2010 | Bose Acoustimass 5 III System
I have a Lifestyle 35 and want to replace head unit with a 5.1 receiver. The Bose subwoofer model LSPS uses a network type cable connector on the sub side and a male din plug on the head unit side of...
The entire 5.1 amplification system, in the Bose Lifestyle 35, is actually part of the Bose Acoustimass (subwoofer) module. The RJ-45 (network type) connector passes a low-voltage signal from the console to the Acoustimass module. If you were to hack the connection, and plug the speaker outputs of a 5.1 receiver to the RJ-45 socket on the Acoustimass module, you would blow the amplifier.
If you are really itching to replace the Bose Lifestyle 35 console with a regular 5.1 receiver, I strongly suggest you sell your Bose system, and purchase a Bose speaker system, such as the Acoustimass 10 Home Theater Speaker System, which is made for use with a standard 5.1 surround sound receiver.
Dec 26, 2009 | Bose Lifestyle 28 System
Front Speaker not working
Yes, ur setting needs to be changed. On fliping the settings u will realise in one of the modes mostly the surround mode the speakers will work.
Thankyou
Appreciate a good rating from you..
Jul 31, 2009 | Bose?® Acoustimass?® 10 Series IV home...
Can I hook the reciever to mm bose subwoofer and 5
if bose unit has built in amplifier .Then your sherwood would have to have a variable RCA output jacks in order to work with sub.Then bose audio input RCA cable would connect there.If bose unit does not have built in amp .Then you would connect sherwood left/right speaker outputs into bose left/right inputs .Then other bose speakers will connect to bose unit
Jul 30, 2009 | Sherwood RX-4105 Receiver
Bose Acoustimass 15 subwoofer is completely dead.
Clarify, did it ever work for you? Were both receivers used properly configured for the subwoofer? Did you also test the other speaker moduels running off the subwooferto see if they work?
Speaker Receiver setting
• Left and right LARGE
• Center LARGE
• Left and right surround LARGE
• Center surround* LARGE
• LFE/Subwoofer ON
With an Acoustimass 16 Series II system or upgraded Acoustimass 15 Series IlI system only.
Apr 23, 2009 | Yamaha RX-V663 Receiver
Sherwood receiver rx-4105 fm doesnt pu any frequency (just static) , am does
You need to hook an antena to the back of the unit (A peice of speaker will do!) you should see a screw in back of uniGood luck and Thank you for using FixYa.
Dec 17, 2008 | Audio Players & Recorders
Sherwood RX-4103 Receiver Logo
263 people viewed this question
Top Sherwood Audio Players & Recorders Experts
 Grubhead
Grubhead
Josh Whitehead
Josh Whitehead
Are you a Sherwood Audio Player and Recorder Expert? Answer questions, earn points and help others
