I bought this DC-CAMZ 4200 from CREATIVE SINGAPORE. This cam is amasing! I understand that the specs mentioned that only up to 512mb can be used. However, since most cameras are using 1gb with no problem, i recently bought a 1gb SD card andwas surpriced that it didn't work. I call up the technical hotline this afternoon to ask for help and was told that the max capacity is 512mb. But i asked the cust care if there were any cust feed back if they had successfully used a 1gb SD, it seems that there were people who are able to use it but he does not know what brand. I thank the Cust care for his help as he tried his best to help. I jus feel a 512mb is not enough if i were to use the video function. I hope the technical team could advise me on the alternative way to go about it. Possible a software upgrade or maybe what Particular brand of 1GB SD is suitable for this cam.
SOURCE: PC-Cam 300 no longer functions as a digital camera
Let's do a hardware reset on the player: Press Snapshot button and Operational mode button simultaneously for more than two seconds this will delete all the files from the camera. A beep sound is heard when the memory is cleared and LCD displays zero. This may get the camera working again.
SOURCE: PC-CAM 880 - remember Webcam mode
Uninstall all reference drivers to camera, reboot then install drivers again AFTER you hook the camera up to your computer.
Drivers can be found by clicking HERE.
SOURCE: Creative PC-CAM software
you might have a malfunctioning camera try it on a friends computer with the software if it dosent work it probably wont work you can take it to a repair shop, if it does work your computer probably has a virus or corrupt system files all you need to do then is scan for viruses and then insert a system repair disk for your current operating system or put your operating system disk in and repaair your system.
SOURCE: I want to Creative PC-Cam 600 software
follow the links below, it may help you to download drivers/applications:-
http://www.nodevice.com/driver/company/Creative-Labs.html
http://support.creative.com/
