Posted on Jul 28, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How do I connect my pioneer pl555z turntable to my new pioneer receiver.
Anonymous
Level 3:
  • Master 8,546 Answers
  • Posted on Jul 28, 2011
Anonymous
Master
Level 3:
Answers
8546
Questions
Helped
2767577
Points
24828
It helps to know the details of BOTH entities when an inter-connection is involved.
Most 'new' receivers don't support old-school TT's.
"PHONO" is the only designated connection on an audio device that is literal and exclusive. Nothing but PHONO will work right on it and old-school turntables would require it to preamplify and frequency-correct the tiny current produced by a Phono cartridge. Look up RIAA equalization.
If your unit doesn't have a PHONO connection AND your TT doesn't have a self-contained preamp you will have to get a Phono Preamp to connect between the TT and any Line Level input, like Aux.
eBay always has some...
http://shop.ebay.com/?_from=R40&_trksid=p3984.m570.l1311&_nkw=phono+preamp&_sacat=See-All-Categories
Testimonial: "Thank you .Information was very helpful."
I just want to know if I can run a turntable through this unit
You can connect some turntables to the VSX-54TX. The turntable needs to have a built-in phono equalizer; then you can connect it to the Line In connection. See page 26 of the manual for the details. The manual is available on the Pioneer product page: http://www.pioneerelectronics.com/PUSA/Home/AV-Receivers/Elite+Receivers/VSX-54TX in the Manuals & Brochures section. The current direct link to the manual is http://www.pioneerelectronics.com/pio/pe/images/portal/cit_11221/128163968VSX-54TX%20OPERATING%20INSTRUCTIONS.pdf .
I hope this helps. If you post a comment with the model of the turntable, I may be able to help identify if it has the built-in equalizer.
2helpful
2answers
How can I connect an analog turntable to my Pioneer VSX-D710S? Also, do I need a turntable with a built in pre-amp?
According to the specs there aren't any phono inputs which would have their own preamp. Everything else is line level so I'm pretty sure you'll need a preamp either between the turntable and one of the line level inputs or built into the turntable.
3helpful
How to hook up a turntable to a pioneer vsx-1019
receivers with a PHONO input can connect a turntable easily by just connecting the white and red stereo audio cables from the turntable to the phono inputs on the receiver. receivers without a PHONO input can still connect a turntable by using a phono-preamp whose output can connect to any analog stereo input on the receiver like CD or AUX. See this webpage for more info:
http://columbiaisa.50webs.com/turntable_to_pc_hookup.htm
I would like to set up my old Pioneer PL-514 turntable and my Pioneer SX-550 sterio reciever to listen to some old LPs. I seem to have lost the instructions and connection diagrams. Could you please...
http://www.vinylengine.com/library/pioneer/pl-514.shtml
http://www.hifiengine.com/manuals/pioneer/sx-550.shtml
The upper link is for the turntable, the lower is for the receiver. they want you to create an account tu dowlnload so just create an account with them. In my expierience turntables had hook upeads out the back(wires connected) that would hook to phono in on receiver and speakers would hook to receiver via speaker wires(may not be included) by pos and neg. The speaker wire usually either has a rib or a line or writing on on leg so you can identify which wire you would want to be pos or neg.
Re. pioneer pl 990 turntable can the lid be closed
No you cannot play while lid is closed and YES you need an amp/receiver amp
1helpful
How do i connect a pioneer pl-630 turntable to a pioneer vsx-1919ah receiver
Are you meaning it doesn't have a connection for a turntable, just aux connections etc?
Check if it has a magnetic cartridge pre-amp first, if it doesn't you can get one just put the words: magnetic cartridge pre-amp, into Google to find one. Once you get it that will plug into an aux socket and the turntable into that, so you can hear the sound.
PL-88FS with modern HDMI Receiver
Hi...
If the new receiver doesnt have a specific input in back labeled "phono" , You WILL need a preamp for the phono. Then plug the preamp into the AUX or other available input
SX-1600 + KD-491F
Hi again,
It would seem that you posted the problem here also. With your kind permission, I will repost my excerpts of my responses that others may benefit on similar concerns.
A. Most current receivers no longer include a PHONO input. Perhaps what could be done is to purchase a phono to line level pre-amplifier to go along in your purchase for a new receiver.
I was made to understand that the Pioneer SX-1600 is prone to speaker output problems which could either be:
1. the speaker relay (protection); and/or
2. the amp, STK4191II Stereo Module.
Either should be relatively easy to work on and perhaps you can try the services of a locally available qualified electronic technician since the repairs would not be too specialized. The service manual may be of help (or at least a schematic , they may be downloaded from here and here).
B. To recap what you need is a receiver that can accommodate:
4 - Pioneer S-DF1-K (15-100W, 8 ohms)
1 - Pioneer PD-F407 25 Disc CD Player
1 - Pioneer CT-300 dual tape deck
1 - Kenwood KD-491F turntable
C. Possible choices are (keeping in mind that the power output should be less if not equal to 100 watts and a turntable/phono input):
i. Onkyo TX-8522 Stereo Receiver;
ii. Yamaha RX-397 100 Watt Natural Sound AM/FM Stereo Receiver;
iii. Sony STR DE695 AV receiver;
iv. Teac AG-790 200 Watt Stereo Receiver;
v. Denon AVR 888 - AV receiver - 7.1 channel.
Some of the above also includes feature(s) to hook up to your video system. Some may even require a fifth speaker (subwoofer).
Incidentally, you can also choose another brand/model even without a turntable/phono input. As initially posted, a turntable/phone to line level pre-amplifier is only required. Here are some examples:
a. XP200 Turntable Preamp - Nano Series;
b. Pyle® Pro PP999 Phono Preamplifier;
c. Pro-Ject Phono Box Turntable Preamplifier;
d. Radial J33 RIAA Turntable Preamp Direct Box
Good luck with your project.
1helpful
Poor sound
You need to connect most turntables to a PHONO input or buy a PHONO preamp. Many newer receivers do not have a PHONO input. The AUX port you are using would work fine for a device like a CD player, but turntables need to be amplified. You can buy an external Phono pre-amp from Radio Shack. I don't know anything about this site, but something like this device should work for you. http://www.phonopreamps.com/tc400pp.html
Top Pioneer Audio Players & Recorders Experts
 Grubhead
Grubhead
John
John
Steve Sweetleaf
Steve Sweetleaf
Are you a Pioneer Audio Player and Recorder Expert? Answer questions, earn points and help others
