Question about IBM NetVista X41 PC Desktop
UPGRADING USB 1.1 TO USB 2
First off, I am a bit of a numpty as far as PCs are concerned. I have a Netvista 6274 - 14G with USB 1.1 and I want to upgrade / update to USB 2. I've searched on the internet and I'm confused about what part(s) I need as different sites suggest: PCI Card - Type 'F' and others about a 'Daughter Board'. Can someone please advise me what parts I do actually need to change to USB 2 and also a supplier, many thanks.
    Problem Solver:
  • 6 Answers
I searched and found a 1/2 height PCI card with 2 USB ports, plus a internal connector for two more ports. My little NetVista will not hold a full-height PCI card. Get out your tin snips.
Works like a charm !
FYI: I disabled the BIOS USB support for the old ports, and plugged the old MB cable into the new PCI card. I now have two 2.0 ports on the front, and two 2.0 ports on the back. However, I lost the ability to boot from USB
Posted on Dec 25, 2008
Trying to install windows 7 from flashdrive and get as far as "no driver for hard drive" to install OS and one can't be found anywhere on line. All I need is the driver and I'm home free. I
I had a look at the specifications of your computer and it might not meet the requirements to install windows 7
If your computer is 5 yrs or older it might not support windows 7 also you will need a minimum of 1 GB of RAM for 32 bit or 2GB of RAM for 64 bit to install windows 7 http://windows.microsoft.com/en-AU/windows7/products/system-requirements hope this helps
Jan 10, 2013 | ASUS Eee PC 900 Notebook
I have windows xp o/s, p5vdc-mx motherboard with 512mb ram and 80gb harddisk, can i install windows 7 in this configaration? if no please tell me the configaration?
Windows 7 system requirements 1 gigahertz (GHz) or faster 32-bit (x86) or 64-bit (x64) processor1 gigabyte (GB) RAM(32-bit) or 2 GB RAM (64-bit)16 GB available hard disk space (32-bit) or 20 GB (64-bit)DirectX 9 graphics device with WDDM 1.0 or higher driverInternet access (fees may apply)Depending on resolution, video playback may require additional memory and advanced graphics hardwareSome games and programs might require a graphics card compatible withDirectX 10 or higher for optimal performanceFor some Windows Media Center functionality a TV tuner and additional hardware may be requiredWindows Touch and Tablet PCs require specific hardwareHomeGroup requires a network and PCs running Windows 7DVD/CD authoring requires a compatible optical driveBitLocker requires Trusted Platform Module (TPM) 1.2BitLocker To Go requires a USB flash driveWindows XP Mode requires an additional 1 GB of RAM and an additional 15 GB of available hard disk space
If you want to run Windows 7 on your PC, here's what it takes:
Additional requirements to use certain features:
Aug 17, 2011 | Computers & Internet
I want to install win7premium32-bit to my pc
It requires at least 2 gb ram and c2 duo or higher. Be sure you have that min with your pc. next you need windows cd. insert it int drive and press F3 or any key to boot with cd. It's then very simple just do as pc says. In format using type choose NTFS next just proceed as directed and you are done.
Dec 14, 2010 | Computers & Internet
How many extra usb circuits are there on my ibm 09k9982-011 mother board
IBM 09k9982 011 ATX MOTHERBOARD P3 11s19k5609z 1N0Z9131W3C Netvista Socket 370
Condition: Used - pulled - working
Content: 1 Motherboard only
Compatible part # 06P2525 01
FRU 09K9982 , 89P8010
Chipset Intel 815 - FSB 100/133 - 2x Dimm PC100/PC133 - Agp 4x - 3 PCI - 2 USB
IBM 09K9982 Netvista Pentium III Moederbord.
Socket 370 Mini-ATX.
Intel 815 chipset.
2x Dimm pc-100/pc-133
Agp-slot (4x)
3x PCI
2x USB
Sound and Video on-board.
To use with : FOR IBM Netvista Socket 370 , 6648-TAU
hope this helps
Dec 11, 2010 | IBM (09N5424) Motherboard
I bought a new laptop from Dell. My old on is a desktop from Dell. I have a Belkin transfer cable. It is asking for a transfer key number. what is that????????
Please note that your cable will support below givne O/S check at your end.
One destination PC running Windows 7 (32- or 64-bit) and available USB port
One source PC running Windows® XP (32- or 64-bit) or Windows Vista® (32- or 64-bit) and available USB port
For Example two Pcs 1 is Xp and other pcs is Windows 7, then try to connect between both .
Another one more option is there for transfering the data between two systems either laptop or Desktop by a cross cable (LAN CABLE), buy a cross cable from shop and insert into RJ45 Socket (i.e lan socket) the try to transfer the datas.
If this answer is helpful, please rate....
Feb 27, 2010 | Belkin Easy-Transfer Cable for Windows XP...
Bios upgrade
BIOS are very motherboard specific!
Oct 29, 2017 | Intel Pentium 4 , 2.8 GHz (SL77ND)
Processor Upgrade For An IBM Netvista 8307-73G...
If the physical size, and numper of pins is the same as your current processor, you can most definately upgrade. Hyper threading is enabled through the bios, but as far as I know it's not neccesary.
Swapping out processors is fairly easy, and when you buy a new one, it should come with extensive instructions and pictures showing you exactly how to do it. Good luck!
Mar 12, 2009 | IBM NETVISTA M42 - P4 2.4GHZ/512KB 256MB...
USB 2 PCI card installation on IBM NetVista with MS Vista
Lucy,
USB 2.0 cards require 2 IRQs.
  • 1 IRQ supports USB 1.1
  • and the other the Enhanced (USB 2.0) controller.
Installing the USB 2.0 card in a slot that does NOT share an IRQ or shares an IRQ with onboard USB produces the best result. Consult your motherboard manual or online guide to determine which PCI slot is best for you.
You should also try disabling the on board USB support from BIOS setup.
Thanks
Iqbal
Apr 28, 2008 | IBM NetVista A40 PC Desktop
Can't upgrade the USB ports to Version 2.0
Hi cogilbert,
I had a similar problem with my PC which had older version 1 USB. I purchased a USB 2 PCI card with USB Hub, installed and problem solved. It really not a very expensive proposition. The card comes with the necessary software and drivers. It works great.
--RoadHawk
Nov 29, 2007 | IBM NetVista PC Desktop
IBM NetVista X41 PC Desktop Logo
202 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
