Question about Home
Shower low water preasure in electric shower
    President:
  • 1,263 Answers
Can you explain in a little more detail it would help in pinpointing the problem
Posted on Sep 03, 2008
What could be the cause of the low preasure warning light comming on and cutting out the hot flow.
without knowing the make ,model , where are we going to look for assistance with your question .
Jan 12, 2016 | Home
Council are do-oing work on the water pipes in the village and we all have very low pressure now my shower is not working - it does not heat the water is this due to the low pressure - the power to th
Power showers have a minimum working water pressure required to operate. It won't work when too low to prevent scalding or overheating. You can wait until the pressure is back up or bath with a friend?
Oct 20, 2014 | Home
I have a problem with low hot water pressure can you help would an elec shower help
1) If possible, it is Best to solve pressure problem before installing new shower.
http://waterheatertimer.org/Low-hot-water-pressure.html
2) If the cold water has good pressure, then Electric shower could fix problem ... but shower would have to be connected to the cold water line and not the hot.
3) Seems the expense of adding a electric shower would be greater than having plumber fix low hot water pressure.
Assuming you have access to plumbing pipes, and this is not apartment building.
Jan 05, 2013 | Water Heaters
I have a new delta single handle only shower and i have little or no water i have good preasure when i take out the insert but none when it is installed?
Shower is clogged. Put some caustic soda in boiling water and place the shower in it for some time. clean the inner side with some iron rod & retry
Aug 13, 2010 | Delta & Single Handle Shower Faucet
Shower head has little preasure or water volume. is there a flow restrictor that can be removed?
their might be on the handel where the hose meets, but if really low water pressure then maybe more of a problem.
Mar 26, 2010 | Grohe Aquatower 3000 Shower Tower...
Replaced a moen cartidge and now the water is not hot in shower
make sure when you turn on the hot and cold shut off valves all the way and turn the moen on after that. Some times I would get that problem if I turned one(either hot or cold) off then tried the shower.
Feb 23, 2009 | Moen & Posi-Temp Single Handle Shower Or...
Triton electric shower T90si ran dry and not now working.
pump needs attention and the heating element has burnt out
pump needs water to run and the heater element needs water to keep it cool
Sep 07, 2017 | Heating & Cooling
Triton electric shower runs cold
hi it sounds as though the thermostat has gone on top of the can assembly, or moreover it has scaled up & the element needs replacing, if thats the case your better off buying a new unit as the cost of the can assembly & the fitting it will be nearly as much, plus witha new unit you'll be getting a 2 yr guarantee?
Just a thought!
Dec 01, 2008 | Home
Hotpoint aquarius shower
water pump clogged with debry clean out
or the your home lost preasure in pipes
Mar 25, 2008 | Hotpoint Ultima WF860 Front Load Washer
Home Logo
97 people viewed this question
Top Home Experts
john h
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
