Question about Nokia 6500 Slide Cellular Phone
6500slide keeps on freezing
My 6500slde it worked fine then it started gowing slow and froze still the same problem can you tell me how to fix it or is it fixeble
  • 199 Answers
Have you tried reformatting it??
try this
12345 is a standard code and 00000, but if you change it and you have forgotten your unlock code, you'll just have to reformat it
key combination which is used to hard reset the phone (similar to #*7370). It is useful in some cases, for example when the phone cannot reboot.
The trick is
Switch off the phone.
Hold down the following three buttons: Green (call answer) button, * button, and ‘3′ button
While holding these buttons, press the power button and switch on the phone
When the message ‘Formatting’ appears on the screen, release all of the buttons...
reformatting your phone will delete all your data and also will restore all the defaults of your phone, and any corrupted application will be reinstalled, but if the formating doesn't work, you'll just have to re flash it, the safe way is to go to a near repair shop of your phone and have then to re flash your phone,
Posted on Aug 31, 2008
My Sony Blu Ray was working fine. I bought a used blu Ray it skipped and froze(was completely unresponsive. I had to unplug it to power it off for awhile. It worked for a few minutes and then started...
Does the player work with other blurry discs? If so, then your new- used disc has issues. You can try cleaning the disc or buy a repair kit.
If that doesn’t work you can try a different player.
Nov 13, 2017 | Sony Televison & Video
Water line keeps freezing on my GE side by side refigerator
Check to see if the water tank in the bottom of the refrigerator section is frozen. If it is, you will need to turn the refrigerator section temp down.
Dec 05, 2012 | GE (PSS26MSRSS) Side by Side Refrigerator
Black dot on a xbox 360 cd. My GTA has this black dot and keeps freezing after 5 minutes, what causes this and how can i prevent this from happening. *my GOW has this too and freezes after a match*
What your having is an problen with your Grpahic Card, VERY common with the xbox 360. currently there is no easy fix as the card is built in. you will need to find a local repair shop or send it to xbox.com for repair
Thanks
www.1RepairStop.com
Sep 18, 2011 | Microsoft Xbox 360 Console
Freezes on the 'Rebuilding...' screen.
The same thing happened too me about six months ago after about a year and a half of using my zen with min. problems. It would freeze on 'Rebuilding..' and then there was an endless cycle of reset but eventually it would Rebuild completely and all my music and information was fine. It seemed to be playing fine but if it froze I had to start the reset game all over again. Then the real problems started. There are a few load screens before you make it to the Rebuild and it started to freeze on that instead after awhile. I was actually revealed when I froze on 'rebuilding..' and made it that far.
If you can get it into recover mode and reboot it seems to have less problems freezing but that doesn't even work for me anymore. Then occasionally when it freezes it starts to vibrate terribly and make a horrible sound. Then it stops and flashes hard disk problems.
This all happened slowly too me. It really wasn't worth the time I put into it trying to fix it. My advice is to work on getting a new MP3 player. If you can get it past the 'rebuilding..' your going to have to play the reset game every time it freeze and it will probably freeze more often.
Aug 21, 2009 | Creative Labs ZEN Vision:M Digital Media...
Fridge keeps freezing
Chances are, they replaced the wrong parts, or didn't replace all the parts, assuming they replaced an electric motor kit. I would need to know the P/N of the electric motor kit to confirm what was replaced.
Based on the fact that it froze the drinking water tank, and if they replaced the electric motor kit, the problem is more likely the temperature sensor or the control board.
Let me know what the P/N is of what they replaced and we can be more precise.
Jan 01, 2009 | Jenn-Air JCD2295HES Side by Side...
Xbox 360 Freezing Problems
Shutting off the Xbox corrupted the Hard Drive... Have you ever got a Live System Update? You can also reset your Xbox without shutting it off using the controller. You probably have the Three Red Rings of Death... Go to this...
http://www.fix3redlights.com/?p=bfy&m=1&gclid=CKTS1MGEmpcCFRlRagodpD9H-A
Nov 29, 2008 | Microsoft Xbox 360 Console
My toshiba wont start it keep's restarting at the black loading screen.
have you done a maintainance on it to get rid of all the excess information?? if not..go to start--then all programs, then accessories, then tools, click on disk cleanup. click on yes to all when the pop up box show up.
after this do a defragmentation-- go to start, all programs, then accessories, then tools, then disk defragmenter. click on analisys-- this will tell you if you need to defrag your system. if yes-- do it..it will take time to defrag, but it will speed up you game play ability.
Oct 13, 2008 | Toshiba Satellite P305D-S8828 Notebook PC
Magellan RoadMate700
I think Magellan makes it so if you don't update your map every year it will freeze up. Mine does the same thing and they told me to buy an update for $99 last year so I did and it worked and then after it started telling me my map was over a year old this year it started freezing up again. I don't want to pay $99 every year to keep this thing working. I wonder if Garman or Tomtom does the same thing.
May 31, 2008 | Magellan RoadMate 700 GPS Receiver
Sony ericson k8ooi
Well the screen most probably froze because it was overworking itself. i dont really understand though you cant turn it on?
Oct 17, 2007 | Sony Ericsson K800i Cellular Phone
Nokia 6500 Slide Cellular Phone Logo
201 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
