Question about Sony Ericsson Cell Phones
Memory Card I dropped my phone and cracked the lcd screen, I have had it repaired and the phone is working again the only problem is that I have lost everything that was on the phone from my memory card and it is saying that there is no memory card inserted, what can I do?
  • claire21 Sep 02, 2008
    Thanks for that but I've now found that its my memory card thats not working as I've tried another card in my phone and that works fine, so my next question is have I lost everything that is on my memory card? Is there no way of retrieving it as I've got loads of photos on there.
Your board must have a hair line crack on the memory slot so you may need to replaced the main board
Posted on Aug 31, 2008
I dropped it and now it won't turn on. How do I fix it?
Whats the model? Take a deep look at the screen even if it doesn't appear damaged as the slightest crack on lcd may render it 'dead'. If cracked, may require replacement.
Mar 26, 2016 | LG Cell Phones
is the number was save on the phone memory or in the SIM..?
Jun 22, 2008 | Samsung HLP4663W 46" Rear Projection HDTV
Lg reset
Sounds like the LCD digitizer which either broke inside OR became disconnected. If the impact was not enough to sustain a screen crack, and you have warranty with either LG or through your carrier, you can get LG to fix it free if there is no physical damage, cracked screen, or water damage, with your carrier, it would be the easy, just tell them the screen isn't broken, the phone is intact but the screen is blank. That is a hardware failure... they are supposed to be able to withstand some drops so it really depends on how much physical damage there is.
A digitizer LCD is not expensive and there are ways to change them fairly simple since the screen isn't cracked, you go through most LG phones via the back, remove the camera, remove a black cover that holds the sim and or memory card, BE CAREFUL and please look at youtube to see a complete disassembly of your particular LG phone.
Jul 16, 2014 | LG Cell Phones
My iPhone screen won't come on but i can receive and answer calls
take out sim card on the side hold power put back in sim card
Sep 28, 2012 | Apple iPhone4 4G iPhone 4
Does not work. I think it was dropped.
Sorry the unit itself probally have a major or micro cracks into it PCB board.After it repair by a tv tech.The unit still could be also have bad or damges picture to the LCD screen panel too itself.The unit was drop hard or high up like from 3 or 4 feets?Not worth and a wast of the money for a repair for a drop electronic equipments with a LCD screen panel.Unit now only have 50/50 chances for the unit to work correctly again or without the unit LCD screen panel to have damages or picture to the LCD screen panel be effected.Best just buy a new one.
May 03, 2011 | Radio Shack Accurian APD-3955
I dropped my Phone when it was open and the inside screen cracked. The rest of the phone works fine. Can I get the inside screen repaired?
yes you can. There is a company in denver , co that does repairs called wireless image. You can contact a local repair center or any cell phone place that does repairs will do it for you.
Oct 21, 2010 | LG enV Touch VX11000 Cell Phone
My bold has a white screen with a couple black lines going vertically and a black circle/blob in the top right. The phone was never dropped and has no crack in the screen. Please try and help restore to...
You don't have to drop your phone to crack / break the screen. This problem is almost certainly caused by a crack screen. This can be easily repaired by taking your phone to the local repair shop and getting the LCD replaced.
Depending on where you live and who you know you can get this done for $50 - $100 in North America.
Oct 12, 2010 | RIM BlackBerry Bold 9700 Smartphone
Dropped my blackberry pearl, now it will not turn on
inspect your screen, and try to look for tiny fractures / will need to use a flashlight, and look at an angle VERY CAREFULLY, because if it does have any cracks, they are gonna be hard to see (about the size of a cat hair, also look for "prism" in rainbow colors.....if you see that, then the rails in the screen have cracked, and bled.). take the battery, sim card, and memory card out....wait 20 minutes, and put them all back in. try to turn the phone on....if nothing happens, take the phone back to the store, or find out about your warranty info if you still have one.....otherwise you're looking at getting a new phone.
i'm thinking your screen could possibly be cracked, but more than likely, something got knocked off of the circuit board, and will need to be repaired by the manufacturer either way.
Sep 20, 2009 | RIM BlackBerry Pearl 8100
W850i memory stick
hi there,
            I dropped my sony in water once and the screen stopped working completely , I had to replace the lcd screen myself in the phone, (which isnt that difficult with a sony ericsson , it damaged the lcd screen but not the rest of the this sounds like your software has been corrupted or the memory slot contacts have developed a fault from the damp
        Try the master reset function (remember this erases any security pin numbers you might have put into the mobile) and see if the problem persists.If your brave enough ? like me ! you could strip the phone down and blow it dry with a hairdryer (set on low temperature), look for gunk on the memory card contacts and clean these off with computer solvent cleaner and a cotton bud.Then update the firmware and the software from sony ericsson's website.But I have a feeling , that the water got inside and this has coated one or more of the contacts for the memory card with the same thing , that you get inside a kettle,literally scale has formed on one of memory card contacts.
Aug 31, 2008 | Sony Ericsson Walkman W810i Cellular Phone
Cell Phones Logo
Top Sony Ericsson Cell Phones Experts
Computer Repairing
Computer Repairing
Are you a Sony Ericsson Cell Phone Expert? Answer questions, earn points and help others
