Poor signal bush hd set top box
Hi, I just bought this item and find the reception has dropped significantly compared to the standard def box i had. I just read some reviews through a Google search and it seems like there are quite a few problems out there with them. When i get the picture it is great but it keeps dropping out all the time. Can you help please, should I exchange it for another one.
Regards Paul
I have a saterllite reciver just bought a bush hd freesat top box i am running my virgin cable tv through my samsung hd television i put my satallite cable in to my bush top box connect the hdmi cable to get the freesat turn my virgin box off source the hdmi cable on tv get the freesat logo but nothing else what am i doing wrong
Posted on Sep 22, 2009
Upgraded to Hd and tv started messing up. Double images for first 10 minutes and sometimes tv picture goes off and lines up and down.
Your HDTV is capable of up to 1080P resolution. SDTV (standard def) signals are 480i; EDTV (enhanced def) is 480P; HDTV are 720P, (there is no 720i) 1080i and 1080P. Generally, those modes ending in "P" look better than those ending in "i". 1080i is the highest possible for broadcast TV, but BluRay disks and Directv have 1080P display capabilities.
The double picture you're describing sounds like the TV is set to display only standard or enhanced def signals while the Dish Network box is supplying it with HD signals. You should locate the control for the TV's resolution and make sure it is set to "1080P" and then set the output of your Dish Network set top box to the highest output it offers. Do the same for your BluRay player and any other devices, too.
Once set correctly, you should have a great picture once again. I hope this helps & good luck!
Sep 04, 2012 | Sony KDL-40XBR4 40 in. LCD HDTV
I have just bought the Bush combi A322d hd ready lcd 22 inch tv/dvd. I have tried several times to tune it in but it doesn't tune in all the digital program properly that I had before using a standard tv...
Is your antenna "omni" or "uni" directional? "Omni" means you won't have to aim the antenna but "uni" antennas have to be pointed in the direction the nearest tower/s. You'll want to go to AntennaWeb.org and enter your address. This will show you locations and distances of TV towers in your area. My location is over 39 miles from any tower so I get virtually no reception with regular HD antenna. If your more than 20 miles you'll need to get a fairly high gain antenna and have to aim it in the direction of the TV tower.
Nov 19, 2009 | Bush Televison & Video
I HAVE A HI DEF BOX AND IT IS CONNECTED TO MY TV VIA A HDMI CABLE BUT PICTURE IS NOT HI DEF. DO I NEED TO ACTIVATE SOMETHING ON THE TV ITSELF?
HD signals are automatically sent from the receiver to the TV and are displayed as such unless there is a setting on the HD box in the on screen display to drop the signal to standard definition.
Its also imperative that you have HD programming and that that you are tuned to an HD channel. Since the box itself is backwards compatable it can display Standard Definition signals.
What is the model # of the box. Perhaps I can guide you to the settings.
Aug 11, 2009 | Toshiba Televison & Video
Adding a hd set top box to 55pp8620
hdmi id the best way to go
see if it is high defition input "HDMI" or s-video or av hook ups are not high def
Mar 15, 2009 | Philips Televison & Video
Hi-Def?
Yes, it is HD TV ready but you must have a set top box from your cable or dish company that provides a Hi Def signal. The inputs must also be connected with the YRB cable. Only certain channels on my box are HD. The screen is so large that HD isn't nearly as impressive as some of the smaller models but it is still HD. I also have the 53FDX10B.
Mar 03, 2009 | Hitachi 53FDX01B 53" Rear Projection...
Digital ready?
Deacon J,
You will need a digital converter box OR high definition tuner for the transition. What's the difference? A converter box will only output a standard definition signal, either on channel 3 or by composite or S video cables. A high definition tuner will allow you to watch the new digital broadcasts in hi-def, assuming they are transmitted in hi definition. The converter boxes are the cheaper option and you can get a coupon from the government for a $40 rebate on the box, but I would opt for the hi-def tuner fo the better picture quality.CNET has a good write up on the transition here:
http://www.cnet.com/1990-7874_1-5108580-3.html
I did some looking and about the cheapest hi-def tuner I could find was $150, which is 3 times what a converter box would cost. I would expect the cost to fall on the tuners over time. Perhaps a converter box may be a good solution until the prices fall, if they do. The problem is that not many companies are making the tuners, as most TV's already have a hi-def tuner built in, so there isn't a big market for the add-on tuners. I hope this answers your questions.
Dec 31, 2008 | Sony KLV-S32A10 32 in. HD-Ready LCD...
Switching to digital
No. The change only effects people that use rabbit ears or a rooftop antenna. If you receive cable now, no change is necessary. You will not be able to receive the HD channels, but you can't receive thiose now either. An HD set will show you the HD signals that your current Standard Def set can not show. Please note that your current set has a digital tuner but processes analog signals. The "digital" tuner that is requried for rooftop reception is to process digital broadcasts as the analog signals will no longer be broadcast.
I hope this helps,
Dan
Nov 13, 2008 | Orion Televison & Video
Bush 32" TV. desperate situation. T-T
The TV is in protection mode. An internal problem was detected and the set shutdown to prevent further damage. If the set is only 9 months old, it should still be under warranty. Call and request warranty service.
Dan
Sep 30, 2008 | Bush 5693D 24" TV
Hd set top box wont work with samsung plano crt
do you have cable
satellite or antenna???
Jul 30, 2008 | Samsung TXN3245FP 32" TV
Audiosonic 51cm tv, will a HD set top box work?
nope standard def should though. will say tv does not support hd channels
May 29, 2008 | Sanyo DS27510 27" TV
Televison & Video Logo
425 people viewed this question
Top Televison & Video Experts
