I recently lost my usb cable for my nikon d40. I then discovered the port on the front of the computer for the SD card, but whenI put the SD card in, my computer does not even show it. Rebooting my computer does not fix the problem.
Yes. I go to My Computer and it doesn't even show up.
Posted on Sep 03, 2008
  • 51 Answers
Have you tryed running it from my computer then clicking on the sd card?
Posted on Aug 31, 2008
How to transfer photos from my coolpix L20 camera to my computer? Thanks..
There are two easy ways to transfer photos.
1) Connect via a USB cable. The cable came with your camera. If you lost it, you can buy a new one on line or from Nikon. The cable has a small plug that goes to the camera and a large end that plugs into a USB port on your computer. Once the cable is connected, turn on your camera and your computer will recognize your camera's memory card just like it recognizes an external hard drive or other device. If you go to Explorer on a PC or Finder if you have a Mac, you will see it as a device. Open the device and the folder(s) it contains then copy and paste or cut and paste the jpg files from that location to a folder on your hard drive.
2) Transfer your photos directly from your SD memory card to your computer using either your computer's SD card reader or a USB external SD card reader that you can purchase on line for $20 or less. Open the battery compartment door and you will see the end of the SD card. Remove the card from the camera by pushing it in (it is spring loaded) and releasing. It will pop out. Insert the card in your card reader and your computer will recognize the card as if it were a hard drive or similar. Follow the instructions that I gave you for transferring the files above. Both methods can be simplified if you use software such as Nikon's Transfer NX.
Oct 01, 2014 | Nikon COOLPIX L20 Digital Camera
Nikon D40 SD card slot broken
If you feel up to doing the replacement yourself, you may order the part here.
Aug 13, 2012 | Nikon D40 Digital Camera
My computer quit reading the card or the camera, so I can't get pictures from the camera onto my computer
Try removing theSD memory card from your camera and inserting the SD memory card into an USBmemory card reader then connect the USB card reader into the USB port of aworking computer. The computer will see this USB card reader and SD memory cardas an external storage device. You can open the camera photo folder and copythe photos to your computer.
Apr 13, 2012 | Nikon Coolpix S4000 Digital Camera
I can't dump pictures onto my computer through a
It might have just happend due to recent update of your system
so the solution would also be another update
but before that go to the device manager , locate other devices and right click on it and click on update drivers, restart the system, if that works its fine else go on to the following link and download the latest version of the Nikon Software
http://support.nikonusa.com/app/answers/detail/a_id/61/kw/61/r_id/116678#Anchor-8
Aug 02, 2010 | Nikon D40x Digital Camera
Coolpix s220 won't transfer pics via usb cable
If you can get the pics using a card reader, why are you insisting on using the camera and USB cord? Pros always use a card reader.
Feb 07, 2010 | Nikon COOLPIX L3 Digital Camera
How do you put Nikon pictures on camera to computer?
There are a couple ways. One if you have a usb cable that its the camera and the other end into the computer, and import them. Or two you can pull the memory card (sd or flash) and put it into a card reader. Most pc's have them built in, but on a mac you will need to buy a card reader that connects to your usb port.
Aug 21, 2009 | Nikon COOLPIX L18 Digital Camera
My memory card won't work in my camerakeeps telling me to format the Lexar 2GB card every time I insert it
Use the camera to format the SD card not your computer. There should be a menu option to format it.
May 28, 2009 | Lexar Professional High-Speed 2GB Secure...
Cant download pictures usb
Take your sd memory card out of your camera, and put it in your computer. A file with your pictures should appear. Copy thoes pictures into a different fold on you computer. Take you sd memory card out of your computer and plug it back into your camera. Your pictures will be both on your camera and on your computer.
I hope this solution helps. Please rate this solution.
Oct 10, 2008 | Nikon COOLPIX L18 Digital Camera
Nikon D40 Download Problems
It could be the card reader is unable to read the card not your pc. You might be able to get a firmware update from card readers web site.
Jun 08, 2008 | Nikon D40 Digital Camera with G-II 18-55mm...
Nikon D40 Memory Card Error
Hello. Make sure the write-protect switch on the SD card is in the UP (nearer to the contacts) position. Try the card in an SDHC capable reader on your computer first. Note that the SD card can only be inserted one way - make sure you're not putting it in upside-down! If the computer recognizes the presence of inserted card (whether it can read it or not), format it at FAT32. When finished, remove properly (icon in system tray) and insert into your D40 slot, WITH THE CAMERA OFF!! Turn on the D40, and if it now recognizes the SD card, FORMAT it again, in the camera. Good luck.
May 26, 2008 | Nikon D40 Digital Camera with G-II 18-55mm...
Computers & Internet Logo
43 people viewed this question
David Payne
David Payne
