How to replace
I want to know how to replace it (new cartridge)
  • ksthabi Sep 01, 2008
    Thanks for a help
  • 36 Answers
Normally, there is a door on your printer that you can open and if your printer is turned on, the chariot within must move and stop in the middle of the rail in order for you to remove or add head cartridges.
First find a door (something like that) that you can open.
Tell me what happen then.
Posted on Aug 31, 2008
  • William VITULLO Sep 01, 2008
    Did you solve your problem ?
Canon LBP 5200 Notifies to replace cartridge even if it is new.
The cartridge has a chip on it to let the printer know if it is new or how much is used. If the printer cannot read the chip it may not work properly. Make sure all packaging is removed from the cartridge and the chips contact points. Reinstall and see if the problem still exists. If it does return the cartridge to the store as defective and have them replace it with a new one. If you are using a remanufactured cartridge or one that has been refilled most likely they did not replace or reset the cartridge chip.
Dec 01, 2013 | Fuji Xerox Phaser 3155 Laser Printer
Printer ask for cartridges
turn off your printer...then replace new cartidges.after replacing cartridge restart printer...always when you want to change or replace cartridge/Drum/fixing/belt trun off your printer...
Jul 12, 2012 | Lexmark X9575 InkJet Printer
Cannot get ink cartridges to stop at replacement Epson 300 series
If this is a new cartridge, open the front cover and remove all cartridges. Be sure the protective film has been removed from the cartridge prior to installation.
Inspect the contacts on the new cartridge for damage. Replace the cartridges in the correct place, close the front cover and power the printer down and then up again.
Hope this initial information and idea helps. Let me know for any clarification.
Jul 08, 2010 | Epson Stylus NX400 InkJet Printer
Refill cartrige and printer says replace cartrige
A lot of printer manufactures place a small chip on the ink cartridge. Combined with the printer software it knows you re-filled the cartridge. This forces you to buy new ink. A work around that works with some printers. Keep you're old ink cartridges. Replace with new and when it empties replace with you're re-filled ink cartridge. Store you're old re-filled cartridges in a dry cool place when not in use. With HP printers users keep three cartridges.
Good luck.
Mike
Jan 14, 2010 | Lexmark Z2420 Printer
Put in new ink cartridge and get error black and color cartridges need replacing
"New" refilled cartdiges? Or new from the manufacturer? Some printers have chips in the cartridges that "know" when they ran out of ink, and they have to be reset. If the refiller didn't reset the chip, it still "thinks" that the cartridge is empty.
If they're new cartridges, bought from the same place at the same time, I'd suspect bad cartridges.
Jul 22, 2009 | Office Equipment & Supplies
Full ink cartridges reading as emty on cx5700f
Did you purchase new cartridges from the vendor of the printer (e.g. Lexmark, Canon, Epson or HP) or are you using refilled or third party cartridges?
If you are not using factory new cartridges, Please replace them with factory new ones and let me know if that corrects the problem.
If you are using factory new cartridges, contact the vendor and tell them you need defective cartridges replaced.
Don
Jul 14, 2009 | Epson Office Equipment & Supplies
Installing new ink cartridge
bought a new cartridge for x3430, replaced old one and it says: "missing cartridge". I have re-seated it a million times but to no avail.
Aug 19, 2008 | Lexmark X2500 All-In-One Printer
Check Cartridge Error - Sharp UX-B700 Plain Paper Inkjet Fax
I replaced my new $40 cartridge with another new cartridge and it worked.
Feb 23, 2008 | Sharp UX B700 Plain Paper Inkjet Fax
Keeps showing J1 error, toner light is flashing
The J1 error means the toner cartridge needs to be replaced. Since you just replaced the cartridge, you should remove the cartridge and repeat the following steps.. Shake the new toner cartridge horizontally four or five times and then remove the cover. Slide the new toner cartridge in until it locks in place. It sounds like the cover may still be on the cartridge.
May 14, 2007 | Xerox WorkCentre XD103F All-In-One Laser...
27 people viewed this question
jasbo
jasbo
