Question about Electrolux Refrigerators
Hi i have an older electrolux 120 gas fridge,the piolet light is going but does not cool down.thinking it needs re-gasing if so where on the sunshine coast and how much
    President:
  • 1,462 Answers
Sounds as though this is an absorbtion type fridge and hence no gas! in any case, refrigeration only needs regassing when there has been a leak
Posted on Aug 31, 2008
Rm4400 freezer working fridge not
move temp sensor that's mounted in coils down or let hang if same replace sensor
Jan 19, 2014 | Dometic Refrigerators
Electrolux DFF44 Refrigerator not cooling properly. High Temperature Freezer light constantly on. Bought around 8 years back. compressor is also not working ..
Top of Form
If there is no cooling at all , before we go further we must confirm the first step of confirming the compressor and gas pressure. So shut off the fridge and leave it off while you clean and check the evaporator for frost. If frost is seen it is a good indication as the compressor is working with sufficient gas within.
Now after about 6 hours plug in the fridge to start. Observe cooling to happen in about one hour and ice to from under three hours.
Earlier make sure that the thermostat was set to normal mode for freezer and fridge. If there is no ice formation we have a big issue as the compressor and gas must be checked out. If compressor is running check the pressure, get help to test gas pressure. If not you will need to fill up ,If gas pressure is good the possibility of the compressor being inefficient is high. In such a case you must take consensus to estimate and decide, if RPM of motor is low check capacitor.
However if Ice forms then observe the fridge for about 24 hours for cooling to continue and the fridge to cut off. If not the auto defrost timer, or the thermostat must be checked.
The ventilation fan that circulates the COLD air from the evaporator coils could get clogged with frost and so could be jammed. Also the wires to the fan can be worn out due to the frost. If so check if the defrost timer works to switch the heater to remove the frost. Also the check if the compressor is shut down by the timer /thermostat . If the heaters are not working, check continuity of the heaters.
So attempt to test using a multi-meter / clamp tester from the outside and make your observations so that we come to the solution.
Please check this link for tips to work.
http://www.espares.co.uk/advice/fridges-and-freezers/a/2
Thank you for using Fixya.
Sep 05, 2011 | Electrolux Refrigerators
Cannot get fridge to go down in temp - it is above 15 degrees. Freezer is working well.
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
Jul 12, 2011 | Electrolux Arthur Martin ARA4262
Electrolux 3 way fridge will not work on 12v or 240,switch lights up, ok on gas. can i repaire?or have i got to replace? i think the model No is rm4200 or rm4230
Hi My three way fridge has the same problem. Have solved the 12v problem as it was not wired to the 12v invertor. Do you have an on board battery supply? the 12v is usless and runs a battery flat in no time. Better off to use gas. Hope to have the electrician here next week to check 240v so will let you know if we find a problem. Graham.
Jul 07, 2010 | Electrolux Refrigerators
I have 660 hobby van and a electrolux fridge gas and electric, when you turn it on with electric nothing happens when you try gas i can hear it light but the fridge does not get cold please can you help
Hi , I am guessing this is a kind of RV. If it is, I am wondering if you just got it?? If you did just get it then I will say that those kinds of Refrigerators can take up to four hours to show good cooling. Just a thought. Wayne
May 21, 2010 | Electrolux Freezers
Not cooling on 120 V0lts
NDR 1062, cools with gas but will not switch over to Ac . If i turn off lp, check light comes on and doesn't cool
Jun 22, 2009 | Dometic NDR 1062 Refrigerator
Our fridge stopped cooling-the gas is leaking-any danger to us
NO ITS NOT A DANGER TO YOU FREON HAS NO HARMFUL GASES
Apr 30, 2009 | Refrigerators
Pilot light wont lit up
Change The Thermostat Cause If Your Getting Gas But The Water Heater Doesn't Detect The Heat It Will Close The Valve. When Lighting You Hold The Button Down For About 30 seconds so the thermostat will detect flame and stay lit. Check To Make Sure The Thermostat Is Where It Should Be. Heres A Picture Of What It Will Look Like.
You Can Replace Them If Need Be Will Be Available At Sears Or Home Depot. Also They May Sell Them At other Local Hard Ware Stores.
Happy Fixing And Thanks For Using Fixya.com
Sincerely,
Michael Scott
Jan 19, 2009 | Vanguard International Vanguard BY Rheem...
Hi i have a 3 way electrolux fridge. it cools perfectly well on the electric mains, I've not tried the 12v, but it fails to cool on the gas. The gas ignites but fails to cool the system.
A simple remedy to the fridge working correctly.
I wasnt aware that the mains dial turned fully to an 'OFF' position. Once I had turned the dial until it 'clicked' off, I tried the gas and it lit and cooled perfectly.
May 28, 2008 | Electrolux Refrigerators
Beko fridge freezer not working... not cooling
yes it can b fixed is the fridge running ? if it is it will need re gasing which is a common fault with beko and you should not pay more than £40 for the re gas if it is not running it will b either your thermastat which again you should nt pay more than £48 4 or the compressor which will b aprox £120 supply and fit none of the above should b done by a novice good luck
Sep 07, 2007 | Refrigerators
Refrigerators Logo
237 people viewed this question
Top Electrolux Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Are you an Electrolux Refrigerator Expert? Answer questions, earn points and help others
