Question about Creative Labs PC-Cam 550 Digital Camera
Installation trouble with PC CAM 550 on Win XP Media Center Edition 2005.
I tried to install driver from the installation CD but a pop up displays " A error occured during installation...", so I d?cided to remove previous driver of my PC CAM but Windows XP displays " Driver is already desinstalled "... !!!! I don't want to format the memory of my PC CAM, because it took 55 precious photos... What can i do ?
  • osama94 Jan 31, 2009
    i have a problem in installing my creative pc cam 550 .A pop up appears and says that that the cd is could read and then it finishes off. Although i have the original cd
2 Suggested Answers
  • 903 Answers
SOURCE: Problem installing the driver
Mine did the same thing - just ignore it and click ok - it will work believe me - just do it and it'll work.
Posted on Sep 12, 2005
Microsoft windows XP media center eddition.No sound.How to fix? Have tried all solutions suggested to no avail.
Check if u have install audio drivers from the motherboard driver cd. If u have not installed, install it. If already installed it check for a newer version of the driver file with the motherboard manufacturer's web site. If you find it diffucult. Post me the details of the motherboard, or the total pc specfication, including the OS and Service Packs. i will provide u with the driver file.
Oct 04, 2010 | Microsoft Windows XP Media Center Edition...
Installation of XP MCE won't finish
You need to set the pc to boot from the install disk. Then it should detect the failed install. Either select a new location or over write or format the disk and install.
Trying to recover from a failed install is usually far more trouble than its worth. You usually end up with a unreliable install and nothing but headaches.
Mar 23, 2010 | Microsoft Windows XP Media Center Edition...
Problem Re-installing XP Media Center Version 2005
If I was you back up all your important data and then format the drive and start the installation from new.
Jan 02, 2010 | Microsoft Windows XP Media Center Edition...
No audio on my newly installed xp software
If you can see an error in device manager its means the audio driver is not installed. You need to installed the audio driver. The audio driver is in the CD installer of your motherboard.
Regards
nicoleFIXIT
Oct 02, 2009 | Microsoft Windows XP Media Center Edition...
I'm having difficulty installing itunes over xp media center. it seems that both xp and itunes want to grap the cd drive. Any way out of this? Also I heard that xp media centre is cp pro with some add...
I am not quite sure what you mean by saying that the programs want to grab the cd drive. Neither program should be using the cd/dvd drive unless you are using it, neither program has sole use of it. Could you clarify if you are getting an error during the installation?
No you can't install XP Pro and use the same product key that you have with Media Center. You need to purchase XP Pro if you want to install it and use the product key that comes in the packaging.
Sep 24, 2009 | Microsoft Windows XP Media Center Edition...
Icons and start up bar is missing
right click on ur desktop and click on arrange icons by then click on show icons on desktop if it is not already check marked.
Apr 24, 2009 | Microsoft Windows XP Media Center Edition...
A4tech PC camera failed installation
I also have the same problem, I've just upgraded my OS from XP SP2 to Vista Home Premium Edition and my A4TECH PK-750MJ won't work anymore but in my previous OS which was XP SP2, it was just a plug and play, no driver was needed, unline now, drivers were installed but it's still looking for the .inf file something. Please help! Thanks!
Mar 02, 2008 | A4tech PK5
O S disc, Toshiba L35-S1054
No unfortunately XP home and XP media edition are different but not completely. The only difference is the entertainment factor like TV control and live recording and pausing , viewing photos etc and media center is considered to be a bit more secure than XP home but i find this just a wrong perception of people as i also have XP home and also had media center, makes no difference at all regarding security but yes if u want much more features or facilities as far as entertainment is considered media center edition is far more good than XP home.......
IF U INSTALL XP HOME THAT DOES NOT MEAN U INSTALLED XP MEDIA CENTER
Now there are 2 ways to solve ur problem
1. Either get a NEW disc from microsoft or any computer shop for media center and then install it.
OR
2. Install XP home on your system and then try to put the CD for media center , it will update XP to media center . In this way u will get the media center back and u will also not lose any previous stored data.
NOTE: In both the above cases u will have to get the CD for Media center......
Wat matters is losing the data that is already stored on your system.
BUT AGAIN I WOULD LIKE TO REMIND HERE IS THAT INSTALLING XP HOME WILL NOT GET BACK U TO MEDIA CENTER AS THEY ARE DIFFERENT BUT IT MAKES NOT DIFFERENCE WHETHER IT IS XP HOME OR MEDIA CENTER AS ONLY DIFFERENCE IS ENTERTAINMENT>>> IN THE WORLD THERE ARE MORE PEOPLE USING XP HOME THAN MEDIA CENTER>>>
I would recommend to cont. with XP home
Feb 19, 2008 | Computers & Internet
Hp dv6000
There is option in BIOS called something about automated SATA recognition or similar - disable it. It is under System configuration. And if you are putting new drive in then run full test from BIOS (Hard drive selftest - takes about 79min.)
I tried to reinstall Windows Media center on my HP dv6000 because my previous hdd crashed - When I put in installation cd - it said that it can't find hdd. I spent week to figuring that out. The thing is - as far as you haven't disabled that SATA thing in BIOS - PC doesn't recognize hdd. But only with Windows media center edition. With all other windows xp - there is no such problems. Strange.
Feb 11, 2008 | Computers & Internet
Sep 12, 2005 | Creative Labs PC-Cam 550 Digital Camera
Creative Labs PC-Cam 550 Digital Camera Logo
56 people viewed this question
Top Creative Labs Cameras Experts
micky dee
Geoff Hone
ray gallant
Are you a Creative Labs Camera Expert? Answer questions, earn points and help others
