Question about Samsung Televison & Video
I have a Samsung DW28A20SD digital TV, only 2 years old & when you plug the mains power in & press the on/off button, nothing happens & the standby indicator doesn't light up. Is there a quick fix for this or what? Thank you.
  • glteale Aug 31, 2008
    Have checked incoming power supply & even tried
    some other outlets just in case. Other appliances work ok.
    How can I check or find inside power supply?
  • Samsung Master
  • 6,487 Answers
This is not that easy to fix since we need to do some diagnostic first to determine what is really the problem, the best thing that you can do for this is to take it to a repair center and let them diagnose and replace the parts the should be replace...
Good luck........
Posted on Aug 31, 2008
  • Samsung Master
  • 1,879 Answers
Probably you already checked:
power cord
power source / outlet
since the power indicator does not light up,
tried checking the power supply inside ?
  • 10,594 Answers
Please check ac fuse in power supply board might be blown / replaced.
LN55C750R2FXZA
you must check voltages,before change any board.
Aug 17, 2014 | Samsung Televison & Video
X322BV-HD*WXC100
Warranty is usually 1 year parts and labor. Contact mfc for warranty service. likely main board.
May 28, 2013 | Televison & Video
MY VP42HDTV WILL NOT DO NOTHING WHEN I PLUG IT IN WHAT COULD IT BE.
Hi if you plug it in at the mains and switch it on and you get nothing not even the standby light then this points to either a fuse been blown so check the fuse in the plug failing that it will mean getting a new power board fitted, now if the telly is more than say 2 years old i would say its not worth getting fixed as the chances are you will replace the power board and then you will start having problems with the inverter, soyou could end up throwing money down the drain.
if its less than 2 years old and its totally dead check the fuse in the plug change it anyway and then give it a try but if its still totally dead then this points to either the fuse been blown in the telly this is a little clear glass fuse located where the mains cable plugs into the main power board, if this fuse is not blown also then the whole power board will need replacing.
let me know how you get on or if you need further assistance ok
plz rate this solution as i have a whole page of unrated posts, thanks
Nov 28, 2010 | Vizio VP422 42 in. Plasma TV
Last time I tried to turn on my camera (Samsung SL502) the lens came out but the screen didn't come on. I hit the power button again and nothing happened, now the lens is extended and won't go back...
Sounds like the lens mechanism is stuck - mine does the same thing after my 2 year old dropped it on the cement. Looking for a replacement lens now, but not having much luck. Read the previous posts for other solutions. Good luck!
May 28, 2010 | Samsung SL502 Digital Camera
I have a Samsung HL-R5667W that is about 3 1/2 years old. The screen is dark except for occasional flickers of light. The lamp appears to be giving off light when I look in the back. I replaced the bulb...
Hi my name is Eric,
I hope I can help you with your issue ,
Most likely your colorwheel is bad,
second possibility is the digital board.
Both are for a technician to install, you could do more damage poking around inside the TV.
If I have helped you with your issue please click accept.
If you have more questions you can still respond until this post expires,
I will reply asap
Thanks
Eric
Sep 26, 2009 | Samsung HL-R5667W 56" HDTV
SAMSUNG LNS3251DC - RED POWER LIGHT IS ON BUT TV NOT POWERING UP. WHEN I PRESS THE POWER BUTTON NOTHING HAPPENS. TV HAS A DARK GLOW COMING THOUGH
Multiple causes here. The Main bd controls the Power supply. The Main bd receives the "Power on " signal from the IR sensor and the Power Button the tv. Seems that the Main bd is not sending the Power on signal to the Power supply. So the first place to start is with the Main bd. Second being the Power supply. have a trained Samsung tech troubleshoot the set.
Jul 11, 2009 | Televison & Video
Samsung HCN4226W 42 in. Rear Projection
My 5 year old Samsung HCN4226W is not coming on (no picture and no sound). When pressing the "ON" button, I can hear a "click" like it wants to come on, but nothing happens. HEL
Oct 10, 2008 | Samsung HCN4226W 42" Rear Projection...
Televison & Video Logo
66 people viewed this question
Henry  Thomas
Henry Thomas
Jerry Greenberg
Jerry Greenberg
