I have an asus eee which has a partitioned hard drive. The C drive is already full (3.7G) and is just running XP and Norton. The D drive has MS Office and all other docs (6.7G) only 16% being used. Why oh why did Asus partion this way and how can I fix the problem without repartioning the drives which would be a nightmare as the operating system etc came alreadsy installed with no recovery disc.
  • 51 Answers
You can use partition magic from norton to partition the hard drive without loosing any data.
Posted on Aug 31, 2008
I installed linux ubuntu remix on my ASUS Eee 1001PXB-BK301 multiboot, then i deleted ubuntu after not using it anymore using windows xp disk mangement and found myself without a mbr with grub saying grub...
What you need is SATA controller drivers to be downloaded while starting windows xp disk or ERD Commander.
Since Asus Eee does not have an internal Floppy Disk Drive (FDD), you need to use an external USB FDD.:
Step one: You would like to connect an external USB FDD.
Step two: copy scsi/sata Hardware Access Layer (HAL) Drivers for you laptop to a floppy disk
Step three: during the XP boot process press F6 and follow the prompts to insert a floppy disk with HAL scsi/sata drivers.
Step four: Finish the boot process and run fix MBR.
There is another easy way:
If you can get a Knoppix USB flash drive, you can boot it up from Knoppix and run the following command in the terminal window: sudo ms-sys -m /dev/sda.
Hope This Helps
Jan 29, 2011 | ASUS Eee PC Netbook
I HAVE AN ASUS EEE PC 900 WITH WINDOWS XP AND NO CD ROM IT HAS A VIRUS AND I AM TRYING TO REBOOST FIRST SO I WILL BE ABLE TO GO ONLINE TO DOWNLOAD NORTON 360
Have you tried booting safe mode? If you boot safe mode and cannot get rid of the virus, you NEED an external cd rom or a USB jump drive so you can boot from it and use something like ERD Commander, Hiren Boot USB, etc.
Or open the eee pc and remove the SATA hard drive and connect it ot another computer and run the virus scan, remove the virus and put it in again.
I hope this helps.
May 17, 2010 | ASUS Computers & Internet
There's a virus in my asus eee pc 2G surf and hard to connect to the internet. is it better to reformat it? How?
Check Two Solution:
Install Antivirus - Install new Symentec Antivirus Updated copy, and scan all Internet file, folder & Computer.
If problem presists - then format your Notbook or only your Notebook 'C' Drive
To format -
Windows XP installation:
1. Restart your notebook - and immedietly click on F2 key/Del button
2. Boot your computer from CD Drive
3. save your setting
4. it Running System File.
5. Then Create partition press Enter-(Delete previous partition)-press 'L'to delete your 'C' partition, If you want delete all partition, same delete like C drive.
6. Select 'C' Drive press enter to format partition choose option NTFS or Fat32, and Enter
7. It's running automatically then enter operation system windows CD Key and press enter
8. It will take time 30 to 35 min. Depending upon your RAM speed.
9. It will complete automatically and PC restart.
Feb 01, 2010 | ASUS Eee PC 2G Surf Notebook
Hi! how do i format my asus laptop to re-install windows xp
How to Format a Hard Drive with Windows XP
  1. To format a hard drive with Windows XP or 2000, insert Windows CD and restart your computer.
  2. Your computer should automatically boot from the CD to the Windows Setup Main Menu.
  3. At the Welcome to Setup page, press ENTER.
  4. Press F8 to accept the Windows XP Licensing Agreement.
  5. If an existing Windows XP installation is detected, you are prompted to repair it. To bypass the repair, press ESC.
  6. Use the ARROW keys to select the partition or the unpartitioned space where you want to create a new partition. Press D to delete an existing partition, or press C to create a new partition.
  7. Type the size in megabytes (MB) that you want to use for the new partition, and then press ENTER, or just press ENTER to create the partition with the maximum size.
  8. Select the format option that you want to use for the partition (Recommended: NTFS), and then press ENTER.
  9. After the Windows Setup program formats the partition, follow the instructions that appear on the screen to continue installing Windows.
Please don't forget to rate me..:-) Thank you much..
Nov 11, 2009 | ASUS Eee PC 900 PC Notebook
On an ASUS 1000h how do you remove the partition on the 80gb hard drive?
you can delete the partition by using an xp installation CD.
Nov 05, 2009 | ASUS Eee PC 1000H Laptop
Always need disk cleanup
Open up the Computer icon and right-click on your c: drive. Then click on Properties, then on Disk Cleanup. Once this has completed, you might want to run Defrag as well, in Tools, then Defrag, then Defrag Now. You might also think about Drive Compression too, to make more effective drive room.
Oct 31, 2009 | ASUS Eee 4G Notebook
I broke my asus eee pc 900 and couldnt start windows. so i tried installing from the xp disk..ive used 4gb thunb drives..external dvd drives. and i always have an error when trying to install on the hard...
hi,
most of the times if laptop or Desktop cpu falls then HDD is the very first part to be damaged.
You can try any third party software as partition magic or DM for formating the drive.
May 29, 2009 | ASUS Eee PC 900 Notebook
How to install wine on asus eee pc
You can install WINE via SYNAPTIC
if you use Easy Mode on Xandros pre-installed OS press CTRL+T
and then type
Sudo Synaptic
Then in the graphic frontend that pops up search for WINE and mark it for installation. Select Install and Wine will be installed automatically.
Note that you have to be connected to the internet.
You can also type
Sudo apt-get Wine
Follow the text instructions and Wine will be installed.
Apr 01, 2008 | ASUS Eee 4G Notebook
Computers & Internet Logo
62 people viewed this question
David Payne
David Payne
