Question about HP LaserJet 3030 All-In-One Printer
Hp scanner 3030
The computer does print and copy documents but doesnt scan. It says that the scanner is not connected. I have updated the software but no luck. Help.
  • arun ji Sep 09, 2008
    pls do the needful urgently i need a document to scan
  • bigdogbandal Nov 08, 2008
    I hooked up the printer to my computer with vista and I can't make the scanner work. When I push the scan to button it says scanner "not setup on pc". I went in the control panel and tried adding it but the computer is not recognizing that a scanner is hooked up to it.
I have a hp 3030 all in one is there.. printer, xerox, fax is working properly but scan is not working .. kindly solv this problems..
Posted on Oct 30, 2008
Buy "Readiris Pro 11" and select Brothers MFC-890 (Twain) (User Interface) This should wok
Posted on Dec 19, 2008
Need to scan docs from scanner to pc
You have to install scanner and printer software came along with the HP 3030 model.Once setup complete it will try to do self diagnose the scanner connectivity.Then when you press the button on the scanner ,scanner will send the data to pc to activate the scanner software automatically.
Nov 26, 2012 | HP LaserJet 3030 All-In-One Printer
Can print but not scan
Issue The error message 'An error occurred while communicating with scanning device' appears on the computer running Windows XP.This error occurs while using the HP scanning software. If the error message appears on the computer while scanning from a networked product, click here to troubleshoot scanner communication errors for the networked product (c00897542) (in English). This document does not cover the communication error message on networked products. Solution Beforeproceeding with the solutions in this document, use the product to makea copy in order to make sure that the hardware is functioning correctly. Ifthe copy function does not work, this document will not help resolvethe issue. Search the HP Web site for a document covering the errormessage that appears on the computer while copying. Ifthe copy function works, try each of the following solutions in theorder presented. After completing the steps for each solution, test theproduct. If the product still does not work, then proceed to the nextsolution.
NOTE: Someof the following solutions require that the computer be restarted.Consider printing this page or creating a bookmark to it, so that itcan be referenced after restarting the computer. Solution one: Restart the All-in-One and the computer Follow these steps to restart the product and the computer.
NOTE: Make sure that the product is connected directly to an electrical outlet and not through a surge protector or power strip.
  1. Turn the power to the computer off.
  2. Press the power button (c01453128.gif) to turn off the product.
  3. Wait 10 seconds.
  4. Restart the computer.
  5. Press the power button (c01453128.gif) to turn the product back on.
  6. When the computer restarts, try the scan again.
  • If these steps resolved the issue, you do not need to continue troubleshooting.
  • If the issue persists, continue to the next solution.
Oct 31, 2008 | HP PhotoSmart C4385 All-in-One Printer
My HP3050 scans only around 3 inches of the paper and rest is not scanned. What can i do to scan the whole document?
1a. If copy also similar complaint & optical sccaner moving home to end perfectly "Replace flat cable" which is connected to optical scanner.
1b. if copy also similar complaint & optical scanner not reaching home to end, "Lubricate optical scanner Rail".
Sep 18, 2011 | HP LaserJet 3030 All-In-One Printer
FAILS TO COPY FROM A SCAN
Hi
Scanning takes an image on a document on the scanner's platten and converts it to a digital file format stored on your computer.
Copying is scanning + printing.
To copy, you do not need to separately scan first and then print. Just select how many copies you need on the number pad, then press either the Black or the Colour COPY buttons on the scanner (or open the printer's/scanner's software and click on COPY), while it's connected to the computer and the document will automatically be scanned and printed (copied).
I hope this helps.
Aug 24, 2011 | Office Equipment & Supplies
We don't know how to get a document scanned with the HP 3030. We lost the guide. We never did until know, but would like to use this possibility now. Printing and copying works fine.
OK HOPE THERES A BUTTON FOR SCAN ON YOUR PRINTER..IF IT DOSNT WORKS THEN GO TO CONTROL PANEL..CLICK ON SCANNER AND PRINTER ICON. THEN YOU CAN OPERATE IT FROM THERE. OTHER PROBLEM CAN BE SOFTWARE UPDATE
FOR MORE INFO....
www.hp.com
Oct 15, 2009 | HP LaserJet 3030 All-In-One Printer
Scanner not scanning
PSC 1401 will print but it will not scan
Jun 30, 2009 | HP PSC 1401 All-In-One Printer
HP Solutions Center can not communicate with HP 3500c Scanner
Had exact same problem. Went to HP site and they said to check "add or remove programs" functions (in control panel) and if there are multiple copies of HP software to download their fix. I checked, had multiple copies, downloaded patch and all worked well again.
Sep 21, 2008 | HP ScanJet 3500C Flatbed Scanner
HP LaserJet 3030 Message: Scanning error cannot connect
I had the same problem on XP and Vista and it turns out that if your don't have the HP Toolbox Running/starting up with pc this caused my problem. Once I lunched it to startup with I am able to scan using the Scan To Button on my Scanner.
-Cepedare
Apr 04, 2008 | HP LaserJet 3030 All-In-One Printer
Scanned documents are very light
I have found that when scanning b/w documents, its helpful to start with a black and white copy, not a grayscale, pen written, or printed form a printer in grayscale mode copy, but a true black and white on the copier or fax copy. The scanner doesnt read shades of black so well and when scanning multiple page documents, my pixma tends to scan in lightly. I havent found a piece of software to do just this, batch darken what has been scanned (at least not for free). Copying before scanning is the work around. Hope this helps everyone who's had this problem. It also doesnt hurt to darken what your scanning down a notch when copying
Mar 21, 2008 | HP PSC1510 Printer/Scanner/Copier...
HP LaserJet 3030 All-In-One Printer Logo
809 people viewed this question
Ben Johnson
