Question about Epson Stylus RX425 Multifunction All-In-One InkJet Printer
EPSON RX425.pRINTING FROM SD Memory Card
When I insert a formatted SD memory card to print,all the lights on the printer start flashing.This did not happen when I had another camera which used a different card.I have tried several SD Cards and the problem persists.
  • Anonymous Mar 20, 2014
    Cannot get the SD cards to work, is there a fold or format the card needs to be in ?
    Master:
  • 623 Answers
It means that your sd card is incompatible with your epson printer
Posted on Sep 01, 2008
  • Epson Master
  • 19,396 Answers
Ensure that the cards are formatted on system Fat 32, if problem persists and is with all cards, then the card reader slot may be faulty.
    Genius:
  • 2,785 Answers
It seems the said memory card is not compatible with your printer,
What is insert card
This printer can print photos that are stored on a flash memory card.
Insert card means to insert the flash memory card into the printer so you can select the photos you want to print.
Apr 01, 2010 | HP Photosmart C6280 Printer
Epson RX425.Printing from SD Cards
Try to unplug the power of the printer for about 10 mins then plug it back in then try to print again.
Aug 31, 2008 | Epson Stylus RX425 Multifunction...
Printer wont read SD cards does read sony memory
If it does not seat (fit) properly, why say the printer will not read SD cards? It certainly will read SD cards that are supported. You can still upload to computer and print from there as you suggested.
Dec 27, 2009 | Canon PIXMA iP6700D InkJet Photo Printer
HP C5180 All-in-one : Memory Card Error, No memory card in it
  1. Remove the memory card from the camera.
  2. Locate the memory card slot on the product that is compatible with your memory card. Figure 1: Memory card slot locations c01331721.jpg 1 - CompactFlash (I, II) 2 - Secure Digital, MultiMediaCard (MMC), Secure MultiMedia Card 3 - xD-Picture Card 4 - Memory Stick, Magic Gate Memory Stick, Memory Stick Duo (with user-supplied adapter), Memory Stick Pro 5 - Front universal serial bus (USB) port (PictBridge-enabled)
    NOTE: Some portable USB flash drives with a read-only partition, such as U3 smart drives, might be incompatible with the front mass storage port on your product. These partitions are added by the manufacturer and may include utilities and other software. Refer to the manufacturer for additional details about your drive.
  3. If it is not already on, turn the product on by pressing the power button (c01324469.gif ).
  4. Turn the memory card so that the label faces inward and the contacts face the product. Figure 2: Inserting the memory card c01335108.gif CAUTION: Inserting the memory card in any other way might damage the card and the product.
  5. Gently push the memory card into the memory card slot until it stops. The memory card does not insert all the way into the product; do not try to force it.
  6. When the memory card is inserted correctly, the status light next to the memory card slots flashes and then remains solid green. CAUTION: Never attempt to remove a memory card while it is being accessed. Doing so can damage files on the card. You can safely remove a card only when the status light next to the memory card slots is not blinking. Do not pull out a memory card while the light is flashing green.
Step two: Print the photo
  1. Press Photo Menu . A message displays on the control panel with the number of files found on the memory card.
  2. Press the right (c01185072.jpg ) and left (c01185108.jpg ) arrow buttons to browse through the photos on the memory card.
  3. When the photo number you want to print appears, press OK .
  4. After selecting the photos, press Photo Menu again.
  5. Press the right arrow button (c01185072.jpg ) to select Number of Copies , and then press OK .
  6. Press the right arrow button (c01185072.jpg ) to select Layout , and then press OK .
  7. Press the right arrow button (c01185072.jpg ) to select Paper Size , and then press OK .
  8. Press the right arrow button (c01185072.jpg ) to select Paper Type , and then press OK .
  9. Make any other appropriate changes to the settings, and then press Print Photos .
May 23, 2009 | HP Officejet Pro L7590 All-in-One InkJet...
How to use the memory card reader
To access the memory card reader without using the software provided, follow the steps below. If no card is inserted, the green light on the card reader will be on.
Insert a memory card.
• Insert the card with the brand name label facing up.
• If there is an arrow on the card, make sure it points toward the printer.
• If needed, make sure you connect the memory card to the adapter that came with it before inserting it into
the slot.
Wait for the light located to the right of the slots on the printer to come on. The light blinks to indicate the memory
card is being read or is transmitting data.
• The printer recognizes one memory card at a time. If you insert more than one memory card, a message appears
on the display prompting you to remove all memory cards inserted.
• If a USB flash drive is inserted together with the memory card, a message appears on the display prompting you
to choose which memory device to use.
When reading of images is complete, the number of photos found appears on the display. Then you can make your selection and print. these are the types of memory card supported by you printer.
xD-Picture Card
• Secure Digital (SD)
• Secure Digital High Capacity (SDHC)
• Mini Secure Digital (with adapter)
• Micro Secure Digital (with adapter)
• MultiMedia Card (MMC)
• Reduced Size MultiMedia Card (with adapter)
• MultiMedia Card mobile (with adapter)
• Memory Stick (MS)
• Memory Stick PRO
• Memory Stick Duo (with adapter) or Memory Stick Duo PRO (with adapter)
Mar 18, 2009 | Lexmark X5495 All-in-One &USB...
Memory card incompatible
your sd card slot may have problem plz ask your local vendor to check it.
Sep 01, 2008 | Epson Stylus RX425 Multifunction...
Still no success printing from SD memory Card.
Here's what you can do. Backup your files from that SD card to your computer then reformat the card. Copy your files again to the card then try to print it.
Memory card issue with Epson r300
Hi , reinstall the printer driver with sd inserted.
Jan 25, 2008 | Epson Stylus Photo R300 InkJet Printer
Wont accept xd picture card
Hi, tecnil
Device cannot detect files on the memory card.
Cause
The memory card might be missing or inserted incorrectly. Verify that the memory card is inserted correctly.
The files might not be in the correct format. To print from the device control panel, the files must be in the sRGB JPEG format. To print other formats, you must use a software program on your computer.
You might have inserted more than one memory card. Only one card slot can be occupied for the device to detect JPEG files. Verify that only one card is inserted.
oke,
thx
cropp
Jan 08, 2008 | HP Photosmart 7450 InkJet Printer
Printing pictures from memory cards
>remove the flash card - try making a standalone copy
>try another card
Dec 30, 2007 | Epson Stylus CX4800 All-In-One InkJet...
Epson Stylus RX425 Multifunction All-In-One InkJet Printer Logo
104 people viewed this question
Top Epson Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
