Question about Car Audio & Video
Help me please brutha!
I have a Digital Audio model-DA2200W, Was listening to my tunes loud asalways....then the subs quit bumpin...checked the subs cuz i thought iblew em...theyre fine...The power on the amp is still on...green lightand all..just no output..I opened it up to see if anything looked burntlooks fine...is it toast or can i fix it??
I suggest looking closer at the motherboard where the positive is See if its burnt black on the back side then check your fuses in your car check them all also another thing check the audio plugs are they burnt or loose>??
Posted on Sep 02, 2008
Philips sw3440/37 audio inputs D-sub 15 connector pinout.
Hello
I was listening to my surround sound and a loud noise came from my sub along with smoke. I pulled the back panel off to find out a small resistor burned. Is there any way i can get a replacement?
Jan 22, 2011 | Audio Players & Recorders
Was riding down the road and my subs quit bumpin and protection light stays on
your rca cables or the wires running to the amp are loose and/or touching eachother. also check behind your head unit
Jan 10, 2010 | Power Acoustik LT-980/2 Car Audio...
JL 13w7 & 1000/1 Settings
There is no "perfect" setting that can be placed in a manual. It's all done by ear. Your settings will vary depending on the vehicle you are in, the type of enclosure you have, the type of music you listen too, how much voltage your deck put's out. There are many variables, but I can try to give you a basic guide.
First of all you need to know your enclosure. If you have a ported enclosure tuned in the mid to low 30's you may want to set the low pass to around 70-80 hz with your sub sonic set at 30 hz. this will give you the higher bass frequency you need for the loud bass you want, and protect the sub from going too far below the tuned frequency of the enclosure, and losing it's composure.
As far as the gain, and bass boost are concerned, you just have to adjust them by ear. First adjust the radio volume to normal listening levels, by that I mean as loud as it can go without the speakers in the car sounding like ****. Now you adjust the gain first. slow turn the gain control, carefuly watching and listening to the sub.. Adjust the gain to the point of the woofer getting a lil sloppy then back it down a bit until the sound is clean again. Now do the same with the bass boost. if there is a bass boost frequency adjustment, set that as close to the tuned frequency of the box as you can.
If you are in a sealed box the adjustments are a bit easier, and are all about taste. Adjust the radio as described before, and put on your favorite song. Next start udjust thing lowpass frequency to taste, not too high tho, try not us higher than 100 hz in your sub's for better sound. Sub sonic is not quite as important in a sealed box, as there is much less danger of the sub losing control.
Well good luck, and hope this helps!
Jul 13, 2009 | Jl Audio 13W7 Car Subwoofer
Fuse melts when turned up all the way
speakers are overdriving the amplifier you need a higher wattage.
Jun 23, 2009 | Digital Audio 2, CHANNEL 600 WATTS HIGH...
Subwoofer not working properly after a few mins playing
Get a hold of the woofer connector (I believe its brown) right by the whoofer and move it around/press it/disconnect and reconnect and check if the woofer comes on. There is a bad connection in the connector for the woofer itself. I have a 2001 GLE my self and that's what I found to be the problem with mine.
Dec 16, 2008 | 2001 Nissan Maxima
Any other suggestions...
make sure you have solid power and ground resistance (connections)
-jeff
Sep 02, 2008 | Digital Audio 2, CHANNEL 600 WATTS HIGH...
Da2200w wont kick out sound....
try using another input device for sound like a differert stereo or an ipod or try using another input channel on the amp such as high level or low level please rate -jeff
Aug 31, 2008 | Digital Audio 2, CHANNEL 600 WATTS HIGH...
Subwoofers not bumpin, amp is still on
Check to make sure there is a good input to the amp. Next check each sub to another source to make sure they are good. Look for any reset on the amp.
Apr 26, 2008 | Kicker CVR12 Car Subwoofer
Audiobahn A2502DP amp is alive but wont talk to me
Your "bumpin" may have killed the amps "bumpin" Was the amp secure when you were sliding? So wires are ok, and lights and finas running. You have power but no output..Check the settings on the amp, also the fuse. Something might be earthing itself to the amp as well.
Feb 14, 2008 | AudioBahn A2502DP Car Audio Amplifier
Amp isn't putting out any sound
I have a Digital Audio model-DA2200W, Was listening to my tunes loud as always....then the subs quit bumpin...checked the subs cuz i thought i blew em...theyre fine...The power on the amp is still on...green light and all..just no output..I opened it up to see if anything looked burnt looks fine...is it toast or can i fix it??
May 25, 2006 | Power Acoustik LT-980/2 Car Audio...
Car Audio & Video Logo
63 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
