Question about LG Washing Machines
I have an LG washing machine model WF-T755A After washing completed, if water not turned off at taps, the unit slowly fills up with water. The last time causing it to overflow and flood the floor
MNTECH gave me infor about eplacing inlet wahwer, which I did nad the problem was fixed
Posted on Sep 01, 2008
  • 1,543 Answers
Water inlet valve is not sealing off 100%. Replace inlet valve (the part where the hose attached to the machine). didn't find that exact model listed so couldn't give you a part number. Usually LG's have a separate valve for the cold and the hot. If you turn off one valve where hoses connect to household plumbing you should be able to figure out if it is the hot or cold. (most often it is the cold) Leave both valves off when not using washer until fixed. (note: usually on LG washers, if you have unit connected to power and the door closed, if it fills with water as your machine did, the water level switch will trip and automatically pump the water out, even if washer is not in use and the power is "off".)
Posted on Aug 31, 2008
We have a LG Fuzzy logic 5.0kg WF-T507. When not working, cold water is slowly leaking into the tub. The hot water is also not flowing when needed.
The fill valve could be defective but the leakage into the machine when idle could be caused by supply line(s) above the fill valve level. Some manufacturers recommend turning off the supply between wash sessions but in practice that tends to be impractical.
Feb 12, 2017 | LG Washing Machines
Iv'e got a LG Top loader.WF-T755A. When it spins the drum shakes violently and move the washing machine around . It also makes a loud noise while doing it. What is wrong please?
The load is off balance. Instead of being evenly spread out along the drum, your laundry is bunched up on one side. Try smaller loads to allow the clothes to move more freely in the water.
Feb 11, 2017 | LG Washing Machines
I have a LG Punch WF-C5856TC washing machine. Off late, Notice that the water is trickling in rather than flowing. Hence it takes really really long time to wash clothes. Pls advise
The first place to look is the inlet tap in the wall
even you have the tap on full the tap washer inside jams and prevents the full flow of the water
next check out the filter in the hose at the tap or at the washing machine end
next replace the water inlet solenoid
you can check this by changing the hose from the hot water tap onto the cold water tap and pressing the hot water button to fill
solenoids do not know the difference , they just work when the power is applied
Sep 08, 2015 | LG Washing Machines
I have a LG WF-T753A washing machine. The hot water is not working, but has in the past - cold water is fine. When it goes to fill up with Hot only, a slight hum, and then it stops, but no water. Have...
Check to see if the screen inside the water-inlet valve is clean. (The water-inlet valve is the device on the washing machine that the fill hoses are attached to.) If it's clean, you probably have a defective water-inlet valve. If so, completely replace it.
May 04, 2011 | LG WFT1071TP Top Load Washer
Users manual
The LG Canada website has it.
Click on "Owner's Manuals" on the left hand menu and fill in the details, model number WF-T8016TP. You'll need IE, not Firefox...
Jan 24, 2009 | LG WFT1071TP Top Load Washer
LG WF-T753A Top Loader washer hot water inlet valve
Just found this whilst looking for known issues with my machine as the cold water won't stop when filling.
Aug 25, 2008 | LG WFT1071TP Top Load Washer
LG WF-T652A Slow water fill
Probably dirty filters in the inlet part of the washing machine. I had the same problem with this model.
Jul 29, 2008 | Washing Machines
Washing Machines Logo
240 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
