Question about Acer AL1717 17" LCD Monitor
No display but only the light of powe switch (on/off) blinks and after some time it comes back (could be te signal problem??). Please help on this regards.
  • hurlhammer Oct 06, 2008
    i had the same problem it happened all of the sudden. the monitor would come on say acer then cut out and repeat.
  • wmshiham Oct 25, 2008
    i've got this problem too. display will go off and on/off button will start blinking
I have found a solution. when this is happening press the menu button rappidly. the on/off will occur still but after a few tries the monitor will stay on but you will have to repeat this if the monitor turns off. it seems to stay on when your system goes into stand by
Posted on Oct 06, 2008
TURN SIGNAL PROBLEMS,ALL 4 COMES ON W/RT SIGNAL ON.IS THE FLASHER BUILT INTO THE SIGNAL SWITCH? ON 2007 DODGE DAKOTA?
you have a bad ground (earth)someplace in that circuit and it is using any path it can to get it
Sep 05, 2017 | Dodge Cars & Trucks
Display not working but system functioning
tried with other monitor just to ensure if the problem is only with in the monitor. if the same problem, the cause it could be the inverter board for screen back light which has component being shorted.
Aug 15, 2012 | Samsung SyncMaster 713N 17" LCD Monitor
Problem with the Samsung Washing Machines The machine keeps coming up with the message HEI 10x
Here is a list of errors for your machine.
I hope they help you.
SAMSUNG WASHING MACHINES, ERROR FUNCTIONS
When an error occurs, the alarm noise will sound and the error code displayed in the program window. Listed below is a series of error codes you may or may not see for your model of Samsng Washing Machine. The errors are shown as blinking in O.5 second intervals until the error status has cleared. In this case, all the driving devices are turned off until the error is cleared.
1. WATER SUPPLY ERROR - Display shows 4E.
Water Supply Error occurs when water level frequency does not show changes more than 100Hz or water is not supplied up to the preset water level after 10 Minutes or more at the time of initial water supply. The error status can be cleared by turning the POWER switch OFF and back ON.
2. WATER DRAIN ERROR - Display shows 5E.
5E is displayed if the water level frequency detected is 25 KHz or less in the initial phase of the UNB -detecting cycle. The Water Drain error can be cleared by turning POWER SW OFF and back ON.
3. OVER-FLOW ERROR - Display shows oE.
Over-Flow error occurs when the water level is too high. It can be cleared by turning POWER switch OFF. Water is drained prior to POWER switch OFF. The tub is drained for 2 minutes if a frequency of more than 25 KHz is detected.
4. UNBALANCE ERROR - Display shows UE.
Laundry load is unbalanced, manually loosen any tangled laundry.
If only one item of clothing needs washing, such as a bathrobe or jeans, the final spin result might be unsatisfactory and an UE error message will be shown in the display. Unbalance error is cleared by POWER switch OFF and back ON.
5. WATER HEATER ERROR - Display shows HE, HE1.
HE, HE1 is displayed if the water temperature rises by 7 C or more in 1 Min or by 2 C or less 20 Min after heating process has started. The error can be cleared by turning POWER switch OFF.
6. WATER PRESSURE SWITCH ERROR - Display shows 1 E.
* Generated Frequency Signal of WATER LEVEL (WIL) SIW (KHz)
Normal Level = Abnormal W/L Frequency
Low Level = 30.00 Khz
High Level = 15.00 Khz
If the same signal is detected for more than 5 seconds, it is a PRESSURE SWITCH Error. When this error occurs the drain pump will operate for 3 min. and the display will show 1 E indicating a pressure switch error.
7. ABNORMAL WATER TEMPERATURE ERROR- Display shows cE.
e.g. If the water temperature is 50 C or more, during a Delicate or Wool cycle.
At the time of initial water supply, if the water temperature is not appropriate, the display will show cE. This error can be cleared by POWER SWITCH OFF.
8. WATER LEAKAGE ERROR - Display shows 11 E.
Water Leakage error occurs when the water drains naturally, (by leakage) after the washing program starts.
9. THERMISTOR ERROR - Display shows tE
Nov 21, 2010 | Washing Machines
Hi, I have Sony VAIO Laptop. The day before
ravi,
if the laptop getting power on and if u can see green light glowing and if you see that hdd keeping on blinking that mean that system is booting but there is no display.
issue is with ribbon cable inside the system u need to replace the cable. if you can do it it is ok other wise take it to service center.
i hope this will resolve the issue.
Jun 11, 2010 | Sony VAIO Notebook
I have a 98 chev cavalier z24. Both indicator
Sounds like the signal multi-function switch has a short it it. Get a new one.
Feb 02, 2010 | 1998 Chevrolet Cavalier
NO Display
time to replace the monitor, u fried the board, been there done that
Jun 20, 2009 | Samsung SyncMaster 793MB 17" CRT Monitor
There is no display on the monitor screen. The amber light on the power switch keeps blinking uselessly!
The monitor requires service The monitor is not receiving a signal from the computer
Apr 15, 2009 | Computers & Internet
Green light continously blinking in samsung sync master 753s
1. cpu problem. why because of there is no signal output from cpu to monitor. the led blinking means there is no vertical, horizontal signals from cpu to monitor.
2. your monitor connected to another system.
3. neck board dry points.
4. cheak the display cable. 13&14 pins are horizontal, vertical signals.1, 2, 3 pins , R G B , 6 ,7, 8 pins R G B ground ( coaxiler cable used , meshed wire is ground )
Oct 13, 2008 | Samsung SyncMaster 753S 17" CRT Monitor
Screen Don't Comes On Anymore
Have you tried plugging an external monitor into the VGA connector on the back? This would narrow down the problem to either the video card/motherboard or the LCD display itself.
There are several possible defects- as above, the display, motherboard component, video section.
Also, first check the LCD/CRT switching function. On many laptops, there is a function (FN) key which is pressed at the same time as one of the number/function keys (the uppermost row of keys), and this combo will switch display from LCD to CRT & both.
Feb 28, 2008 | IBM ThinkPad T42 Notebook
Acer AL1717 17" LCD Monitor Logo
94 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
