Question about HP DesignJet 450c InkJet Printer
Error lights I turn on the printer and it finishes up on the three yellow error group light (on the left). If I hit the cancel button, then the yellow cartridge light and the green ready light are on. If I turn the printer off and move the print catridges from side to side, sometimes the printer will work when I turn it on.
  • 53 Answers
Its one of three problems. Firstly is the carrage belt OK. Look at the area under the belt, are there lots of bits of purple looking bits and dust lying around, then you need a new carrage belt. P/N 4706-60082 (36"machine). If the belt is OK the second problem could be teh trailig cable although the are fairly long lasting. The most likley cause is the carrage (head unit) itself. The paper sensor packs up and then the error crops up. Your part number is C4713-60039. The machine is regarded as obsolete and parts are becomming hard to get. You have a good machine otherwise and try to get the parts. Yoy can log onto HP Partserve to locate spares in your area
Posted on Jan 29, 2009
ERROR CODE 5800
Follow these procedure
1. Turn off the canon printer.
2. Hold button Resume/Cancel (red triangle in the circle), click on POWER - an indicator light green.
3. Release the button Resume / Cancel keeping POWER.
4. Click Resume/Cancel 2 times, keeping POWER, and then release all the buttons.
5. When the indicator recorded GREEN - click Resume / Cancel 4 times!
6. Turn off the printer POWER button.
7. FINISH
I think You will be relif from your printer problem.
Thank you very much.
Jun 05, 2011 | Canon Pixma MP500 All-In-One InkJet...
Hi, i can no longer use my canon ip1980, the error message " ink absorber full, contact your service provider" how can i fixed my printer? thanks
7. FINISH
i hope this helpful
thank you for using fixya
Mar 16, 2011 | Canon PIXMA iP1800 InkJet Photo Printer
Howdo you fix an error message 5C00 on a Canon iP90 printer.
Try this to reset the error.
1) Close the print head cover, and turn off the printer. While pressing the Resume/Cancel button, press the Power button. (Do not release the buttons. The LED lights in green to indicate that a function is selectable.)
2) While holding the Power button, release the Resume/Cancel button. (Do not release the Power button.)
3) While holding the Power button, press the Resume/Cancel button three times, and then release the Power and Resume/Cancel buttons. (Each time the Resume/Cancel button is pressed, the LED lights alternately in either orange or green, starting with orange.) During initialization, the LED blinks in green.
4) When the LED stops blinking and lights in green, press the Resume/Cancel button the 4 times. (Each time the Resume/Cancel button is pressed, the LED lights alternately in either orange or green, starting with orange.)
5) Press the Power button. The LED lights in green, and the selected function is performed. (When the operation completes, the printer returns to the menu selection mode automatically.)
6) Power off then back on and test.
Please rate this solution, thanks!
Mar 07, 2011 | Canon Office Equipment & Supplies
How do I reset an 5800 error code on my Canon mp500? Waste ink full code.
7. FINISH
i hope this helpful
Feb 16, 2011 | Canon Pixma MP500 All-In-One InkJet...
My canon ip90 does not print, continue to get 5100 error msg
you can try this method to reset the error..
First close the print head cover, and turn off the printer. While pressing the Resume/Cancel button, press the Power button. (Do not release the buttons. The LED lights in green to indicate that a function is selectable.), then while holding the Power button, release the Resume/Cancel button but do not release the Power button.
While holding the Power button, press the Resume/Cancel button three times, and then release the Power and Resume/Cancel buttons. Each time the Resume/Cancel button is pressed, the LED lights alternately in either orange or green, starting with orange. During initialization, the LED blinks in green. When the LED stops blinking and lights in green, press the Resume/Cancel button the 4 times. Pls note each time the Resume/Cancel button is pressed, the LED lights alternately in either orange or green, starting with orange.
Then press the Power button, the LED lights in green, and the
selected function is performed. When the operation completes, the printer returns to the menu selection mode automatically. Last just power off then back on and test.
May 28, 2010 | Canon PIXMA iP90 InkJet Printer
Canon i470D Printer will not work. Yellow light
1. Turn off the printer ( "Power" button).
2. Hold the button "Resume", include printer (click "Power").
3. Hold the "Power" button, release the button "Resume" (power indicator / preparedness must turns green)
4. Not releasing the "Power" button, double click "Resume" and release both buttons
-- each time you click "Resume" power indicator / willingness to change color (one-click - yellow, the second hitting - green). U printers with more than one indicator - indication switches (power indicator / preparedness - green indicator error - yellow)
-- after the buttons are released, power indicator / preparedness will be for some time to blink green (Stamford time depends on the printer model), and then the green light permanently
-- If after these actions instead of constantly burning green printer continues to display error, or you are mistaken in paragraphs 1-4 (turn off the printer and repeat with paragraph 1), or if additional printer error that must be corrected, or it will not go down to a service mode.
5. Four times click "Resume" (each time you click "Resume" power indicator / willingness to change color, and the printers with more than one indicator - indication switches: the willingness / error).
6. Once you click "Power" to confirm the selected action (reset counter absorber). To disable the printer "Power" button to click again.
For some printers (for example, iP2000) to switch off clicking "Power" again, that is three in a row.
May 08, 2010 | Canon i 470D InkJet Printer
Cartridge seems to move smoothly. Just get the
There could be 2 reason for this error. You can either reset the error or try and clean the printer from inside which might be causing the problem. Below are the 2 steps:
STEP 1: Clean the printer from inside
  1. Opened the cover and checked the front right of the printer near the waste ink pads
  2. Carefully turn the cogs to move the ink cleaning mechanism
  3. There might be a load of paper jam debris blocking the mechanism from reaching its port
  4. Carefully cleaning this out and putting the printer back together
STEP 2: Reset the error
Apr 26, 2009 | Canon PIXMA iP90 Mobile Printer
Error 5100 canon ip90
You may try this to rest the 5100 error:
Dec 07, 2008 | Canon PIXMA iP90 InkJet Printer
I need to know what the error codes 5100, and 5700 mean, and what causes those errors to come up on the screen. Thank you
Try resetting the printer:
Jun 20, 2008 | Canon PIXMA iP90 InkJet Printer
HP DesignJet 450c InkJet Printer Logo
186 people viewed this question
Ben Johnson
