Question about Mitsubishi WD-52525 52" Rear Projection HDTV
V21/V19 Mitsubishi DM Repair Kit
Just how complicated is this to fix?...I just ordered the above part and will try to tackle this on my own but just curious if you can share any tips/pointers before the part arrives...
Thanks
Jerry
  • Mitsubishi Master
  • 8,617 Answers
Its a very easy repair. The kit will have easy to follow instructions. Will just require a small amount of very basic soldering.
Posted on Aug 31, 2008
Continuous flashing green light, tryed reset button and cut power to tv, no change
The V19 V21 DM repair kit from www.tvrepairworld.com should repair that issue. The kit also contains the instructions
Nov 26, 2009 | Mitsubishi WS-55909 55" Rear Projection...
Mitsubishi TV green flashing timer light after power outage.
You will need to cahnge the capacitors on the DM board, very common problem. The V21 V19 DM repair kit at the following link contains the replacement capacitors and detailed instructions. Its listed under the repair kits catagory at the following link.
http://servicemanuals.vstore.ca/
Aug 29, 2009 | Mitsubishi WD-52525 52" Rear Projection...
Timer light just blinks had a power outage last night wont turn on
you need the V21 V19 dm repair kit which should take care of that issue for you. Its listed under repair kits at the following link
the kit contains the capacitors and instructions on how to do the repair.
Aug 03, 2009 | Mitsubishi WS-55859 55" Rear Projection...
TV will not turn on. Also will not System Reset
you need the V21 V19 DM repair kit to repair that issue. Its a very common problem and a very easy and inexspensive repair. Heres a link to the kit which contains step by step instructions with pictures.
http://servicemanuals.vstore.ca/product_info.php/pName/v21v19-mitsubishi-dm-repair-kit/cName/repair-kits
Apr 30, 2009 | Mitsubishi WS-55859 55" Rear Projection...
The green timer light just keeps blinking and the front control panel and the remote will not work. i tried the reset button and unplugging the tv with not change
you need to replace the capacitors on the DM . Very easy repair. You can get the V21 V19 dm repair kit at the following link which has the replacement capacitors and step by step instructions on how to do the repair. Its listed under the repair kit category.
Mar 25, 2009 | Mitsubishi WS-65869 65" Rear Projection...
Timer light flashes and tv wont turn on
The problem is the DM isnt completeing the boot sequence due to the failed caps. You can get the V21/V19 DM repair kit at the following link which contains the replacement capacitors and a CD with step by step instructions with pictures on how to do the repair. Heres the link.
Nov 14, 2008 | Mitsubishi WS-55511 55" Rear Projection...
Green flashing light and tv will not turn on
that is usually repaired by replacing the DM capacitors. You can get the V21/ V19 DM repair kit at the following link which contains the replacement capacitors and step by step instructions with pictures on cd so you can easoally do the repair yourself. Heres the link its listed under the repair kit category as the V21/V19 DM repair Kit.
Sep 27, 2008 | Mitsubishi WS-55511 55" Rear Projection...
MitsubishiWS65511
You have the V21 chassis when the led blinks constantly you need the V21/V19 DM repair kit which has the parts and step by step instructions with pictures on how to do the repair. And its less than 40.00 for the entire kit with free shipping. Here is the link its listed under the repair kit category.
Aug 14, 2008 | Mitsubishi WS-55511 55" Rear Projection...
Timer light flashing dont trun on, can you bypass the boards and run it like a monitor
You need the DM repair kit called the V21 / v19 DM repair kit which contains the parts and step by stepp instructions with pictures to repair the most likely cuase for that symptom, and its less than a service manual cost and they include the service manual for free as a bonus on the instructional CD. Heres the link its under their repair kit section
Jul 27, 2008 | Mitsubishi WS-55859 55" Rear Projection...
Blinking green timer light on Mitsubishi WS 55859
You can get the repair kit which has the capacitors you need plus a cd with the repair instructions and full service manual at the following link for 35.00 with free shipping. Your model is the V19 but the V21 is the same kit you need as the V19, 20 and V21 are the same DMs Just click on the repair kit catagory and you will see the V21 DM repair kit. and if you leave them a message they will include the info for the WS55859 on the CD.Heres the link.
Jun 30, 2008 | Mitsubishi WS-55859 55" Rear Projection...
Mitsubishi WD-52525 52" Rear Projection HDTV Logo
227 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
