Question about AOC 4 Vn 14" CRT Monitor
Burned resistor... no clue what is its value
My monitor AOC model 4 Vn got a short ciruit..a resistor burned out. the one near the box thing...i need to know the value of the resistance of the resistor which burned out so i can repair it..can i have a list of the values of the resistors?ill just see which resistor is missing in the list then buy it from a store
    Problem Solver:
  • 5 Answers
BrYze,
take a look and get the resistor number printed on the pcb. i might be able to give you what you're asking for.
Francis
Posted on Sep 01, 2008
I need to know the value of the Resistor "R1" in
Let us use a bit of logic to resolve this... I have an Axiom but it would be a lot of screws to take out to get to the part... so let us think about this. The resistor value starts with a "1" and we know it is 5% tolerance (gold). we know the resistor burnt up with likely 5 volts on it... Value could be 1000 ohms, however the voltages present (12 volts max) would NOT have burned up a resistor of 1000 ohms. The USB area is mostly 5 volts and across 100 ohms is only a quarter watt... not enough to really burn up a resistor... First thing is to MEASURE that the resistor s open... in spite of being burned, it MAY still be OK... these resistors now usually either open or remain close to their value. The resistor ALSO may be a fusible resistor intended to act as a fuse... Is the resistor open or not? is it near a resistance with a "1" as the first digit? If it is not open I suspect it is not all of the problem. In that case, look for a burned circuit trace on the board. If it is open, then MEASURE the voltage across the resistor with the power applied. If you find 5 volts, then it MIGHT be a 10 ohm used to limit the USB current to 500ma. Get back to me with your findings... I have unraveled many of these things...
Jul 12, 2011 | Music
Resistor burned on my Grandmother's Emerson model NR303TT
Hello Gio, Hi, a burned resistor is usually caused by a shorted part like a semiconductor or regulator, there are two things you should do, find the value of the resistor and what caused the resistor to burned, for the Resistor, the value is usually written on the board, If not you can find the value on schematics diagram (which is usually hard to find, but if you have one, fine), and on the same working model (very remote a possibility). IF this are not available, you now need the assistance of a technician.
Jan 26, 2011 | Emerson NR303TT CD Shelf System
Display is half.what can i do
try to find person to service your monitor.
i think there is broken coil or busted capacitor in its board
Mar 16, 2010 | AOC 4 Vn 14" CRT Monitor
I need a manual for a 22" AOC monitor
Suggest you go to AOC Support, Downloads>Manuals, and type the exact model of AOC monitor that you have.
Download the User Manual.
For example:
http://us.aoc.com/support/downloads
Product Category:
Left-click on the blue down arrow, to the right of this box.
Left-click on LCD Monitors
Model Number:
Left-click on the blue down arrow to the right of this box.
Scroll down, and left-click on the model number of your AOC LCD monitor.
After you have done this, a drop down menu will appear.
Where it states your monitor's model number, and the word - MANUAL, go to the right, and click on the white - Download.
The User Manual is in PDF file form. Give it a few seconds to download.
Jan 03, 2010 | Computers & Internet
Resistors R504 and R507 are burned, values are unknown.This is a Boka color monitor.I need the values of the resistors.
What is the serial number of your monitor!!
And which parts that's burned, can you tell me the exact locations...
Oct 16, 2009 | Computers & Internet
AOC 193FW White Display
I WANT ACER AL1921 DRIVES
Mar 11, 2009 | AOC 193FW LCD Monitor
Problem in monitor
1. First cheak the control panel microswitches. if any dry points on the panel ,solder the drypoints.
2. Replaced the microswitches
3. Cheak Control Proccer input voltage DC 5 V, from power section.
4. Changed the 7805 Reguletor. ( near to Control Procer )
Oct 03, 2008 | AOC LM729 17" LCD Monitor
Burn resistor
if its a 4 band resistor, use the following calculator...
http://www.dannyg.com/examples/res2/resistor.htm
if the resistor is a 5 band, use the following link....
http://www.sizes.com/materls/resistorcolor.htm
hope this helps!
Jun 16, 2008 | Dell E773C 17" CRT Monitor
AOC 5En monitor
replace new moitor....
Nov 13, 2007 | AOC CT720G 17" CRT Monitor
Width problem
Sometimes you will need to reinforce the whole circuit with new soldering metal as well. Mass produced circuitry sometimes uses very little of the stuff or uses soldering metal of poor quality.
Apr 09, 2007 | LG Studioworks 563N 15" CRT Monitor
AOC 4 Vn 14" CRT Monitor Logo
108 people viewed this question
Top AOC Computers & Internet Experts
Jerry Umali
Raj Patel
Are you an AOC Computer and Internet Expert? Answer questions, earn points and help others
