Question about Samsung SCX-4100 All-In-One Laser Printer
Lsu error my copy machine xerox has an error message lsu, what can i do to resolve it i'm having the problem where when printing, scanning or copying lsu error is displayed. but after restarting i becomes normal but after sometime again same problem arises. please resolve my problem.
  • 2 more comments
  • raju pathak May 11, 2010
    plase
  • HABIBUR RAHAMAN Aug 20, 2013
    printing & copy
  • MASIWAL RAMESH
    MASIWAL RAMESH Mar 04, 2014
    TONER COVER OPEN AND 2SENSOR SERVISE SO PROBLAM SOLVED
  • MASIWAL RAMESH
    TONER COVER OPEN AND 2 SENSOR SERVISEC SO SALL THE PROBLEM
LSU ERROR
Posted on Nov 22, 2008
  • Davie Kayendah
    Davie Kayendah Oct 13, 2014
    check lsu cables connection or change LSU unit or LSU Motor.
My printer shows error message lsu and i cannot print ......
Posted on Nov 17, 2008
What is thish problam
Posted on Nov 10, 2008
XEROX PRINTER SHOWING LSU ERROR
That means that someone from "Luisiana Southern University" has been trying to use you copy machine. Be sure no one from LSU goes near the Xerox!
Apr 25, 2015 | Xerox Office Equipment & Supplies
Describe 102-372 code problem in m24 xerox work centre
Solution : Power OFF the Printer, Wait 45 Seconds, Then Power ON CAUTION: If the machine is powered OFF / powered ON, all information that is stored in the machine's memory may be erased.
NOTE: Before powering OFF, make sure that all copy or print jobs have completely finished. Never power OFF in the following instances:
  • While data is being received.
  • While jobs are being printed.
  • While jobs are being copied.
  • While a scan is being executed.
  1. Power OFF the machine. The power switch is located on the front right side of the machine under the Control Panel.
    NOTE: Before the machine is powered ON again make sure the Touch Screen is blank.
  2. Power ON the machine.
    NOTE: When the power is ON, a 'Please wait...' message will be displayed. This message indicates that the machine is warming up and cannot be used. After 45 seconds, the machine becomes ready for use.
    If the issue is not resolved repeat steps 1 and 2 a second time.
Mar 07, 2011 | Xerox WorkCentre M-24 Color Copier
LSU Error keeps showing
LSU stands for Laser Scanner Unit. Depending on the model this should come up only if the services used required scanning such as copy, fax sending, scanning.
nevertheless if this is a continuous message you might need to check the connectors within the scanner which I advise an field call.
Apr 30, 2010 | Xerox WorkCentre M20i All-In-One Laser...
Xerox PE220 workcenter shows LSU Error message.
XEROX WORKCENTER PE220 , ITS SHOWING LSU ERROR . ITS NOT PRINTING OR COPYING ANYTHING . PLEASE GIVE SOLUTION
Dec 17, 2009 | Xerox Phaser 8500/DN Printer
LSU error message
Remove the jammed paper. Unplug the printer from the mains and PC. Inspect the rollers, etc for tiny paper piece(s) that may be stuck, or other debris. Try to clean rollers and make sure they are dry.
Keep printer unplugged for about 2 minutes and replug and try a test print.
Also make sure that you have waited long enough for the printer to heat up before giving a print job.
Finally, it could be an issue with the paper sensor. If this is the case, you will probably have to take the printer in for servicing..
Apr 27, 2009 | Xerox WorkCentre 220 All-In-One Laser...
LSU error code
Do you have the old cartridge? Because the message you are getting makes no sense if you can copy and not print.
The chip on the cartridge may be corrupting the machine software.
I will explaine why I say this. LSU fault, is a failure of the laser unit within the printer/copier. If it had failed, you should not be able to copy or print, The machine should not function. The laser unit is what makes the image on the drum. So neither print or copy should work if that was a true LSU code.
Did you purchase a cartridge made by another company other than Xerox? If so try returning it.
As I say, an LSU code should make the machine totally unpoerable, not partially functional.
I would try the old cartridge if you have it to see what happens.
Let me know if you have tried swapping cartridges and I will look into this more for you.
Sep 16, 2008 | Office Equipment & Supplies
Printer Problem
What model printer is this? The C2424 does not have a laser.
Are you 100 percent sure it is a model C2424?
There is no LSU status code for that machine.
May 14, 2008 | Xerox WorkCentre C2424DN All-In-One Laser...
Lsu error
LSU indicates a laser problem.
What is the model number? I can give you more information with the proper model number.
Thanks.
Dec 27, 2007 | Xerox Phaser 8500/DN Printer
Machine does not copy
LSU Error occurs when your printer printhead is damaged. Change your printer printhead, the printer will be ok.
Aug 25, 2007 | Dell 1600n All-In-One Laser Printer
Samsung SCX-4100 All-In-One Laser Printer Logo
2,296 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
Victorman
Victorman
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
