I have a karcher 411 A jet washer, there doesn't seem to be enough pressure to do the job. I have bought a new wand but it doesn't seem to make any difference, any ideas, what am I doing wrong
  • Washing Mach... Master
  • 19,396 Answers
Check to see if there's good water volume coming through the hoses attached to the washing machine. If there is, check to see if the screens inside the water-inlet valve are clean. (The water-inlet valve is the device on the washing machine that the fill hoses are attached to.) If they're clean, you probably have a defective water-inlet valve. If so, you should completely replace the valve.
Posted on Aug 31, 2008
How to connect the telescopic jet pipe to my Karcher K7?
Karcher utilizes a europeon fitting known as 22 mm female out of pump need to know type of fitting on wand they have adapters .telescopic wands may be standard either 1/4" quick disconnect or national male pipe thread
Aug 20, 2014 | Karcher Garden
My Karcher 330 M has blown two water inlet ( Garden hose inlet ) elbows. Replaced one and then after about 5 min operation shut off the valve on the wand and immediately the new elbow split the same as the...
I have a larger gas powered karcher, just make sure the water going to your karcher is not obstructed from its path. on mine i bought a goodyear hose that can be purchased at northern tools or any hardware store. and use it just for pressure washing. good luck!
Dec 23, 2010 | Karcher PSI Electric Pressure Washer
Karcher pressure washer works only with low pressure
The inlet screen orientation is of no consequence. Either way should work fine. Check two things...
1) Many of the spray nozzles have a high and low setting at the tip of the wand (where the water comes out). See if your nozzle has any "Push-Pull" movement (with the unit turned off). If so, it might be set in the "LOW" setting and needs to be changed.
2) Located on some SIDE MOUNTED pumps is a "Variable-Volume" adjustment. It may need to be turned to increase the flow and should be marked with a plus (+) and minus (-) along with direction arrow.
NOTE: If your pump is mounted on the bottom of your engine you will not have this adjustment.
Hope this helps!
Sep 30, 2009 | Karcher G3025OH Pressure Washer
Where can i get a new hose for a1600 psi jet washer? Hose has a leak in it and we are not having any luck finding a replacement locally. Washer was purchased at either walmart or Canadian Tire.
I have an older Karcher Pressure Washer and I am unable to find the model number. This is the info that I have: 79C2, Volume 1.9, Pressure 1400, Serial # 800983493B, 120 Bar, 60 degree C,
QC506-877. I need the model # to order a replace gun and/or wand. thank you
Jul 14, 2009 | McCulloch FHH18A Electric Pressure Washer
Karcher pressure washer trigger problem
The wands that it will not run with would most likley have a little dirt in the tip of the nozzle. This would not allow the water to flow through in turn activating the pressure switch and shutting the machine down
Jul 05, 2009 | Karcher K2.26 Electric Power Washer
Karcher K 3.68M Electric Pressure Washer. Wand trigger Locks Up.
Sounds like the pressure valve is broken thats why you cant depress the trigger , the valve is on the pump , i would suggest taking it to a repair shop as they are fiddly things to fix
Jun 04, 2009 | Karcher PSI Electric Pressure Washer
Cant change the high pressure hose on a Karcher
On the Kärcher, you have a bayonet mount at the base of the tip end of the pistol grip. This is where you attach different types of nozzles and gadgets after having removed the existing sprayer tube. Just push in and turn a quarter of a turn, then you pull it off the pistol grip. The hose is possible to remove from the machine as well, an ordinary threaded mount but since you need the pistol grip to regulate on/off this is probably not what you want to do. If the telescopic wand is made by Kärcher it should be very easy to snap it into place just like when you removed the sprayer tube/nozzle. If the attachment was made to fit Alto washers there is an inexpensive adapter that works very well. Good luck!
Jun 03, 2009 | Karcher G 2600 VH Gas Pressure Washer
Washing Machines Logo
249 people viewed this question
Top Washing Machines Experts
