Question about Sony Cyber-shot DSC-W50 Digital Camera
After reseting the dsc w50, becouse of e .91.01., flash is not working
When the error .91.01 appear i did as it is told in this web and reset the camera from the main menu, however, even the error stop appearing i find myself in a new dilema becouse the flash is not working, every time i try to take a picture with flash, one of the lights above starts flashing and on the screen is displayed an image like the flash trying to work. I've tried to restar the camera once again and the problem doesn´t seems to go away and even i can take really good pictures when daylight, what is the point of taking pictures on night, i like to take pictures avery time i go out for a drink with my mates, so please help me out... i am desparate
  • 3 Answers
Hi worked for me , remove battery take apart, discarge the capistor i think 320 volt DO NOT SHORT THE CAP !!!when dead voltage on cap ,turn on reset all camera and try good luck
Posted on Sep 04, 2008
I have a camera sony cybershot DSC-W350 and flash is not working. And I receive an error message E:91 01. What do I do?
Hi. Thanks for your question.
To get your camera back in working order you need to reset it to factory settings. Please click on the link below for a video from Sony website on how to perform reset.
http://esupport.sony.com/perl/tutorial-display.pl?tut_id=374&mdl=DSCW50
Thank You for using FixYa.
Jan 14, 2011 | Sony Cyber-shot DSC-W50 Digital Camera
My camera is showing e91 error and no flash
It is the falsh module that has broken and needs replacing. (probably not worth it on a W50 due to cost.
but try the following.
I have a method to stop the E:91:01 error flashing on the screen.it were not solve the flash function but atleast you can use the camera without flash.
1)at setup do a initialize.
2)go to flash function to turn off the flash (must do it fast,b4 the E91:01 appear,if not you need to reset it again )
by now E91:01 will never appear.you can use it like normal,be sure not to turn on your flash again or go to night mode.if not you need to perform step 1 & 2 again.hope it help.
Feb 03, 2010 | Sony Cyber-shot DSC-W50 Digital Camera
Sony DSC-W50 camera Error msg E:91:01
Please follow the instructions given below
1. Turn OFF cam
2. Remove the battery or the power supply
3. Turn the switch to CAMERA for about 30 sec
4. Turn the switch to OFF
5. Install the battery or power supply
6. Turn the switch to MEMORY
7. Open the LCD cover and press the RESET button ( small inner button )
8. You will be prompt to adjust date/time. Do it
9. Take some pictures
Second step:
Let me know, if need further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Oct 07, 2009 | Sony Cyber-shot DSC-W50 Digital Camera
E:91:01 in DSC-W80
I can't recall all the Sony error codes off the top of my head, but I believe E:91 is that your flash is not working.
Can you take pictures at all or do you get just the error code? If you can take a picture with the flash off then your flash needs to be replaced.
If you can't use the camera you need to first press the reset button, then reset all camera settings to default.
1-3. PROCESS AFTER FIXING FLASH ERROR
When "FLASH error" (Self-diagnosis Code E : 91 : 01) occurs, to prevent any abnormal situation caused by high voltage, setting of the flash is changed automatically to disabling charge and flash setting. After fixing, this setting needs to be deactivated. Flash error code can be initialized by the operations on the HOME screen.
Method for Initializing the Flash Error Code
Initialize
Initializes the setting to the default setting. Even if you execute this function, the images stored in the internal memory are retained.
1 Select [Initialize] with v/V/b/B, then press z. The message "Initialize all settings" appears. 2 Select [OK] with v, then press z. The settings are reset to the default setting.
To cancel the resetting
Select [Cancel] in step 2, then press z.
· Make sure that the power is not disconnected during resetting.
Hope this helps.
Thomas D.
Owner, Darntoothysam com
Affordable Digital Camera Repair
Sep 07, 2009 | Sony Cyber-shot DSC-W50 Digital Camera
Flash error on sony cybershot
Try to resetting (initializing) it. But if the problem repeats soon, look for service.
Aug 30, 2009 | Sony Cyber-shot DSC-W50 Digital Camera
Sony cyber-shot dsc-w50 problem
When “FLASH error” (Self-diagnosis Code E : 91 : ** ) occurs, to prevent any abnormal situation caused by high voltage, setting of the
After fixing, this setting needs to be deactivated. Flash error code can be initialized by the operations on the Setup screen.
1 Select [OK] with v on the control button, then press z.
The message “Initialize all settings Ready?” appears.
• Make sure that the power is not disconnected during resetting.
Jul 26, 2009 | Sony Cyber-shot DSC-W50 Digital Camera
Error E91:01 on DSC H7
If the camera works in all other respects, then that has something to do with the flash setting or some other setting in the menus. But this sounds like something with the flash directly.
Here is a link which may be able to help on the DSC H7: http://www.aakatz.com/whitepaper/whitepaper/appendix2.htm
Try also to reset all the menu setting back to what it was for the factory. Most digital cameras have a setting for that, and usually is something like "RESET ALL" or something close to that.
If nothing works, then the camera needs repair. This is an error to do with the flash only, it appears. So some of the internal parts could be weak, thus causing the error.
Jul 27, 2008 | Sony Cyber-shot DSC-W50 Digital Camera
Flash does not turn on
A camera malfunction has occurred. Reset the camera, then turn the power on again.
Reset button is under battery lid.
Feb 13, 2008 | Sony Cyber-shot DSC-W50 Digital Camera
Sony Cyber-shot DSC-W50 issues
hi there
you can try doing this and it should work and solve the problem for you
  1. Press Menu button
  2. togle across from REC Mode to setup
  3. togle down three times from camera to setup 1
  4. togle across into sub menu
  5. togle down from four times to Initialize
  6. togle across again to the sub-menu
  7. togle up from cancel to OK
  8. press center button to accept the OK choice
  9. Screen changes and so press okay again
  10. It should restart the camera
  11. Opening on the 'Clock Set' screen
  12. togle down to cancel and use the camera and make sure that you have the camera to flash, if it works try again in the Auto function.
  13. If it is still not working do not worry follow the steps again two or three more times, As this is generally a software error message and not a hardware malfunction.
Oct 01, 2007 | Sony Cyber-shot DSC-W50 Digital Camera
Sony DSC-W50 Flash Error code-E:91:01
I have a method to stop the E:91:01 error flashing on the screen.it were not solve the flash function but atleast you can use the camera without flash. 1)at setup do a initialize. 2)go to flash function to turn off the flash (must do it fast,b4 the E91:01 appear,if not you need to reset it again ) by now E91:01 will never appear.you can use it like normal,be sure not to turn on your flash again or go to night mode.if not you need to perform step 1 & 2 again.hope it help.
Jul 25, 2007 | Sony Cyber-shot DSC-W50 Digital Camera
Sony Cyber-shot DSC-W50 Digital Camera Logo
269 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
Are you a Sony Camera Expert? Answer questions, earn points and help others
