Power When I got back from my trip to Florida, I couldn't get my printer powered up. I went to the HP Helpdesk, hoping they would tell me where there was a fuse or breaker I could deal with. I was directed to your solution; bypass the surge protector. As soon as I plugged the printer into the wall, the display lit up like a Christmas Tree. Thank you for a simple solution I probably would have not come with by myself (after all, everything else plugged into the strip was working OK). Thanks again. SirTomMorrow Port Orchard, WA
  • 181 Answers
Glad to hear it worked - thanks for the positive feedback!
Posted on Nov 14, 2008
My printer hp tell me ink system failure "Error : 0xc18a0001 . can U tell me what to do ?
1. use the power button to turn off the printer. Take the Ink cartridge out, put it back in. Turn the printer on again, and test. If this doesn't resolve the issue, then
2. unplug the printer. press and hold the power button for 30 seconds. Plug the printer back in, and turn it on- and test. If this doesn't resolve the issue, then
3. call HP for assistance, as the printer may require repairs. There also may be a firmware update they can provide for the unit- I seem to recall a problem on some models of HP printer with buggy/corrupted firmware.
Hope this helps.
Jun 30, 2010 | HP Photosmart C5180 All-In-One InkJet...
Legal size copies
Your printer doesn't support Legal size to Scan and Copy, you can scan/copy it by reducing the size of the paper from the menu. 10% will fit since the actual paper size supported by your printer is 8.5X11.7inch while the legal size is 8.5X14inch. Good luck. For more info check out here : http://h10010.www1.hp.com/wwpc/us/en/sm/WF06b/18972-18972-238444-12019-3328086-2511708-3643610-3643611.html
May 15, 2010 | HP Officejet Pro L7590 All-in-One InkJet...
How to change a fuse in the hp 2800 printer, power up problems
There are 2 fuses inside the power supply unit.
The hard part is getting to the power supply! The power supply is located at the left side of the printer and in the front (the opposite side of the cartridges).
You have to remove the side and top covers.
There are some hidden screws. One is under the button faceplate that you will also have to remove. The entire procedure is tricky especially without a service manual. Unfortunately I couldn’t locate a manual.
Caution always disconnect the power lines and allow some time for capacitors discharge before you attempt any repairs.
I hope you have some luck with yours !!
Nov 13, 2009 | HP Business InkJet 2800 Printer
My Ricoh AP610N Printer worked great until I moved it in my car from Florida to North Carolina. Ever since, it blows my home circuit breaker when I plug it in. If the printer switch is turned off I can...
you definitely have a short somewhere, my first impression would be a safety switch (covers) or the FUSER or scanner assy ( if has one) both of which use high ac voltages for the lamps
Jun 06, 2009 | Office Equipment & Supplies
Lost power to printer after cleaning mirrors in optical box
Check the following.
Power switch on the back of mqchine ON.
Power cord firmly in place at both ends.
If there is a fuse or circuit breaker next to the power in connection, confirm it is good or reset.
All covers properly closed.
All internal units in correct position.
Hope this is of some help.
ed
May 19, 2009 | HP Color LaserJet 2600n Printer
Vista compatability download for my HP PSC 1500 all-in-one series
The 1510 model is under the 1500 series. It is the same software for your printer
Aug 06, 2008 | HP PSC 1510 All-In-One InkJet Printer
Error 13-jam paper HP Laser 4+
HP LaserJet 4, 4m, 4 Plus and 4m Plus Series Printers - False Error Message 13 PAPER JAM ISSUE: After clearing all jammed paper from the HP LaserJet 4, 4m, 4 Plus, or 4m Plus series printer, the display still reads 13 Paper Jam . Even after cycling the power off and then back on, the error remains. SOLUTION: Open the rear door of the printer. There is a paper sensor near the upper right hand corner of the fusing assembly (just below the right edge of the long yellow warning sticker on the fuser) that can cause paper jam error messages even when there is no jammed paper in the printer. Toggle the thin black plastic lever up and down to make sure it is not stuck or sticky. The lever should be in the down position before closing the back of the printer. If the lever is stuck or missing, the printer will generate a false paper jam message. Hope it will help you !
Apr 02, 2008 | HP LaserJet 4 plus Printer
Language setting
Try this: 1. unplug all cables from back of unit (turn power off as well) 2. while the printer is off hold down the * and 5 3. while holding them turn printer on 4. continue to hold buttons until display reads 'Permanent Storage Init' 5. then release buttons 6. at the end of reset it will ask you to select language and location, just press enter then 1 to confirm Hope that works!! Ed PS. You could have picked an easier language!!!
Jun 12, 2007 | HP LaserJet 3055 All-In-One Printer
41 people viewed this question
jasbo
jasbo
