Question about Maytag Washing Machines
I have a coin rattling around in my front load washer. How can I get it out?
    President:
  • 1,462 Answers
You haven't given make or model
however, usually the easiest way to get at foreign objects is to remove the heater.
undo back panel and you will see heater held in by 1 10mm nut in centre. loosen nut and prize heater out. you can then see into the gap between tub and drum and fish coin out.
a few types have the heater mounted in the front which makes it more difficult
Posted on Aug 31, 2008
We have a dryer fin with something rattling around in it. Do the fins come off?
Need a model number for the dryer for a more definitive answer--usually you would have to open the top cover to expose the drum. Depending on the model dryer, some baffles(proper name) are screwed onto the drum, some have plastic tabs which must be carefully pushed in order to remove the baffle. Most likely, the rattling is caused by coins left in pockets--they won't damage the dryer but can be irritating to listen to. Front load washers are notorious for trapping coins in the baffles of the rotating baskets--and that is A VERY EXPENSIVE REPAIR if you want to have the coins or objects removed.
Aug 14, 2015 | Dryers
Washer makes a rattling sound when it starts the spin cycle. Sounds like gears stripping or something loose rattling around. Now it won't spin after the wash cycle. It will spin if I put it on the...
Sounds like you cannot activate youre imagination maybe Ill do this for you one time here goes ~: You or someone left coins in your pockets jeans cardigan whatever they got out of garment while in the wash spin and worked themselves into the machine and now its bug-gerred innit?
Jul 30, 2017 | Bosch Axxis WFL 2060 Front Load Washer
My GE WSLP 1100 makes a grinding/"coin rattling" before the spin cycle. what's going on?
You have something rattling around in your water pump. It might be a coin or a piece of fabric getting in the way. There is a cap you can open to have a look. It is on the bottom right at the back of the machine. Hope this helps.
Oct 17, 2009 | GE Spacemaker WSLP1100D Top Load Washer
Front load washer- coin removal
Hi, The coin is probably inside the baffle that tosses the clothes around. I believe this nodel has a screw that holds the baffle in place. I hope this helps you. Please let me know if I can assist you further.
Thanks
Vic
May 28, 2009 | GE WSXH208A Front Load Washer
LG WM2077CW small item trapped behind drum
you would need to remove bottom exit rubber pipe from drum and use a flash light to free coin or screw,hope this helps
May 27, 2009 | LG WM2077CW Laundry XL Front Load...
Coin trapped between rotating drum and casing
Get underneath the machine and remove the big black house coming directly out of the drum,this is held in place with either a screw tie or pinch type tie.
Put the machine back level and see if the coins drop out (they should) or have a feel around inside the drum.
Please make sure machine is unplugged and empty before carrying out this procedure.
Some water will come out of hose.
Nov 19, 2008 | Zanussi ZWF1430W Front Load Washer
Coins in my front loader
remove element, remove coins with magnite telescopic type.replace element
Nov 06, 2007 | GE WSXH208A Front Load Washer
Washing Machines Logo
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
