Question about Acer Computers & Internet
BIOS SETTING IS NO ADMINISTRATOR - Acer Computers & Internet
  • Roberta Smith
    Roberta Smith May 11, 2010
    it has a password then ?
  • Acer Master
  • 3,051 Answers
I think that dee is refering to a password that is not known if that is true then here is what yo will need to do turn off the computer and remove the side cover locate the bios jumpers you will notice that there are 3 pins and 2 of them are covered by the jumper, now remove the jumper from the pins that are covered and move it down 1 pin now u should have the last 2 poins covered and the top one showing ok now start up the computer and it will boot into the bios screen you will see the password section and just click on it and it will ask you if you want to remove allof the passwords press yes ance this is done it will tell you that you will need to place the jumper pin back in the original position thatt it was in so exit out of there and turn off the computer and replace the jumper back to wherre it was and just restart the computer if the administrator comes up again just press the esc key ok i hope that this will fix your problem ok best regards mike
Posted on Aug 31, 2008
Slow startup now that I upgraded BIOS
you can't reset bios. download the old version from DELL support.
Run cmd (as administrator, right mouse click and "run as administrator"), write cd Desktop (if u save here) and write bios name with /forceit (ex. N5010A07.exe /forceit)
Feb 15, 2014 | Dell Inspiron 530 Desktop Computer
How do i recover toshiba tecra 730xcdt windows password?
If a user account needs to be reset, logon as the administrator or as a user with administrative access, and then follow these steps:
Click Start, point to Programs, click Control Panel, double-click Administrative Tools, and then double-click Computer Management.
Expand the Local Users And Groups object under System Tools, and then click the Users folder.
In the right pane, right-click the appropriate user object, and then click Set Password.
Type the appropriate password, and then click OK.
Click OK to acknowledge that the password change succeeded.
Close the Computer Management console and Administrative Tools windows.
The user can log on with the new password.
To Reset the Administrator's Password
Log on to the computer as a user with administrative privileges, and perform the steps
listed above for the Administrator account.
If the Administrator password needs to be reset, and there are no other users with administrative access, there is no way to recover the password and the operating system will need to be reinstalled.
or if you have not set a bios password
restart your computer you will see on your screen to press a certain key to enter bios usually the Delete or the F2 key
press and hold that key to enter set up BIOS where you can set or remove your password
this will differ depending on you computer and bios
hope this helps
Aug 08, 2012 | Toshiba Tecra 730XCDT Laptop AC Power...
Reset log on password
hope this helps
Aug 03, 2012 | Dell OPTIPLEX GX60 Motherboard
Need the bios password on my gateway solo 9500
When you boot up to the log in screen type in administrator as user to log in if you cant log in
during the boot up process you will see on the screen for a short amount of time press a certain key to enter set up press and hold that key during the boot up process to enter BIOS using the arrow keys scroll down to set user password or supervisor password you can change or remove your password from there
also
The most common way that we know on how to reset or clear the BIOS password is to physically remove the power from the computer by disconnecting the power plug and then removing the Cmos battery for 30 minutes from the motherboard. Another way is to reset the clear CMOS jumper on the motherboard itself.
Both of the 2 methods mentioned works because most motherboards use a battery to sustain the BIOS/CMOS settings for the motherboards PROM chip. So by cutting off cmos the battery power, the BIOS/CMOS settings will be erased.
cmos battery Under the keyboard or bottom of laptop - If you are working on a laptop computer the location of the dipswitch (almost never a jumper) can be under the keyboard or on the bottom of the laptop in a compartment such as the memory compartment. Although on some motherboards the Cmos battery is soldered in
Often many users will leave the administrator account alone or have other accounts with administrator rights. If you're not logging into the computer as administrator or have other accounts follow the below steps to reset your other accounts password.
Reboot the computer into Safe Mode
When logging into Safe Mode you should be prompted with an option to what account you wish to use. Select the Administrator account. If prompted for a password try pressing Enter on the keyboard for no password. If this does not work, try other passwords you may have used. If you're unable to log into the Administrator account skip to the next suggestion.
Once you've logged into the Administrator account open Control Panel and User Accounts.
Oct 04, 2011 | Axiom Audio Axiom 40GB for Gateway Solo...
How do i reset the bios password for my lenovo a310?
User passwords:
Power on
BIOS execution can be controlled by a Power On Password. This password is set in the BIOS Configuration screen, accessed by pressing the F1 key after pressing the power on switch to turn on the PC. If the person at the keyboard does not know the Power On Password, then BIOS execution halts.
Hard drive
The hard drive is controlled by the Hard Drive Password. After the Power On Password is entered, the person at the keyboard must be able to enter the Hard Drive Password, otherwise the disk drive will not spin up for use. Like the Power On Password, the Hard Drive Password is set in the BIOS configuration screen.
Administrative passwords:
Each of the two user passwords can be controlled by a Master or administrative password. If the administrative password is not set, then anyone who knows the user password can change it in the BIOS configuration screen. If the administration password is set, then it is impossible to reset the user password unless you know the administrative password. The Supervisor Password is the administrative password for the Power On Password. The Master Hard Drive Password controls the Hard Drive Password.
Password Recovery is a feature of Client Security Solution 6.0. This makes it possible for an end user to recover from the problem of "I forgot my Power On Password or Hard Drive Password."
c.gif fw.gif Client Security Solution
Mar 13, 2011 | Lenovo IdeaCentre A310 Laptop
How to disable hp pro book 6455 bios password
To resolve this issue, create a BIOS administrator password and delete previous ProtectTools user logs by following this procedure:
  1. Download and install the latest SSM utility (SP42536).
    Softpaq Description Information Download HP System Software ManagerVERSION: 2.10 Rev. A SP42536 Instructions/Information SP42536 File Download
  2. Navigate to c:\Program Files\Hewlett Packard\SSM .
  3. Access biosconfigutility.exe to reset the BIOS administrator password.
    a. From a command prompt, navigate to the SSM folder.
    b. Type biosconfigutility.exe to start the utility. A list of commands displays.
    c. Type /newsetuppassword:"password" to create a new BIOS administrator password.
    d. Close the command window.
  4. Restart the notebook PC and press F10 at startup.
  5. Log in using the new BIOS administrator password.
  6. Choose User Management and delete any previous ProtectTools users.
  7. Save the new settings and exit startup.
Dec 09, 2010 | HEWLETT-PACKARD HP ProBook 6455b Notebook
What to do when forget my laptop password I set from the bios setup?
if is the windows administrator password press F5 then you enter safe mode and remove administrator password if is the bios password remove the motherboard batery for 5 seconds
Aug 18, 2010 | Dell Inspiron 1525 Laptop
Bios problem
you have to remove bios battery once. after remove start your system enter to bios its all resetted. switch off system and put bios battery and restore default setting for bios.
Jun 17, 2010 | HP EliteBook 6930p Notebook PC
Hts541680j9s wont take password
here are 2 password type first 1 is bios password if tell me about your bios password it prompt when u powerup follow procedure below
For that you need to reset factory defaults settings for bios.
For reset bios u have to open back side of your laptop then u find motherbord circuit there.
pull cmos cell on motherbord for 15 minute then it reset to defaults.
Also u can reset with jumper settigns read carefully on mother bord there is 1 jumper near cmos cell u read there " bios reset or clear"
It is on 1-2 position right now set it in 2-3 position then power up then all bios settings are reset.
then again set it in 1-2 its original position.
Then it not want password.
And if u tell about windows password
Then when you power up the computer press F8 key then enter in safe mode then wait until it prompt for user password
then enter in administrator then if u able to enter then reset your password.
But if u set and forgot default administrator password then u should need winxp recovery disk.
Jul 24, 2009 | Acer Aspire 5720-6661 Notebook PC
I need to remove the administrators password for Dell Inspiron B130 service tag ends in 595B
Dell Laptop with bios or hard drive password set ? Unlock your dell laptop using the link below if it display a message that says "this computer system is protected by a password authentication system, you cannot access the data on this computer without the primary or administrator password, when you turn on the computer. This message is what you get if the BIOS is protected by a password. or you get system disabled
Go to: http://dell-inspiron-b130-bios-password.biospwd.com to get your dell bios password authentication and get full access to your dell computer, they can unlock almost all dell laptop such as dell inspiron, xps, latitude, precision, studio, vostro
May 28, 2009 | Dell Inspiron B130 Notebook
Computers & Internet Logo
41 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
