Question about Epson RX620 All-In-One InkJet Photo Printer
My epson stylus photo R230 can't print
My printer can't print anything. the ink indicator lamps blink (in red) and i can't even print any documents. what can I do to solve it ? please hlp. thanks.
  • 1 more comment
  • Edysing Feb 27, 2009
    I have Epson R230 with the same problem 2 red led blinking one at a time, cannot do anything. Please help ..somebody?
  • bheygene May 11, 2010
    pls. help me how to reset my epson stylus PHOTO R230
    pls. send me the program file to reset thaks.. more power.
  • Pauline Dec 28, 2012
    I have same problem (2 red lights blinking...) How can i solve?
How can i install epson stylus photo r230 in windows xp?
Posted on May 26, 2009
  • Epson Master
  • 419 Answers
@Edysing: That indicates the waste ink pads have reached what the printer considers to be saturation point.
The solve this you need to download the SSC utility from here
Note: Make sure you're using a Windows XP machine (it won't work with Vista or Mac)
Install the utility as normal and then configure it via the configuration tab to your R230 printer and the appropriate printer model "Epson Stylus Photo R220/R230"
Then:
  • Close the utility and locate the little printer icon in your system tray (bottom right corner of screen)
  • Right click on this icon and scroll up to "Protection Counter"
  • Click on the "Reset Protection Counter"
  • Locate and click on the "Clear counter overflow" option too
  • Now turn off your printer, wait a few seconds and then turn it back on again
You should now find your printer has reset the waste ink counter and you can printer again.
With that done you should then decide how to redirect your waste ink to an external tank.
Google can help with a few kits out there or you can always find instructions for creating your own...
DO NOT ignore the waste ink issue though as the pads will become oversaturated and leak ink if you leave the issue unresolved.
Hope that helps.
Note: Eagleflh is the owner of "Think Green" and shouldn't be promoting his products on here (he's not a customer no matter how much he pretends he is)
Posted on Mar 09, 2009
Two red lights are blinking
Posted on Jan 08, 2009
I only copy black & white documents.Have changed 2 B & W inks.Never print a color things. Today after change a new B&W ink / the blinking light "color" check appeared.The machine...
That is an indication of regular functionality from device. Red on device is indication of power on cables ready to capture prints. Usually with devices that has several lightening indication displays, a yellow would be ready to produce print request where finally green is indication that print asignment has been attained succesfully. once a new ink was installed, attempt to print documents to ascertain the status to devcies.
Feb 17, 2011 | Canon PIXMA MX310 All-In-One Printer
2 lights flashing
What is the flash pattern?
If the red paper light and the red ink light are blinking in an alternating pattern, then you may have a foreign object or piece of paper blocking the movement of the print head. Turn off the printer, open the printer and look for anything in the printhead path. Remove anything that doesn't belong. Some printers have a strip that the print head travels across that can sometimes come out of position. This can be repositioned by moving it up and down as well as forward and back to align in a guide on the back of the print head.
After clearing the obstruction, close the printer and turn it back on. If the error persists, then the unit needs service.
If the red paper light and the red ink light are blinking together and the green power light is off, then the printer has an internal error. Turn it off and then back on. If the error persists, the unit needs service.
One internal error could be the waste ink absorber is full. These pads are below the printhead and absorb ink during cleaning cycles. To reach them is messy and takes disassembling the printer from the top. This may include removing the print head. Pull the pads, blot the ink off them and the places where they fit in the printer. Run clean water over the pads until the water remains clear. Dry the pads (use a hair dryer to speed the process). Then reassemble the printer.
Next navigate to http://www.epson.com/cgi-bin/Store/support/InkPadsForm.jsp and fill in the model and serial number of the printer (as well as the other required information). You will get a link to download a reset utility for Windows. Run this tool to solve the error. Do not run this utility until the pads are replaced or cleaned; waste ink will get everywhere inside the printer and over your documents.
I hope this helps.
Nov 19, 2010 | Epson Stylus C86 InkJet Printer
My mfc240c says to replace the yellow ink cartridge but I don't want to spend money on that if the 'light bulb' is ruined. When I turn on the machine, I don't see any light for scanning or copying. ...
By the "light bulb," do you mean the scanner lamp? That lamp should only turn on when you are actually scanning, faxing, or copying a document. You should be able to still use the machine to scan and fax, even with the yellow ink empty. Try scanning a document to see if the scanner lamp comes on.
As far as printing or copying goes, you won't be able to print or copy anything until you replace the yellow ink, even if you try printing in black and white only.
Apr 19, 2010 | Brother Multi-Function Center MFC-240C...
Red paper and ink lights blinking
red paper light is blinked as it is indication that plz insert paper in your printer, and ink light blinks because your printer is low on ink, kindly get your printer cartage refilled.
Mar 19, 2010 | Epson Stylus 1400 InkJet Photo Printer
Blinking teardrop light blinking
Blinking drop light on HP6122 signifies an ink cartridge is out of ink. There are two cartridges -- color (larger of two) and black (smaller of two). Blinking drop light only indicates either, but not which. HP6122 service software and print driver are available from HP website http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?product=83027&lc=en&cc=us&dlc=en&lang=en&cc=us. HP6122 service software has a printer maintenance utility which includes ink cartridge monitor. Use the maitenance service utility to determine which (or both) cartridge is out of ink. With cartridge replacement, printer should automatically print test page, then reset and be ready for printing from your computer. To clear printed documents from print que, open the HP6122 print que via control panel > printers > double-click on HP6122 driver to show que > select document tab > select cancel.
Mar 26, 2009 | HP DeskJet 6122 InkJet Printer
My r220 epson will not prit anything
The ink indicator permanently on indicates an ink cartridge problem, (not that the protection counter needs resetting). The status monitor picture of the ink cartridges should show which cartridge is at fault, it will have a red X on it. The cartridge is empty, faulty, or in the wrong position. Alternatively, you may have an internal fault e.g. with the system board. But change the indicated faulty cartridge first.
Jan 09, 2009 | Epson Stylus Photo R220 InkJet Printer
Epson R230 ink & Paper Lamp Blinking
could someone show us how to open the r230? im having hard time cleaning the waste ink pad because i cannot open the r230..
Aug 28, 2008 | Epson Stylus Photo R200 InkJet Printer
Both ink cartridges?
Both have to be in the printer,even if one is empty.
Read this HP document on the blinking lights code:
http://h10025.www1.hp.com/ewfrf/wc/document?lc=en&cc=us&docname=c00035263&dlc=en&product=71896
copy and paste the complete link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Aug 03, 2008 | HP DeskJet 5550 InkJet Printer
Repair manual for epson photo r220
Here is the link for your printers document and manual
http://www.epson.com/cgi-bin/Store/support/supDetail.jsp?BV_UseBVCookie=yes&infoType=Doc&oid=60202&prodoid=58654761
pls dnt 4get to rate, thanks
Apr 20, 2008 | Epson Stylus Photo R220 InkJet Printer
Epson RX620 All-In-One InkJet Photo Printer Logo
1,933 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
