Question about Epson TM-U220 Matrix Printer
Connecting Epson TM U220D printer with Laptop (having Windows XP)
I am not able to connect Epson TM U220D printer with my Laptop (Compaq series with Win XP).
I bought a USB to parallel port convertor, but "Device not recognized" error does not go. The UBS port shows "Unknown Device" .
Please suggest.
Thanks and regards,
Amit
If you have the Cables2GO USB to Parallel converter, it is a pain to get working.  Go to Radio Shack and buy the GigaWire USB to Parallel.
Then once plugged in, go the printer that will be using the converter.  Go to the printer properties, select the PORTS tab.  Select the 'VIRTUAL PRINTER PORT FOR USB'.  That worked for me!
Posted on Nov 12, 2008
Please verify if you properly install the port converter, its drivers.
Posted on Oct 19, 2008
Epson TM-U220D. Parallel to USB connection. Which drivers should I install?
Hi Ali
The problem by doing this is that not all Parallel to USB cables work right out of the box with your equipment.
What you need to do first is make sure that your computer sees the device through the cable. Then when it prompts you for the drivers for the printer install the driver set (parallel) the connection should not matter at this point. However the step of the computer detecting the device first is very important.
I hope this helped.
Philipp
Apr 16, 2014 | Epson TM-U220 Matrix Printer
To install Epson printer TM-U220PD Model M188D
What is the baud rate of the EPSON TM-U220D MODEL M188D?
Feb 14, 2010 | Epson TM U220D Printer
Hallo there Am currently using epson u220d and want it to in print in black......not in colour and am using windows xp hp machine.How do i configure it? regards Erastus
printer options - printing defaults - settings you have color print mode. Set it ti monchrome
Also at printer properties you have option to set the printer using only black cartridge.
Jul 20, 2009 | Epson TM-U220PD Matrix Printer
TMu220 serie 25 for usb
Hi
option 1 - buy a pci parallel card
option2 - buy a cable serial 25 to usb the cost is $30 dlls
Oct 26, 2008 | Epson TM-U220 Matrix Printer
Epson TM-U220D Receipt Printing Problem
mau download driver epson tm-u220d ga ada...
klo mau cari dimana yah
Oct 21, 2008 | Epson TM-U220 Matrix Printer
How can I connect an Epson TM U220D Printer to a PC?
You can connect it using a SERIAL NULL MODEM cable, You can download the driver from epsonexpert.com after you register they will send you username and password to login, go to technical resources and select printer model and download the APD304E driver
May 02, 2008 | Epson TM U220D Printer
Epson TM-U220D Printer Status
Hi, On the PC that will not display printer status correctly, pls run MSCONFIG (start, run, type "msconfig", OK); in the System Configuration Utility Window, click on the tab Startup, see if the EPSON Status Monitor is present and checked. If it is not present, check if you have Lavasoft Ad-Watch or similar program running. This prevents the EPSON Status Monitor from registering and running correctly. If such a program is running, temporarily remove Automatic setting and reinstall the EPSON Status Monitor. Accept any registry modification at this point. Restore all settings once installation is finished. If still a no go, try wiggling the parallel connector a bit and make sure it is snug and fit. If all else fails, you may have to consider: Installing to only 1 PC, share and make it a print server assuming you have networked all your PCs; or re-installing Windows (Ouch!) Hope things work out for you. Pls post again how things turn up. Kind regards.
Jul 30, 2007 | Epson TM-U220D Matrix Printer
Epson TM-U220 Matrix Printer Logo
2,126 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
