Question about Compaq iPAQ BlackBerry H1100
Do I need to select iPAQ Backup Options each time before Backup or Restore?
    Master:
  • 425 Answers
Once Options are selected, they will be remembered (unless hard reset or total loss of battery power), so there is no need to select Options each time iPAQ Backup is used. In the case of hard reset or complete loss of Battery power, the options setting will require resetting.
Posted on Sep 12, 2005
SOURCE:
Trying to backup my 2415 iPaq. It used to save .exe files. Now, it only saves .pbf files. What's the difference - or does it make any difference at all? Also, I have a second iPaq that does NOT...
an .exe file is an EXEcutable file, it is the file that starts a program. It is not the backup data, but it may be the program that captures it.
Your .pbf files are indeed backup data files by Paragon backup and recovery program.
So, you would open Paragon using its .exe file and it backs up the data to .pbf files. To restore the files, you would open Paragon, and point to the last .pbf file or files to restore.
And yes, you could have Paragon Backup and Recovery on both machines and save the backups to a USB memory stick. What is on the memory stick can be accessed by Paragon on both machines. Make sure it is data only, rather than system files unless each computer is absolutely identical in model and spec.
PBF File Extension - What is a .pbf file and how do I open it?
https://fileinfo.com/extension/pbf
Backup archive created by one of Paragon's backup and recovery applications; stores backup files in a proprietary format; can be browsed within the software, which enables users to restore individual files or a whole file system. In addition to system backups, PBF files are often ...
File Extension .PBF Details
filext.com/file-extension/PBF Details for file extension: PBF - Grand Prix Legends BMAP (Bitmap) File :: PBF - Paragon Disk Image :: PBF - PBook E-book Format :: PBF - Portable Bitmap ...
How to view or import *.pbf file (OSM data, binary format) in ArcGIS for ...
https://gis.stackexchange.com/.../how-to-view-or-import-pbf-file-osm-data-binary-for... Oct 25, 2012 - The ArcGIS Editor for OSM (https://github.com/Esri/arcgis-osm-editor) should allow you to do what you want to do. Data is downloaded via the ...
Sep 02, 2017 | HP iPAQ HX2415 Pocket PC
Cannot get past opening screen or turn off unit. Unit seems frozen
Did you try to flash the BIOS/firmware of your device?
1.) Go to the Master Index of BIOS, FIRMWARE, & DRIVER Updates,
2.) Select the appropriate hyperlink for your model. (in your case it's here http://mobilitytoday.com/forum/showthread.php?t=4846)
3.) Download the most recent BIOS version SoftPAQ (SP) for your Model of iPAQ.
4.) Press the POWER + iTASK + CONTACTS + RESET buttons at the same time so as to enter the FLASH Mode
5.) Make sure your USB connection to the Cradle is hooked-up.
6.) Place your iPAQ in the USB Cradle.
7.) Stop the MS ActiveSync session on your HOST PC: CTRL-ALT-DELETE > TASK MANAGER > PROCESSES.
8.) Hilight WESCOMM.EXE and select "End Process" button.
9.) Run the file you downloaded from HP in step 3.
10.) The iPAQ should now begin Flashing the iPAQ's ROM BIOS
Jan 11, 2008 | HP iPAQ HX4700 Pocket PC
Tip
System Restore
Use System Restore to Undo Changes if Problems Occur
Windows XP Professional makes it easier to resolve problems if they occur in your system. You can use System Restore to remove any system changes that were made since the last time you remember your computer working correctly. System Restore does not affect your personal data files (such as Microsoft Word documents, browsing history, drawings, favorites, or e–mail) so you won’t lose changes made to these files. Windows XP creates “restore points” every day, as well as at the time of significant system events (such as when an application or driver is installed). You can also create and name your own restore points at any time. Creating a restore point can be useful any time you anticipate making changes to your computer that are risky or might make your computer unstable. If something goes wrong, you select a restore point and Windows XP undoes any system changes made since that time.
When you run System Restore, a calendar is displayed to help you find restore points. If you don't use your computer every day, some days might not have any restore points. If you use your computer frequently, you might have restore points almost every day, and some days might have several restore points.
To create a Restore Point
1. Access the System Restore Wizard through Help and Support Center. (Click Start, and then click Help and Support. Click Performance and Maintenance, click Using System Restore to undo changes, and then click Run the System Restore Wizard.
2. Click Create a restore point, and then click Next.
3. In the Restore point description box, type a name to identify this restore point. System Restore automatically adds to this name the date and time that this Restore Point is created.
  • To finish creating this restore point, click Create.
  • To cancel restore point creation and return to the Welcome to System Restore screen, click Back.
  • To cancel restore point creation and exit the System Restore Wizard, click Cancel.
To view or to return to this restore point, from the Welcome to System Restore screen of the System Restore Wizard select Restore my computer to an earlier time. Then select the date when the restore point was created from the calendar in the Select a Restore Point screen. All of the restore points that were created on the selected date are listed by name in the list box to the right of the calendar.
To set advanced restore options
1. Open Backup. (Click Start, goto to All Programs, point to Accessories, point to System Tools, and then click Backup.) The Backup Utility Wizard starts by default, unless it is disabled.
2. Click the Advanced Mode button in the Backup Utility Wizard.
3. Click the Restore and Manage Media menu and select the files to restore.
4. Click the Start Restore button.
5. On the Confirm Restore dialog box, click Advanced.
6. Set the advanced restore options you want, and then click OK. See the Notes section for a description of each option.
on Dec 01, 2009 | Computers & Internet
Wish to reset to factory spects. Echo uncontroled Feedback, Volume keys not working.
There are 2 ways to bring up the Restore function. The first is to turn on your laptop and as soon as you see the Dell logo press the Right Hand CTRL key and the F11 key at the same time. If your laptop was setup this way then you should see the Restore program run from the hidden restore partition of your hard drive.
If the above does not start the Restore process they your laptop was setup with the Dell DataSafe Restore system then follow these steps:
1) Shut down the Computer.
2) Turn on the Computer and start pressing the "F8" Key on the first Dell logo. Keep on pressing the "F8" key on first Dell screen until the Advanced Boot Options menu appears on the screen.
3) Highlight "Repair Your Computer" and hit ENTER.
4) Specify the language settings that you want, and then click Next.
5) Enter your Password and click OK.
6) On Choose a Recover Tool Window
Select: Dell DataSafe Restore and Emergency Backup.
7) You should see the following menu:
a. Restore computer and preserve my new or changed files
b Select other System Backup and more options
8. Select: Select other System Backup and more options
You get:
a. Restore my computer
b. Backup Files and folders
Select: Restore my computer..
Confirm the restore and continue..
Select: Factory Image restore
9) Choose Restore without preserving new or changed files and click on Next.
10) Click on Continue.
Your system should then run the DataSafe Restore and your laptop will be brought back to the same setup it had when you first turned it on. This will of course wipe out any data you have saved to the laptop as well as any extra programs you have installed. If you updated any of your drivers you will have to back to the Dell Support site and download and re-install the drivers.
Jun 27, 2011 | Dell Inspiron 1545 Notebook
Just format
First you need to take backup of the files of your device.
To perform a full or selective backup of the BlackBerry smartphone data using the Backup and Restore tool in BlackBerry Desktop Manager, complete the following steps:
Connect the BlackBerry smartphone to the computer running BlackBerry Desktop Manager.
Open BlackBerry Desktop Manager.
Click Backup and Restore.
Select Backup to perform a full backup or select Advanced to perform a backup of specific databases.
Choose a location to save the backup file, and then click Save.
After taking the backup follow the following steps to wipe your HH.
From the Home screen of the BlackBerry smartphone, go to Options > Security Options > General Settings.
Display the menu and select Wipe Handheld.
Click Continue.
Type blackberry, and then press the Enter key.
For BlackBerry smartphones running BlackBerry Device Software 4.2.2 and later
Select the Include third-party applications check box.
Click Continue.
Note: If you have turned on content protection, the process for deleting all data and applications from the BlackBerry smartphone can take up to an hour to complete. Do not remove the battery from the BlackBerry smartphone while data is being deleted.
Mar 10, 2009 | RIM Blackberry 8310 8320 8330 Curve 8100...
HP-iPaq 2215 battery replacement
Hi, Jim--
When you take the battery out of an IPAQ you're performing a hard reset. I've got 4 different IPAQs and it does the same thing on all of them.
My solution was to back the IPAQ up using the internal backup program (back up to IPAQ storage) and then replace the battery, then restore the last backup.
Saved me a heck of a lot of time. It's been hard to remember to back up everytime I add a program or change data majorly, but it's probably the best thing to do.
Nov 22, 2008 | HP iPAQ H2210 Pocket PC
Ipaq 4100 problem syncronizing with outlook on new laptop
you are now using outlook 2003 , probably cache , this means all the email is on your laptop. when you sync it will sync all the email (thousands). initialise your ppc (back to factory default). set up the sync via usb cable. then sync via bluetooth . then you are fully sync. now setup an auto backup of your email data (daily). if after some time , you have sync problem again , initialise the ppc, restore from backup and you are back to sync (last full backup). try this , you will never need to do it all again.
Regards
David Ng
Sep 23, 2008 | HP iPAQ H4150 Pocket PC
Restore
Within the interface there are 2 options. one for backup and one for restore. using the restore, you can select the files that you need and complete the restore
Aug 08, 2008 | Veritas Backup Exec 10 for Windows Servers...
Data erased from iPAQ hx4700
If an ipaq loses power , then all data in RAM is lost. It's important to keep it charged. It's also important to do regular backups..... so there are two backup options - one is thru Activesync which will backup to your PC and one is the IPAQ's own backup program which will backup to the IPAQ FILE STORE (area in ROM) or a SD card. I do the Activesync backup every time I sync and then the IPAQ backup about once a week or immediately before a system change. Activesync backup ------------------------ Here is a guide which best explains it http://www.cewindows.net/faqs/activesync/backup.htm this guide suggests doing a full backup, but it's fine to do an incremental backup each sync - this means that only changes will be added to your backup and makes the whole process much quicker. IPAQ Backup ----------------- So under Programs is a program called IPAQ Backup. The default location is IPAQ FILE STORE which is an area in ROM and is not lost thru a power failure nor hard reset. You may also choos to backup to a SD card - a full backup will need roughly 20MB. So in this backup procedure, if you click on 'Browse' you can choose a SD card. A restore can then be performed from the IPAQ FILE STORE or SD card (depending on which location you chose) and so if you are away from your PC, this will be no problem. A restore this way , rather than thru Activesync is also much quicker, so if you have a choice go this route.
Sep 11, 2005 | HP iPAQ HX4700 Pocket PC
HW6515 Phone Option Screen fail to launch
Sounds like it might be time to test things in a vanilla fresh setup.......... -Backup your system via iPAQ backup to an SD card (or ipaq file store if you have room) Warning, following will delete all main memory and set back to factory default! -do a hard reset (hold in power and reset for 20 seconds) -Test programs again, see if it acts the same. You can then restore your setup via iPAQ backup again if needed. You can also poke around the following site for suggestions on tested task managers and today screen apps. (I use HandySwitcher)
Sep 08, 2005 | HP iPAQ hw6515 Pocket PC
Compaq iPAQ BlackBerry H1100 Logo
83 people viewed this question
Top Compaq Computers & Internet Experts
pankaj rautela
pankaj rautela
Thomas F. Schneider
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
