Question about Onkyo Televison & Video
Switch mode power supply problem, all output voltage are out of spec. 5v is 4.66v -5v same -27v is -33v -9v is 8.33v. ckd all diode & reg ic all seem ok. chopper ic is working?? hence the above o/p's can't find spec on 5mo365r ic.?? any clues thks pete
  • Steve Rand
    Steve Rand May 11, 2010
    As far as i'm aware, that's all quite normal! PC power supplies will give very similar readings... always just a fraction off the actual voltage.
    It shouldn't be a problem, I wouldn't think... all are less than 10% from the operating ranges.
    The only thing I can see as a problem is the -9v being +8.33, but I suspect that is a typo (based on your VERY hard-to-read shorthand)
    I assume there is something wrong with your DVD player, right? Or are you just concerned about the variances?
night71
  • 328 Answers
SOURCE: POWER OF 5V IS THERE, 9V IS THERE, GOES INTO PC BOARD UNDER DVD MECH.
Since I don't know what model it is, I am going for a shot in the dark. I found a place that has service manuals for Daewoo for free. If none relate to your DVD player, please give me the model number and I may find one for you.
http://www.eserviceinfo.com/repair_tips_database/Daewoo_001.html
Posted on Nov 10, 2007
SOURCE: Magnasonic DVD803-2 DVD player, stuck at standby
Hi kamil. Mo medenom, nomogom! I think problem isn't in power supply. It should be in control board (madaar-e farmaan). Hossain Shahidzadeh
Posted on Feb 24, 2008
SOURCE: Will not power up
Checa si hay filtros secos en la fuente puede ser uno de 50v a 100mf.
Posted on Mar 25, 2008
  • 14 Answers
SOURCE: Dell 1800FP Dark, No Power but power supply seems fine. Help!
I just repaired 3 1800FP's - all dead, no lights.
Firstly a dead 2AS01 is 95% of the problem, because some fool designer left out the protective zener diode - cheapness.
Mouser Electronics does not have this part, but lists it at 37 cents in lots of 2500, and gettable at $2.66 somewhere else.
You must also replace the two small value electrolytics near this IC, as some had an ESR of 40 where <0.5 is where it should be.
I suppose as the electro's dry out, the spikes can zap the IC. The quacks on ebay flogging 2sa01's alone, probably hope to sell you another one down the track (at a fat markup).
There are 2 'Sam Young 2200uf' electros that really should be replaced, with ESR or 2-30 ! Ideally replace ALL electros, as the others will be off - but those 4 as a minimum and using a jewelers loupe, resolder other joints on the transformer and anything that looks more dull silverish, than the rest. A 1 inch used and worn paint scraper will get the case open easy.
DANGER, CAUTION : Finally when refitting the inverter board, ensure the steel tab is over the TOP middle of the board facing away from the power socket (SO YOU CAN SEE IT) . The board sides in flat. It is possible to scew the board down with a slight bend, with the tab pressing over the pcb tracks - very , very bad!
Now all I need is for some kind soul to improve the fix by stating what the value of the missing zener should be.
PS. Just because the caps are not bulging does not mean they should be OK. Most wrecked 10 year old power supplies have better ESR's, so the electronics must be hot under the cover.
I have seen bulging caps with a GOOD ESR, and non bulging ones with an ESR of 47.
Canberra
Posted on Aug 28, 2008
bob_computer
  • 3153 Answers
SOURCE: Pin Name Color Description
Yes this is a good list of the voltages to be expected from a newer power supply on just the main header
Posted on Aug 11, 2009
Aiwa crt tv as2180nh stand by red led is on but no display
9VDC supply come from one of the LOT winding. If it should be there, the LOT should work. Check and replace damaged component/s at its horizontal scan output section circuit. Check the LOT (Line Output Transformer) too for damage. Replace the horizontal scan output transistor. Check the input voltage to LOT. If the voltage is absent check the feeder resistor; if any. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
Jul 23, 2015 | Aiwa Audio Players & Recorders
Tip
How to measure the voltage on TV
Voltage measured on DC scale, black cable multitester / avometer put on a negative path or can be slipped on the silver wire in the tube that is not disposable wrapping.
Next, measure the voltages are available:
  • For 180v voltage can be measured on the positive pin elco (10uf/250v) in PCB RGB tube.stick pin red wire multitester
  • Voltage 110v for TVs 14 "-21" and 130v for 25 "-29" in the B + FlyBack Transformer (FBT), find the path there is elco 100uf/160volt. measure on a positive foot elco.
  • For 12volt voltage, please measure at the foot of the right edge of IC 7812.
  1. For voltage 5V, please measure the right foot of IC 7805.
  2. For voltage 33v, please search at the foot of VT in tuner.
  3. To measure 90v-300v, scale use DCV 250.
  4. To measure the 12v-40v, use a scale of 50 DCV
  5. To measure the voltage of 1V-9v, 10 DCV-scale use.
  6. How to measure the voltage on the yoke and in plyback is;
    • From the yoke horizontal = Fcc 110v DC, 1000 V. AC voltage can be removed with a red plug in output and in use as dB meter.
    • From the yoke pertikal 24 DC current model, except for disposable coupling C = 1 / 2 Fcc. While it could be IC 120V AC (with dB meter)
    • At Fcc FBT kolector; 110v DC, AC voltage = 1000 V..
    • At Fcc FBT filement / heater = 5V-5, 5V AC.
    • In the FBT 20-32k anode voltage V measured with 40kv HV probe is added to the multitester 1000 V. DC.
    • Voltage others depending on model and type of TV. 180v out there (for RGB) directly from the regulators, transformers, Video Amp taken from FBT.
    • There are 24V and 46v vertical FBT, also 12-18V depending on brand and type.
    • Voltage 600 V DC and focus around the screen 400v DC.
    Thus tip n trick from me (AGUS YUSTIARA ), hopefully useful.
for more info , at http://trend2download.blogspot.com
on Aug 16, 2010 | Televison & Video
How can fix a 33v tuner in the place of 5v tuner
33V is used as the tuning voltage, which has supplied to the varactor diodes inside the TV, and not is the supply voltage. The supply voltage is 5V itself, and this is a 5V tuner. The only thing to note is, whether it uses SDA - SCL or Bl -BH. This is the type.
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. Do a search by type in the brand name of your device at its search box and press "Enter".
Jul 25, 2014 | Televison & Video
I have sharp tv model 20v-r70m not power on the b+ is ok i try test 9v supply go to ic801 drop the 9v,then i try replace ic801 nothing happen, how to fix this
pls. check if there has 5v ic regulator... also check the open non- electrolytic colored yellow or orange tantallum capacitor near the talc switches and memory ic.if i'm not mistaken.... the capacitor value is 2.2uf 50v.
Jul 14, 2014 | Sharp Televison & Video
I have sony J21mn11. problem not power on only red lit led only.i check all the components on the power supply area and horiz. output D1878 all are good. there is power IC STR S6707 on power supply area. i...
If you have a digital tester or analog try to check the voltage reading from the power supply if high or low or no supply.Check first following voltage location and section. * Check the AC voltage from ac cord to fuse and before the bridge type diode. * Check the DC voltage after the bridge type diode.if normal voltage. * Then check the voltage into the filter capacitor to regulator ic.the power ic.If theres a input voltage in the power ic,check the output voltage going to harizontal output.If no output the problem is you power output.You need to replace it.
Jul 12, 2011 | Sony Televison & Video
ATX-300-12Z was hit with a power surge (thought we had a surge protector). Green light on power supply blinking at 2X/second. No power at USB devices (or anywhere else.) PC was on when surge hit.
There were 2 Switching power supply circuit inside the ATX PSU. There's a Standy PWM circuit whichSupply +5V to the PWM IC of the Main PWM. Stand by pwm still working or insufficient voltage, lower than +5V. This is the reason you still have Green light. Check or replaced small filter capacitor around 100 MFD 16V, open resistor or shorted diode that was nearest of the PWM IC..
Watch out for charge voltage on big capacitors.
Rleo
Dec 30, 2010 | HP ATX-300-12Z (ATX30012ZBD) 300-Watt...
Noisy when I use with 9v charger and is not
The posts on this site will help:http://music-electronics-forum.com/t10712/ I had trouble finding the correct schematic but the one here:http://www.tonepad.com/getFile.asp?id=42 should give you an idea of what I am talking about. Using a volt ohm meter on the D.C. volts scale ,hook up the black probe to the circuit ground. Make sure to use the correct adapter as a variation in the current output. ma will blow your pedal up. The diode in the schematic with one end hooked to ground protects the circuit from adapters that are wired backwards. It is the first thing you want to check. You will have to perform a diode test. Hopefully your meter has this function. If the diode is O.K. and you can get the correct voltage ( polarity, milliamps etc.) into the circuit, have a look at the schematic. Test each I.C. for voltage at pin 8. Depending on what I.C.s are in your pedal you can find the defective one by testing for voltage at the supply pin and then the other pins of each I.C. If you find voltage at a pin that should only be carrying signal you probably have found a defective one.For instance, in the sample schematic, pin 2 of IC 1a should have no voltage present such as 9 volts for instance. Test all the diodes, test all the ICs. If they are all fine you will have to test each transistor. The info on how to do all this as well as the pin outs are all available on the internet. After you find the defective part or parts test any parts that are hooked to them in the circuit as well as they may have failed or caused the other part to fail. Before I got an oscilloscope I had to unsolder a lot of parts to test them with a VOM, a transistor tester and a capacitor tester. The repairs paid for the scope. Let me know how you make out. I don't work on effects that much any more as my eyesight is failing but I might be able to steer you in the right direction. If you decided at this point that you don't want to try the repair, take it to a good musical instrument repair place and have it fixed. Vintage pedals are getting to be worth a lot of money and they usually sound better than the reissues.
Nov 29, 2009 | MXR Phase 90 Pedal
Does anyone have the voltage specs on a PNT-426 Power Supply. It is for my NEC PlasmaSync PX-42VM5A Monitor. My electrician has found a faulty diode but doesn't have the voltage specs on it. I have a...
I have a PX-42VM5A and my Power supply is a PNT-426 (by Sanken Electric Co. LDT). Here are my specs: INPUT: AC 100-240V; OUTPUT: (there are nine outputs) +170v 1.6A; +60v 1.6A; +5v 4.0A; +2.5v 1.9A; +3.5v 1.9A; +7v 1.0A; +12v 0.5A; +12 v 1.9A and +6v 1.2A
Jun 17, 2009 | NEC PlasmaSync 42VP4D 42 in. HD-Ready...
Sharp colored tv
check the b+ supply of your flyback if they have check the horisontal transistor. check also if they have 5v supply in the system and 9v in the chroma ic or replace the memory ic.please reply.
Aug 08, 2008 | Sharp 25R-S100 25" TV
Samsung 953BW monitor alwyas goes to blank screen
first u will check the signal cable then check crt base [ if lot is arcking ok] replace crt base check filament volt,g2 volt,g1 vot .....etc,then u r chek 5v reg ic in supply out on smps,eprom chip and check H OUT transistor base voltage u r problem not solved about this information pls ask again to me may i help u.......
May 16, 2008 | Computers & Internet
Televison & Video Logo
102 people viewed this question
Top Onkyo Televison & Video Experts
Computer Repairing
Computer Repairing
Martin Murray
Are you an Onkyo Televison and Video Expert? Answer questions, earn points and help others
