Question about Samsung HP-S4253 Television
Changing picture to wide screen full screen on Samsung HPS4253
I am unable to change to full screen since I have had digital cable installed. It worked at first, however when I had some electrical work done all house power was shut down and when turned back on I only receive two options, the 16.9 and 4 something iot does not give me the wide screen full screen option now. How can this be fixed?
I just had my digital cable installed yesterday. He had to jack with it for about 20 minutes until he got it to work. He accessed some sort of internal menu on the cable box by pushing power and menu at the same time. He had to select some sort of 4:3 overide option and that finnaly did it.
Posted on Apr 14, 2009
Installed comcast cable box to emerson flat screen tv. it is hdmi, 1080. now i don't have a full screen picture.
Try using the wide mode. There are multiple screens you can get such as wide, zoom, full, and wide zoom. Go through these til you get the picture you want.
Mar 26, 2015 | Emerson Televison & Video
HOw do I Reverse Full Screen?
Refer the user manual to your TV and check how can you change the aspect ratio of picture. Changing aspect ratio will change the height of the picture.
May 10, 2012 | Universal Remote Control Osiris Complete...
How do i adjust the picture to fit the screen?
The wide button on your remote adjusts the picture size. Each time you press it you adjust the picture. If repeatedly pressing the wide button is not changing the picture size check you cable/satellite remote control. Look for the hdzoom# button. There may also be an aspect or format button. When you adjust this the picture size changes and between the Sony remote and the cable/satellite remote you should be able to come to a happy medium. If the picture size still isn't changing you might not be set to the correct resolution i.e. 1080i on your cable/satellite box. It might be set too low or you might be in the wrong input (av 1 av 2 hdmi 1 hdmi 2) etc.
Jul 07, 2010 | Sony BRAVIA KDL-40V2500 40 in. LCD HDTV
What are the best picture settings for a ln32b360 samsung lcd tv.
Well, picture settings for this tv, is basically personal preference, size of the room, distance you will be from the tv, ect. even the lighting in the room. Changing any of these factors can change what resolution you wanna put your tv into. As well wide or full screen is a personal preference. The best thing to do would be simply play with the display settings and see what works the best for you. Telling you exact settings may not work for you.
Nov 04, 2009 | Samsung LN32B360 32 in. LCD HDTV
Changing wide screen
possible on a cable box, if so hd cnan are automatic on certain hd channels
Aug 10, 2009 | Sony FD Trinitron WEGA KV-34HS510 34" TV
I cannot get my cable to show in full screen. I have Time Warner HD service. Im hooked up right, but my picture does not use the whole 37" screen. When I change my picture width, I get No Scale, Full,...
For HD you have to have a square screen
Sorry to disagree; the standard screen has an aspect ratio of 4:3, this is far more 'square' than the 16:9 (aka 'wide screen') which is standard for HDTV. If you are on cable or satellite service, you may well have to pay extra to have the whole of your screen available for viewing.
That is why only 'over the air' broadcasts are absolutely affected by the change from analog to digital next February but other sources do not have to change over to the new standard and the 4:3 sets will work fine without any extra box until those sources decide to 'go digital.'
Dec 30, 2008 | ViewSonic N3735W 37 in. LCD TV
Picture format
The HD reciever shouldn't be the problem.
If you recieve an image with a 4:3 aspect ratio, the image will be displayed at that ratio on your HDTV unless you specify otherwise. To do so go to your TV's Setup screen
setup
Choose picture formats
select smooth wide as your default
***Some digital (ATSC format) stations may transmit 4:3 images in a way that will not allow expansion. You will be unable to adjust the picture format.
Hope this helps!!!
J
Nov 17, 2008 | Hitachi 53SWX10B 53" Rear Projection...
Plasma resolution
Greetings bigdaddyjr,
You can find the start of instructions for changing your resolution on page 52 of your instruction manual. I found a copy of your users guide at the following link with Samsung:
http://www.samsung.com/us/support/download/supportDownDetail.do?group=&type=&subtype=&model_nm=HP-S4253&language=&cate_type=all&mType=UM&dType=D&vType=R&cttID=921348&prd_ia_cd=02010200&disp_nm=HP-S4253
I hope this helps.
Thank you,
Dort
Go Ahead. Use Us.
Apr 20, 2008 | Televison & Video
Normal Picture Mode Not Available With Cox HD-DVR (Motorola DCH3416) and HDMI Cable
With an HDMI cable connected, the cable box determines the picture size. The settings on the cable box must be changed in order for you to get the correct picture size. I have some experience with Motorola cable boxes; usually to access the settings you turn the box OFF and then press the menu or settings button on the box to bring up the display menu. Hope this helps!
Mar 05, 2008 | Sony KDL-32M3000 32 in. LCD Television
Unable to do anything but trun it on.
In addition to the one year World Wide Warranty,
issued by Olympus Corporation in Japan, the European warranty, issued by Olympus Imaging Europa GmbH, is
valid for two years from the date of purchase, if purchased after 1st April 2004
Aug 28, 2007 | Olympus FE-140 Digital Camera
Televison & Video Logo
119 people viewed this question
Henry  Thomas
Henry Thomas
Jerry Greenberg
Jerry Greenberg
