Question about Hotpoint Washing Machines
Hotpoint washer machine repair
Problems in my machine not working will the problems in the rinse step and think its a timer problems and im loking for the service center in melbourne australia
my e mail alsaafin_jamal@hotmail.com
  • 1,543 Answers
If you mean the washer goes up to the rinse cycle and then just sits there, check cold water inlet screen where hose attaches to washer for blockage. #2 could be a bad water valve.
Service outside the US ? Try geappliance.com? or call US 800 #
GE answer center 800-626-2000 ?
Do an "Ask Me" if you have future questions and more details on your washers symptoms.
Posted on Aug 31, 2008
Have a hotpoint aquarius wml540 that is stopping on the rinse cycle, when it stops the rinse light is on and the red lock light is flashing, is this an error code?
WASHER WILL NOT RINSE:
If your washer doesn't go through the washer rinse cycle, the most likely cause is the water valve. What happens is the water valve will stop letting cold water into the washer; therefore, once the washer gets to rinse it will either stop or not do anything during the whole rinse cycle.
This is because when you selected your water temperature, you selected warm/cold or hot/cold. The hot water came in and you didn't notice any problems. When it got to rinse, the cold water the cold water won't come in. Therefore, the washer does nothing.
To check the water valve, first cut the water off and remove the hoses off the back of the washer. Then one at a time point the hoses inside the washer tub and turn the water back on. If you don't have good water pressure, turn the water back off and remove the strainer that should be in one end of the hose. Inspect the strainer to see if it is stopped up, clean it and reinstall it. Now repeat this test. If you have good water pressure now, reinstall hose and your problem is fixed.
If you still don't have good water pressure, the problem is in your house plumbing and you need to call a plumber. If you had good water pressure the first time you performed the test, the water valve is bad and needs replacing.
TIMER
If your washer doesn't go through the washer rinse cycle the timer may be the problem. Sometimes the timer gets stuck in the middle of the cycle or won't turn at all. If the washer runs, but the timer doesn't turn, the timer is bad and needs replacing.
Do you have anti-flood hoses leading to the machine. If you do there is probably a loose tube in the back causing a small leak. When the hoses detect that water is still flowing after a certain amount of time due to the leak it shuts down and causes the machine to turn off during the rinse/spin cycle
Apr 07, 2015 | Hotpoint Washing Machines
Help me
If you have water for washing the dishes and only the rinse water will not flow then the problem is likely a defective timer control. The timer send signals to the washer for all of its basic function to start and stop. Bad timers are a common problem, especially with an older machine, but they can also go bad in a new machine. f the dishwasher is under warranty follow the warranty service steps to get local free repair. Otherwise you may have to purchase and install a new timer yourself or hire someone to do this at an appliance shop.
Apr 29, 2013 | Dishwashers
The washing machine on/of button and the energy saver button starting blinking simultaneously half-way during my washing. The washing was done I think but it didn't rinse & spin.
Check your pump for any blockages it may not be pumping out fast enough the timer only gives the pump a certain amount of time to pump all the water out if has got some blockage than clean out and this should solve the problem.
Mar 07, 2011 | Hotpoint Aquarius WF210 Front Load Washer
Hi,my washing machine will not rinse and spin unless you stop it move the dail then turn it back on can you help
Hi! I am a technician. I repair electrical appliances and would like to know why does the Normande fridge have two timers while all other fridges do with only one? One of them is obviously the defrost timer but what's the other one for?
Thanks!
Feb 09, 2010 | Hotpoint Aquarius WF000 Front Load Washer
Hotpoint washer
common problems with timer which work like a clock and goes though the cycle, bad timer will cause it not to go through its cycle. it very cheap and easy to replace everything is all plug in.
Nov 14, 2009 | Hotpoint WMA40 Front Load Washer
The machine when it is on a cycle sticks on the rinse spin
hi..most likely the timer switch which might have got
into trouble,this controls all the different cycles.
check it out..
thank u..
kindly rate my response..
May 09, 2009 | Hotpoint Aquarius WF000 Front Load Washer
Hotpoint washer dryer lights flashing
Check first the thermal fuse.
Test heating element to ensure is not grounded, and staying always on. Test the fan and ventilation system.
If you find no fault in there , then test the timer control board.
Enter the model number on one of two websites below to get parts and diagrams for your appliance:
Appliance Parts From PartSelect
Appliance Parts Pros
Apr 23, 2009 | Hotpoint Ariston Aquarius WD420 Front Load...
Washer won't rinse, drain or spin.
My guess would be that you have a faulty timer if you can manually move it and the operation of the washer resumes.
http://tclaundryrepair.com/
Feb 18, 2009 | Whirlpool Ultimate Care II LSQ9564J Top...
Washing Machines Logo
61 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Todd Arndt
Todd Arndt
puggy666
Level 1 Expert
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
